Default weather module question
It seems that recently the default weather forecast has been showing what appears to be the forecast heat index instead of the forecast high. This may be an issue at the source?
@earnestrichards I would open an issue on the MagicMirror GitHub
please provide the config for the weather module… of course xxxxx out any apikey
@earnestrichards Which weather provider are you using?
@ankonaskiff17 As I can see in the image snapshot the weather provider seems to be OpenWeather.
@boblewis I use weather.gov and look is different.
