    MM, bullseye, Pi 3B+ issues
    7 Posts 5 Posters 1.3k Views 5 Watching
      alex2 @alex2
      @alex2
      The other odd thing, which is likely unrelated and I will need to touch base with the module developer, is that the Grove Gesture module suddenly no longer commands modules to appear/hide. I had it setup so a swipe would either hide all my modules or show all my modules, and another swipe would hide/show a specific module, and it randomly quit working as well. The module still runs and I get the feedback that it recognized the swipe, but the command to modify the view doesn’t process.
      LusbuebL 1 Reply Last reply Reply Quote 0
        sdetweil @alex2
        @alex2 there is a wifi timeout setting. Google search.
        on the swipe… do u have all the right modules loaded?
        swipe sends a notification to some other module, which one?
        none of the defaults hide/show modules on notification
        • LusbuebL Offline
          Lusbueb @alex2
          @alex2 I’ve always had problems with MM hanging (under stretch and bullseye) with RasPi3B+, my solution was this cron job: 0 */3 * * * root systemctl restart pm2-pi
            alex2 @Lusbueb
            @Lusbueb
            apologies for the newbie question, but how did you implement this cron job? is it just a run once command or did you need to set it up as a recurring thing?
            • bheplerB Offline
              bhepler Module Developer @alex2
              @alex2 Google is your friend.
              What is a Cron Job and How Do You Use Them?
              • BKeyportB Offline
                BKeyport Module Developer @bhepler
                @bhepler also, https://crontab.guru/
