    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 434.5k Views 32 Watching
      Studio472
      How do I remove the “fade to black” at the bottom of the agenda?
      M 1 Reply Last reply
        MMRIZE @Studio472
        @Studio472
        Append this to your custom.css
        .CX3A .agenda::after {
          display: none;
        BKeyportB 1 Reply Last reply
        • BKeyportB
          BKeyport Module Developer @MMRIZE
          @MMRIZE Boy, we did things the hard way…
          /* Fade adjustments */
          	position: absolute;
          	bottom: 0;
          	left: 0;
          	height: 6%;
          	width: 100%;
          	content: '';
          	background-image: unset;
            MM19198
            I was able to get MMM-CalendarExt3 working, but I’m struggling with MMM-CalendarExt3Agenda. I cannot figure out what I’m doing wrong. None of the events appear in the MMM-CalendarExt3Agenda module but they do appear in the MMM-CalendarExt3 module. Any help is appreciated.
            Google Calendar Config
            	module: "MMM-GoogleCalendar",
            	header: "Family Calendar",
            	classes: "calendar-agenda",
            				symbol: "calendar-week",
            				calendarID: "myemail@gmail.com",
            		broadcastEvents: true,
            		broadcastPstEvents: true,
            		maximumEntries: 100
            MMM-CalendarExt3 Config
            	module: "MMM-CalendarExt3",
            	position: "top_center",
            	title: "Family Calendar EXT3",
            		mode: "month",
            		instanceID: "Ext-Calendar-Month",
            		calendarSet: ['mycalendar'],
            		weeksInView: 3,
            		preProcessor: (e) => {
            			if (e.start?.dateTime) {
            				  e.startDate = new Date(e.start.dateTime).valueOf()
            			} else if (e.start?.date) {
            				  e.startDate = new Date('${e.start.date}T00:00:00').valueOf()
            			if (e.end?.dateTime) {
            				  e.endDate = new Date(e.end.dateTime).valueOf()
            			} else if (e.end?.date) {
            				  e.endDate = new Date('${e.end.date}T00:00:00').valueOf()
            			e.title = e.summary
            			e.fullDayEvent = (e.start?.date) ? true : false
            			return e
            MMM-CalendarExt3Agenda Config
            	module: "MMM-CalendarExt3Agenda",
            	title: "Something",
            		instanceId: "Ext3-Calendar-Agenda",
            		firstDayOfWeek: 1,
            		startDayIndex: -1,
            		endDayIndex: 10,
            		showMiniMonthCalendar: false,
            			e.title = e.summary
            			return e
              MM19198 @MM19198
              I was able to get it working. For those that may need to resolve this in the future, the answer was at this link:
              https://github.com/MMRIZE/MMM-CalendarExt3Agenda#update-to-120
              When some submodule is not updated, try this.
              cd ~/MagicMirror/modules/MMM-CalendarExt3Agenda
              git submodule update --init --recursive
                danidanial
                I was able to get it working. For those that may need to resolve this in the future, the answer was at this link: :backhand_index_pointing_right_light_skin_tone:
                  MarNog @MMRIZE
                  @MMRIZE Thanks for the module! I see your first screenshot and looks like you have multiple calendars using the original MMM-Calendar and MMM-CalendarExt3Agenda modules. What setting do you use to get it working like this? I setup mine, but I cant figure out what do do on the original MMM-Calendar module to display only one specific calendar and another calendar to be displayed using Ext3Agenda module. Also, what is the best way to get hyphens in the column to be between the times when using 2 digits for hours?
                  	header: "Cabrillo's Dates and Deadlines",
                  	position: "bottom_right", //When you want to hide default calendar module, just remove position of calendar module.
                  		maxTitleLength: 50,
                  		wrapEvents: true,
                  		tableClass: "small",
                  		maximumEntries: 13,
                  		//sliceMultiDayEvents: true,
                  			symbol: "calendar-check",
                  			name: "Cabrillo_Dates_Deadlines", // <-- specify calendar name
                  			url: "https://calendar.google.com/calendar/ical/c_5a2463022055508fcb5a604f131895484562edb98904940f4efb3fa1c1362e47%40group.calendar.google.com/public/basic.ics",
                  			// HOW to REMOVE this one from the Calendar Module??
                  			url: "https://calendar.google.com/calendar/ical/c_jvq8rotabh0rrru2qeo2oec9gc%40group.calendar.google.com/public/basic.ics",
                  			name: "CTC_Schedule", // <-- specify calendar name
                  			color: "skyblue", // <-- if you don't want to get color, just remove this line.
                  			broadcastPastEvents: true, // <-- need to broadcast past events
                  			maximalNumberOfDays: 30, // <-- how old events would be broadcasted
                  			maximumEntries: 100, // <-- assign enough number to prevent truncating new events by old events.
                  			symbol: 'calendar-check', // <-- when you want to display symbol. If you don't want, just set as `symbol:[],`
                    title: "CTC TA Schedule",
                      instanceId: "CTCCalendar",
                      firstDayOfWeek: 1,
                      startDayIndex: 0,
                      endDayIndex: 2,
                      calendarSet: ['CTC_Schedule'],
                      eventFilter: (ev) => {
                               if (ev.title.startsWith("OUT")) {
                               	return false
                  	     return true
                  Thank you
                  BKeyportB M 2 Replies Last reply
                  • BKeyportB
                    BKeyport Module Developer @MarNog
                    @MarNog Multiple instances of the calendar module. One with position in place for the ones you want to show with the default module, one without a position for the ones you want to display with CX3A.
                      MMRIZE @MarNog
                      @MarNog
                      Interesting. You might have added some custom CSS, so hard to guess what happened at the moment.
                      I think the area for time displaying is not so wide enough. Give them more space.
                      Currently, the hyphen and startTime/endTime condition is defined like this.
                      /* MMM-CalendarExt3Agenda.css line 187 */
                      .CX3A .event .time {
                        font-size: 75%;
                        vertical-align: text-bottom;
                      .CX3A .event .time.notInDay {
                        display: none;
                      .CX3A .event .startTime::after {
                        content: ' -';
                      .CX3A .event .startTime.notInDay + .endTime.inDay::before {
                        content: '- ';
                        MarNog @BKeyport
                        @BKeyport I added another instance of the Calendar module and it worked like charm. Thank you.
                          MarNog @MMRIZE
                          @MMRIZE I had used a custom.css from someone’s post and I modified the font size. After your suggestion I changed the width on the custom.css and the time is showing correctly now. Thank you
                          • T
                            themoe @MMRIZE
                            @MMRIZE I really like your modules! I tried to setup the Ext3Agenda, but with no success.
                            Can you share the part of the config file to show the Agenda for a couple of days with the scheduled meetings?
                              MMRIZE @themoe
                              @themoe
                              In many cases; ppl might have missed/made wrong to the default calendar setting.
                              Show me your config for default calendars module and CX3A instead.
                              • G
                                gonzonia
                                I have two instances of MMM-CalendarExt3Agenda showing with different calendar sets.
                                For one set it shows data for 4 days, with all days populated.
                                For the other one, it shows 4 days but the last day isn’t populated. If I increase the endDayIndex by 1 it will add a 5th day and day 4 will be populated but the 5th day will not, so I know the data is there.
                                Any ideas what would cause this?
                                Working instance 1:
                                			classes: "SceneFamily",
                                			header: "Upcoming Family Calendar",
                                				instanceId: "FamilyAgenda",
                                				locale: 'en-US',
                                				firstDayOfWeek: 1,
                                				startDayIndex: 0,
                                				endDayIndex: 3,
                                				useSymbol: true,
                                				calendarSet: ['Dad', 'Mom', 'Kid1', 'Kid2', 'Work1', 'Work22, 'Home'],
                                Missing Data Instance 2
                                			classes: "SceneFamily SceneKids",
                                			header: "Chores",
                                				instanceId: "Chores",
                                				locale: 'en-US',
                                				firstDayOfWeek: 1,
                                				startDayIndex: 0,
                                				endDayIndex: 3,
                                				useSymbol: true,
                                				calendarSet: ['Dad Chores', 'Kid Chores', 'Mom Chores'],
                                • UncleRogerU
                                  UncleRoger
                                  I apologize for what I’m sure is a bonehead question… I had a stock calendar module to show events from one calendar (and a second, hidden instance of calendar) but when I tried to implement pages (MMM-Pages), it was loading the hidden calendar along with the non-hidden one.
                                  So I thought I’d try CalExt3Ag to replace the visible calendar. The problem is, I want it to look like the stock calendar:
                                  but the best I could get is this:
                                  Is it possible to get a much simplified listing (one line per event, relative dates) of events using CalExt3Ag?
                                  • BKeyportB
                                    BKeyport Module Developer @UncleRoger
                                    @UncleRoger Not exactly. However you can get it simplied some:
                                    That’s all CSS.
                                      MMRIZE @UncleRoger
                                      @UncleRoger
                                      1. About the look of the module to mimic the original calendar module;
                                        Sorry, it can’t. This module is an alternative view of your events listing, not a replacement. If you need only the same look as the original calendar, just use the original.
                                      2. About the working with MMM-Pages.
                                        MMM-Pages is a good, reliable module, though it doesn’t consider the multi-instance of the module. So when you need multi-instances and want to show/hide on different pages, it cannot work as expected. Try other paging/screen control module. (e.g. I recommend MMM-Scenes2 with shame.)
                                        MMM-Scenes2 Demo
                                        Click to see the DEMO
                                      My mistake. You can assign class name in MMM-Pages settings. (Thanks @sdetweil )
                                        sdetweil @MMRIZE
                                        @MMRIZE i.like you Scenes module.
                                        but MMM-Pages works fine for multi instance. just don’t use the module name in the page definition
                                        use page1, page2, page3…
                                        and then use that in the individual module classes: setting
                                        super easy and much more clear
                                        M UncleRogerU 2 Replies Last reply
                                          MMRIZE @sdetweil
                                          Ah, I misunderstood those identifiers are module name not class name.
                                            sdetweil @MMRIZE
                                            @MMRIZE well they are used as class names in the code lookup. each module’s name is
                                            assigned as a class in the Dom for each module.
                                            that’s why using module name is not instance aware.
                                            but classes can be any string, and pages just search for all with that class.
                                            • 11
                                            • 12
                                            • 6 / 12
