    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 416.7k Views 32 Watching
      MMRIZE
      1.2.0 (2023-04-25)
      • ADDED: weatherNotification, eventNotification - To get data from 3rd party module which is not compatible with default modules.
      • ADDED: weatherPayload, eventPayload - To manipulate or to convert received payload itself on time. (e.g. Convert Celcius unit to Fahrenheit unit)
      • ADDED: Hiding day cell which has no event : onlyEventDays: n
      • CHANGED : Display whole month events in miniCalendar regardless of agenda showing (despite endDayIndex or onlyEventDays)
      • CHANGED: Shared library to fix many issues.
      • CHANGED: Timing of eventFilter and eventTransformer is delayed for better-handling event data after regularized
      • FIXED : Pooling events with multi-calendar modules’ notification
      • FIXED: position issue (I hope so…)
      • FIXED: some typo.
      • FIXED: flickering for many reasons (logic error to treat notifications)
      sc
      • BKeyportB Offline
        BKeyport Module Developer @MMRIZE
        @MMRIZE
        Broke: My install… Nothing is coming up. I’ve attempted removing my custom CSS, which doesn’t help, so I’m figuring it’s something in my config. Here’s one of the 3 instances.
        Nothing showing up in the logs, which are set for info, log, warn, error, and debug.
        			module: "MMM-CalendarExt3Agenda", // https://github.com/MMRIZE/MMM-CalendarExt3Agenda
        				instanceId: "1",
        				showMiniMonthCalendar: false,
        				firstDayOfWeek: 0,
        				startDayIndex: 0,
        				endDayIndex: 99,
        				minimalDaysOfNewYear: 1,
        				animationSpeed: 0,
        				useSymbol: false,
        				useWeather: false,
        				calendarSet: ["Main", "Utility"],
        				eventTransformer: (ev) => {
        					if (ev.title.search("⚾") > -1) {
        						ev.title = ev.title.replace("⚾️ ","");
        					if (ev.title.search("Bowling") > -1) {
        						ev.color = 'yellow';
        					if (ev.title.search("🏈") > -1) {
        						ev.title = ev.title.replace("🏈 ","");
        					return ev
          sdetweil @BKeyport
          @BKeyport its all in the browser, so open the developers window, console tab
          put ext3 in the filter field
          • BKeyportB Offline
            @sdetweil You really think I forgot to check that?
            I did forget to look at the console, though:
              no idea that the ‘not prepared yet’ means
              • BKeyportB Offline
                @sdetweil Same. I figure there’s an option somewhere that’s preventing me from loading it fully. I’m sure @MMRIZE will have it fixed right away.
                  MMRIZE @BKeyport
                  @BKeyport
                  I refactored all the duplicated logics in these modules and separate it with sub module named ‘CX3_Shared’.
                  That message happens when that submodule is not loaded(with certain reason). Most suspicious thing would be that submodule is not installed properly. Could you check it again?
                  https://github.com/MMRIZE/MMM-CalendarExt3Agenda#update-to-120
                  • N Named54 referenced this topic on
                  • BKeyportB Offline
                    @MMRIZE Oh, doh! you gave in and had to install a dependancy/submodule! 🤣🤣🤣
                    Missed that.
                    • BKeyportB Offline
                      Doing some clean up work and some things aren’t working.
                      The module isn’t updating in my config.
                      Here is the configs and details.
                      				instanceId: "1",
                      				firstDayOfWeek: 0,
                      				startDayIndex: 0,
                      				endDayIndex: 99,
                      				animationSpeed: 0,
                      				useSymbol: false,
                      				useWeather: false,
                      					return ev
                      //top_center
                      			position: "top_center",
                      				instanceId: "2",
                      				firstDayOfWeek: 0,
                      				startDayIndex: 0,
                      				endDayIndex: 99,
                      				animationSpeed: 0,
                      				useSymbol: false,
                      				useWeather: false,
                      				calendarSet: ["Seahawks", "Sounders", "Bluejays", "Mariners", "Kraken", "Huskies", "XFL", "ARES", "Holdays"],
                      						ev.title = ev.title.replace("⚾","");
                      					return ev
                      				instanceId: "3",
                      				firstDayOfWeek: 0,
                      				startDayIndex: 0,
                      				endDayIndex: 99,
                      				animationSpeed: 0,
                      				useSymbol: false,
                      				useWeather: false,
                      				calendarSet: ["IRS"],
                      Here’s all the public calendars for testing. My “Main” calendar is a private google calendar.
                      // First Calendar
                      // Stand in public calendar to protect private data:
                      						url: "https://calendar.google.com/calendar/ical/brendan.keyport%40gmail.com/public/basic.ics",
                      						url: "https://recollect.a.ssl.fastly.net/api/places/BC71002A-F27F-11E8-B5B7-6853A40EAB6C/services/579/events.en-US.ics?client_id=91264B66-7113-11ED-8C28-2101D6C077E5",
                      // Second Calendar
                      						url: "http://cal.events/VReW45.ics",
                      						color: "#69BE28",
                      						url: "https://calendar.google.com/calendar/ical/3vejg64nfe9hk5odcphufgis14%40group.calendar.google.com/private-ae3d986ef6488a425755baf7198a1c99/basic.ics",
                      						color: "#69BE28",
                      						url: "https://calendar.google.com/calendar/ical/mp4efjqgjiq6hphri5ppkkm66k%40group.calendar.google.com/private-81bfdc024de66a7639ac010dfe56263a/basic.ics",
                      						color: "#E8291C",
                      						url: "https://calendar.google.com/calendar/ical/fgl0a1o8duc3quq3mpjlcopk50%40group.calendar.google.com/private-c55f9de420fe504de01c18f263d70fa7/basic.ics",
                      						color: "#69BE28",
                      						url: "https://calendar.google.com/calendar/ical/a6fras24hof5ibrk9q1aeg0igg%40group.calendar.google.com/private-147cebc733aab31784e2ab7f18c13cbc/basic.ics",
                      						color: "#69BE28",
                      						url: "https://gohuskies.com/calendar.ashx/calendar.ics?sport_id=3",
                      						color: "#69BE28",
                      						url: "webcal://calendar.google.com/calendar/ical/d2dba52c05b47583471f0eccbdb79938b9b0d5ef7711298f4c3455fe64ae6ffa%40group.calendar.google.com/public/basic.ics",
                      						color: "#e93b16",
                      						url: "https://calendar.google.com/calendar/ical/en.usa%23holiday%40group.v.calendar.google.com/public/basic.ics",
                      						url: "https://calendar.google.com/calendar/ical/futpub9jb1fisumog0u68s9pdc%40group.calendar.google.com/public/basic.ics",
                      						color: "#FF1493",
                      // Third Calendar
                      						url: "https://calendar.google.com/calendar/ical/ufeoastn72l4rcaact44k3iff3pfcun5%40import.calendar.google.com/public/basic.ics",
                        MMRIZE @BKeyport
                        @BKeyport
                        This is what I’ve got with your config.
                        Is it different with what you want? Tell/Show me what you expected. (AS-IS and TO-BE)
                        • BKeyportB Offline
                          @MMRIZE It seems to be loading everything now, but it’s not refreshing with the calendar app. If I add an event, it misses it until it refreshes at the top of the hour. This includes events going “live” - (bold).
                            sdetweil @BKeyport
                            @BKeyport what is the calendar refresh rate set to ?
                            • BKeyportB Offline
                              			module: "calendar", // Built in
                              				animationSpeed: 0,
                              				broadcastEvents: true,
                              				broadcastPastEvents: true,
                              				fetchInterval: 30000,
                              				maximumEntries: 99,
                                sdetweil @BKeyport
                                @BKeyport said in MMM-CalendarExt3Agenda:
                                30000
                                every 30 seconds?
                                default is 300000 ms, 5 minutes
                                • BKeyportB Offline
                                  @sdetweil did I miss a zero there. Damn. Worked fine until this release of MMM-CX3A, tho.
                                    MMRIZE @BKeyport
                                    @BKeyport
                                    I changed that logic also, because, with some certain circumstances, the disharmony of refresh schedules of each individual calendars and notifications might make too many refreshing/flickering. So I have to change the job.
                                    • BKeyportB Offline
                                      @MMRIZE I see. I need the calendar to update more frequently, which is why I have my animations off normally. More options set. it now works, like it used to.
                                      Thanks!
                                        Studio472
                                        How do I remove the “fade to black” at the bottom of the agenda?
                                          MMRIZE @Studio472
                                          @Studio472
                                          Append this to your custom.css
                                          .CX3A .agenda::after {
                                            display: none;
                                          • BKeyportB Offline
                                            @MMRIZE Boy, we did things the hard way…
                                            /* Fade adjustments */
                                            	position: absolute;
                                            	bottom: 0;
                                            	left: 0;
                                            	height: 6%;
                                            	width: 100%;
                                            	content: '';
                                            	background-image: unset;
                                            • 11
                                            • 12
                                            • 6 / 12
