    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • W
      whimsicality @MMRIZE
      @MMRIZE thank you so much for this! I successfully hid the times with the CSS you gave. But when I input the eventtransformer code, it causes NaN:NaN to show before all the events. Do you have any insight?
      M 1 Reply Last reply
        MMRIZE @whimsicality
        @whimsicality
        Show me what you did.
        W 1 Reply Last reply
        • W
          @MMRIZE
            @whimsicality
            Hmmm. Works for me.
            Maybe your ev.startDate would not be a valid format. (Are you using default calendar module? Or others? - like MMM-GoogleCalendar or something)
            You can check with this code.
            eventTransformer: (ev) => {
            	if (!ev.isFullday) {
            		console.log("Check", ev.title, ev.startDate)
            		let t = new Date(ev.startDate)
            		let time = (t.getMinutes() == 0) ? String(t.getHours()) : String(t.getHours() + ":" + t.getMinutes())
            		ev.title = `<span class="myTime">${time}</span> ${ev.title}`
            	return ev
            It will show additional info in your dev-console.
            • F
              furry131
              Hello Good Sirs,
              I have been banging my head against the wall for 2 days on this and cannot get my calendar to show up with any of the dates. I went back and read a few days back and saw the basic set up you did for fun holidays and tried to replicate it with the same code but I get the same results.
              I can see my default running on the right side like it is supposed to. But the C3 loads on the bottom but doesn’t give any cells. (see screenshot) Just the header. I deleted the Module and reinstalled same thing. So I am assuming it is something to do with my config.
              Any help is appreciated.
              			disabled:false,
              			header: "Furlong Calendar",
              				broadcastPastEvents: true, // <= IMPORTANT to see past events
              				maximumNumberOfDays: 45,
              						symbol: "calendar-check",
              						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
              						color: "rgb(235,20,16)", // <= RECOMMENDED to assign color
                                                              url: "webcal://p132-caldav.icloud.com/published/2/MTYxOTc4Nzc3MTYxOTc4N0UtCeAoDU9jR_G3F17Eh3VRz9FwPUKI9GaiJPDRlUx9w0xueLmCtnzAAks9h8v7F0TiHM6R7cKBwKH_2PXqGZ0",
                                                              //color: "rgb(235,20,16)"
                                                              url: "https://api.playmetrics.com/calendar/304/team/111688-1156AA5E.ics",
                                                              // color: "rgb(235,20,16)"
              	module: "MMM-CalendarExt3",
              	position: "bottom_bar",
              	header: "My Calendar for 3 weeks",
              		mode: 'week',
                sdetweil @furry131
                @furry131 quick test… use the calendar url from the commandline
                change webcal to https in the url
                curl -sL the_url >somefile.ics
                see if it downloads the file… that is effectively all we do… download the file(it is text) and then process it…
                i bet there is an error reported in the place u start MM (npm start)
                F 1 Reply Last reply
                • F
                  furry131 @sdetweil
                  OK I changed the webcal to https and ran the script on my terminal. Nothing happens. I ran this"
                  curl -sL https:://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                  When I run npm start, I can see some errors, but it looks like some calendar events are broadcasting.
                  Ready to go! Please point your browser to: http://0.0.0.0:8080
                  Starting chromium browser now, have patience, it takes a minute
                  [18.08.2023 13:56.23.685] [ERROR] ERROR! Could not validate main module js file.
                  [18.08.2023 13:56.23.688] [ERROR] ReferenceError: HTMLElement is not defined
                      at Object.<anonymous> (/home/johnf/MagicMirror/modules/MMM-CalendarExt3/MMM-CalendarExt3.js:1:26)
                      at Module._compile (node:internal/modules/cjs/loader:1101:14)
                      at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                      at Module.load (node:internal/modules/cjs/loader:981:32)
                      at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                      at Module.require (node:internal/modules/cjs/loader:1005:19)
                      at require (node:internal/modules/cjs/helpers:102:18)
                      at Class.loadModuleDefaultConfig (/home/johnf/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
                      at /home/johnf/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
                      at FSReqCallback.oncomplete (node:fs:199:5)
                  [18.08.2023 13:56.24.068] [ERROR] ERROR! Could not find main module js file for calendars
                  [18.08.2023 13:56.27.820] [LOG]   Create new calendarfetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 3600000
                  [18.08.2023 13:56.27.871] [LOG]   Create new calendarfetcher for url: https://p132-caldav.icloud.com/published/2/MTYxOTc4Nzc3MTYxOTc4N0UtCeAoDU9jR_G3F17Eh3VRz9FwPUKI9GaiJPDRlUx9w0xueLmCtnzAAks9h8v7F0TiHM6R7cKBwKH_2PXqGZ0 - Interval: 3600000
                  [18.08.2023 13:56.27.876] [LOG]   Create new calendarfetcher for url: https://api.playmetrics.com/calendar/304/team/111688-1156AA5E.ics - Interval: 3600000
                  [18.08.2023 13:56.27.939] [INFO]  Checking git for module: MMM-OpenmapWeather
                  [18.08.2023 13:56.27.992] [INFO]  Checking git for module: MMM-CalendarExt3
                  [18.08.2023 13:56.28.009] [INFO]  Checking git for module: MMM-Remote-Control
                  [18.08.2023 13:56.28.043] [INFO]  Checking git for module: MagicMirror
                  [18.08.2023 13:56.28.237] [INFO]  Calendar-Fetcher: Broadcasting 2 events.
                  [18.08.2023 13:56.28.426] [INFO]  Calendar-Fetcher: Broadcasting 31 events.
                  [18.08.2023 13:56.32.357] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                  [18.08.2023 13:56.32.358] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                  [18.08.2023 13:56.32.414] [INFO]  Calendar-Fetcher: Broadcasting 65 events.
                    sdetweil @furry131
                    @furry131 remove the double :: from the url, only one
                    https://
                    • F
                      furry131 @sdetweil
                      Ok that fat finger was part of the download issue!!!
                      I do see it downloading.
                      here is the first date output
                      BEGIN:VCALENDAR
                      VERSION:2.0
                      PRODID:-//Calendar Labs//Calendar 1.0//EN
                      CALSCALE:GREGORIAN
                      METHOD:PUBLISH
                      X-WR-CALNAME:US Holidays
                      X-WR-TIMEZONE:Etc/GMT
                      BEGIN:VEVENT
                      SUMMARY:New Year's Day
                      DTSTART;VALUE=DATE:20230101
                      DTEND;VALUE=DATE:20230101
                      DESCRIPTION:Visit https://calendarlabs.com/holidays/us/new-years-day.php to know more about New Year's Day. \n\n Like us on Facebook: http://fb.com/calendarlabs to get updates
                      UID:6496c24c7c2eb1687601740@calendarlabs.com
                      DTSTAMP:20230624T101540Z
                      STATUS:CONFIRMED
                      TRANSP:TRANSPARENT
                      SEQUENCE:0
                      END:VEVENT
                      BEGIN:VEVENT
                      SUMMARY:New Year's Day Holiday
                      DTSTART;VALUE=DATE:20230102
                      DTEND;VALUE=DATE:20230102
                      DESCRIPTION:Visit https://calendarlabs.com/holidays/us/new-years-day.php to know more about New Year's Day Holiday. \n\n Like us on Facebook: http://fb.com/calendarlabs to get updates
                      UID:6496c24c7c3541687601740@calendarlabs.com
                      STATUS:CONFIRMED
                      TRANSP:TRANSPARENT
                      SEQUENCE:0
                      END:VEVENT
                        sdetweil @furry131
                        @furry131 yeh, no holiday calendar event in the next 10 days, so … nothing of course…
                        try the other calendar urls
                        F 2 Replies Last reply
                        • F
                          furry131 @sdetweil
                          soccer is showing up fine. I see old plus some coming up. The last 3 events are for tomorrow and Sunday.
                          I will post results from my family calendar in another post not to mix up the data.
                          johnf@mm:~/MagicMirror/config $ curl -sL https://api.playmetrics.com/calendar/304/team/111688-1156AA5E.ics
                          BEGIN:VCALENDAR
                          CALSCAL:GREGORIAN
                          METHOD:PUBLISH
                          PRODID:-//Playmetrics//EN
                          VERSION:2.0
                          X-PUBLISHED-TTL:PT1H
                          X-WR-CALDESC:Calendar for the North 14B Select III soccer team
                          X-WR-CALNAME:North 14B Select III
                          X-WR-RELCALID:Team_111688_0@production
                          BEGIN:VEVENT
                          DESCRIPTION:For the first 5-10 minutes with Athletes and Parents. Then a
                           little time just with parents.
                          DTEND:20230727T003000Z
                          DTSTAMP:20230816T212112Z
                          DTSTART:20230727T000000Z
                          LAST-MODIFIED:20230726T152913Z
                          LOCATION:https://us04web.zoom.us/j/78643862130?pwd=a5pgPguIdPvNsxTbU5LfLH
                           allqMLca.1
                          SEQUENCE:1690385353
                          STATUS:CONFIRMED
                          SUMMARY:North 14B Select III - Coach Nando Rapids Kick-Off
                          UID:GenericCalendarEvent_535357
                          URL:https://playmetrics.com
                          END:VEVENT
                          BEGIN:VEVENT
                          DESCRIPTION:Westfield Village Park #4 East 7v7 North Half #4 East 7v7 Nor
                           th Half
                          DTEND:20230808T020000Z
                          DTSTART:20230808T003000Z
                          LAST-MODIFIED:20230731T171050Z
                          SEQUENCE:1690823450
                          STATUS:CONFIRMED
                          SUMMARY:North 14B Select III - Practice
                          UID:Practice_2422486
                          END:VEVENT
                          BEGIN:VEVENT
                           th Half
                          DTEND:20230810T003000Z
                          DTSTART:20230809T230000Z
                          LAST-MODIFIED:20230809T151631Z
                          SEQUENCE:1691594191
                          STATUS:CONFIRMED
                          UID:Practice_2422611
                          END:VEVENT
                          BEGIN:VEVENT
                          DESCRIPTION:Westfield Village Park #4 East 7v7 South Half #4 East 7v7 Sou
                           th Half
                          DTEND:20230811T003000Z
                          DTSTART:20230810T230000Z
                          LAST-MODIFIED:20230809T151738Z
                          SEQUENCE:1691594258
                          STATUS:CONFIRMED
                          UID:Practice_2422701
                          END:VEVENT
                          BEGIN:VEVENT
                          DESCRIPTION:FC 14B Select I @ North 14B Select III\nArrive by 3:29 PM\nGa
                           tes North Soccer Complex 11 A
                          DTEND:20230812T225000Z
                          DTSTART:20230812T220000Z
                          LAST-MODIFIED:00010101T000000Z
                          SEQUENCE:0
                          STATUS:CONFIRMED
                          SUMMARY:North 14B Select III - Game
                          UID:Game_873812
                          END:VEVENT
                          BEGIN:VEVENT
                          DESCRIPTION:North 14B Select III @ CR 14B Select 4\nArrive by 5:29 PM\nGa
                          DTEND:20230813T005000Z
                          DTSTART:20230813T000000Z
                          SEQUENCE:0
                          STATUS:CONFIRMED
                          UID:Game_873811
                          END:VEVENT
                          BEGIN:VEVENT
                           th Half
                          DTEND:20230815T020000Z
                          DTSTART:20230815T003000Z
                          LAST-MODIFIED:20230809T151829Z
                          SEQUENCE:1691594309
                          STATUS:CONFIRMED
                          UID:Practice_2422487
                          END:VEVENT
                          BEGIN:VEVENT
                           th Half
                          DTEND:20230817T003000Z
                          DTSTART:20230816T230000Z
                          LAST-MODIFIED:20230815T154145Z
                          SEQUENCE:1692114105
                          STATUS:CONFIRMED
                          UID:Practice_2422612
                          END:VEVENT
                          BEGIN:VEVENT
                           th Half
                          DTEND:20230818T003000Z
                          DTSTART:20230817T230000Z
                          LAST-MODIFIED:20230814T160030Z
                          SEQUENCE:1692028830
                          STATUS:CONFIRMED
                          UID:Practice_2422702
                          END:VEVENT
                          BEGIN:VEVENT
                          DESCRIPTION:North 14B Select III @ Colorado Rapids Youth Soccer Club CR 1
                           4B Select III (Rapids Classic Game #1)\nArrive by 10:30 AM\nUniform: Whi
                           te Jersey with Black Shorts\nGates North Soccer Complex 9 B
                          DTEND:20230819T190000Z
                          DTSTART:20230819T170000Z
                          SEQUENCE:0
                          STATUS:CONFIRMED
                          UID:Game_871031
                          END:VEVENT
                          BEGIN:VEVENT
                          DESCRIPTION:Colorado Rapids Youth Soccer Club Central 14B Select III @ No
                           rth 14B Select III (Rapids Classic Game #2)\nArrive by 3:30 PM\nUniform:
                            Maroon Jersey with Black Shorts\nGates North Soccer Complex 13B
                          DTEND:20230820T000000Z
                          DTSTART:20230819T220000Z
                          SEQUENCE:0
                          STATUS:CONFIRMED
                          UID:Game_871034
                          END:VEVENT
                          BEGIN:VEVENT
                          DESCRIPTION:Colorado Rapids Youth Soccer Club South 14B Select V @ North
                           14B Select III (Rapids Classic Game #3)\nArrive by 12:30 PM\nUniform: Ma
                          DTEND:20230820T210000Z
                          DTSTART:20230820T190000Z
                          SEQUENCE:0
                          STATUS:CONFIRMED
                          UID:Game_871041
                          END:VEVENT
                          • F
                            furry131 @sdetweil
                            OK here is the ios calendar.
                            I see lots of old stuff on there. but I for certain see something starting on 9/3 and 9/8. So I assume it is pulling the correct calendar down
                            ###the following is from the beginning of the logs###
                            BEGIN:VCALENDAR
                            VERSION:2.0
                            X-WR-CALNAME:Family
                            X-APPLE-CALENDAR-COLOR:#ffcc00
                            ####below here is from further down the log showing an upcoming event
                            BEGIN:VEVENT
                            CREATED:20230816T132451Z
                            DTEND;TZID=America/Denver:20230903T140000
                            DTSTAMP:20230816T132451Z
                            DTSTART;TZID=America/Denver:20230903T100000
                            LAST-MODIFIED:20230816T132451Z
                            LOCATION:Walmart Supercenter\n200 W 136th Ave\, Westminster\, CO  80234\,
                              United States
                            SEQUENCE:0
                            SUMMARY:Scouts popcorn
                            UID:4B479445-47F6-4EE4-B4E4-2E45BE45949E
                            URL;VALUE=URI:
                            X-APPLE-STRUCTURED-LOCATION;VALUE=URI;X-ADDRESS="200 W 136th Ave, Westmin
                             ster, CO  80234, United States";X-APPLE-MAPKIT-HANDLE=CAES7QIIrk0Qm/XnhY
                             +ewPzYARoSCS9szVZe+ENAEZzB3y9mP1rAIqEBCg1Vbml0ZWQgU3RhdGVzEgJVUxoIQ29sb3
                             JhZG8iAkNPKgxBZGFtcyBDb3VudHkyC1dlc3RtaW5zdGVyOgU4MDIzNEIbSW50ZXJjaGFuZ2
                             UgQnVzaW5lc3MgQ2VudGVyUgtXIDEzNnRoIEF2ZVoDMjAwYg8yMDAgVyAxMzZ0aCBBdmWKAR
                             tJbnRlcmNoYW5nZSBCdXNpbmVzcyBDZW50ZXIqE1dhbG1hcnQgU3VwZXJjZW50ZXIyDzIwMC
                             BXIDEzNnRoIEF2ZTIWV2VzdG1pbnN0ZXIsIENPICA4MDIzNDINVW5pdGVkIFN0YXRlczgvUA
                             FaVAolCJv154WPnsD82AESEgkvbM1WXvhDQBGcwd8vZj9awBiuTZADAaIfKgib9eeFj57A/N
                             gBGh0KE1dhbG1hcnQgU3VwZXJjZW50ZXIQACoCZW5AAA==;X-APPLE-RADIUS=298.659415
                             5911811;X-TITLE=Walmart Supercenter:geo:39.940379,-104.990612
                            END:VEVENT
                            BEGIN:VEVENT
                            CREATED:20230816T131714Z
                            DESCRIPTION:Oakhurst Park\n9255 Ammons St.\nWestminster\, CO 80021
                            DTEND;TZID=America/Denver:20230908T184500
                            DTSTAMP:20230816T131929Z
                            DTSTART;TZID=America/Denver:20230908T171500
                            LAST-MODIFIED:20230816T131928Z
                            LOCATION:9255 Ammons Cir\nWestminster\, CO\, United States
                            RELATED-TO;RELTYPE=X-CALENDARSERVER-RECURRENCE-SET:9C8B1CA1-25F8-4DFC-AE4
                             2-ACCA1C4C81FF
                            RRULE:FREQ=WEEKLY;UNTIL=20230929T231500Z
                            SEQUENCE:0
                            SUMMARY:Corvers footwork camp
                            UID:FA306006-B4CD-4781-8228-BD46FDE21ACE
                            URL;VALUE=URI:
                            X-APPLE-STRUCTURED-LOCATION;VALUE=URI;X-ADDRESS="Westminster, CO, United
                             States";X-APPLE-MAPKIT-HANDLE=CAESywEaEgn40spzM/BDQBFxPtBlxUVawCJqCg1Vbm
                             l0ZWQgU3RhdGVzEgJVUxoIQ29sb3JhZG8iAkNPKhBKZWZmZXJzb24gQ291bnR5MgtXZXN0bW
                             luc3RlcjoFODAwMjFSCkFtbW9ucyBDaXJaBDkyNTViDzkyNTUgQW1tb25zIENpcioPOTI1NS
                             BBbW1vbnMgQ2lyMg85MjU1IEFtbW9ucyBDaXIyFldlc3RtaW5zdGVyLCBDTyAgODAwMjEyDV
                             VuaXRlZCBTdGF0ZXNQAQ==;X-APPLE-RADIUS=0;X-APPLE-REFERENCEFRAME=0;X-TITLE
                             =9255 Ammons Cir:geo:39.876570,-105.090173
                            END:VEVENT
                            BEGIN:VEVENT
                              sdetweil @furry131
                              @furry131 9/8 is along way away… maybe ext3 in month view can show that…
                              default stops at 10 days I think. . actually 10 entries
                              maximumEntries: 10,
                              • F
                                furry131 @sdetweil
                                i found something in my IOS for tomorrow. so I would think it is pulling down ok.
                                either way, the soccer one is pulling down current stuff this week.
                                BEGIN:VEVENT
                                CREATED:20230719T035111Z
                                DTEND;VALUE=DATE:20230821
                                DTSTAMP:20230810T232604Z
                                DTSTART;VALUE=DATE:20230819
                                LAST-MODIFIED:20230810T232604Z
                                SEQUENCE:1
                                SUMMARY:Soccer tournament
                                UID:FB687F6C-CA14-4F4D-8AAD-FBB2D21688B2
                                URL;VALUE=URI:
                                END:VEVENT
                                  sdetweil @furry131
                                  @furry131 ok, one does it show on default cal? does default have position set?
                                  does it show in ext3?
                                  • F
                                    furry131 @sdetweil
                                    default calendar shows on the top right. It shows entries from my IOS calendar and my soccer calendar( IOS is “meeting with alice” Soccer is “north 14 B select III”) as positioned on the config.js, (see screen shot below)
                                    it does not show on ext3. All I get is the header.
                                    • F
                                      furry131
                                      OK well this is fun. I was reading again and saw in the instructions about moving back to 1.2.6. SOOOOOO… I decided to give it a hoot. Well, now the calendar is showing up for me.
                                      Not sure what this means.
                                      just thought I would share.
                                      Just need to fix the formatting now.
                                      johnf@mm:~/MagicMirror/modules/MMM-CalendarExt3 $ git checkout snap-1.2.6
                                      Branch 'snap-1.2.6' set up to track remote branch 'snap-1.2.6' from 'origin'.
                                      Switched to a new branch 'snap-1.2.6'
                                        MMRIZE @furry131
                                        @furry131
                                        It might mean;
                                        1. Your module was not properly installed. I think this would be the solution in your case generally.
                                        cd ~/MagicMirror/modules/MMM-CalendarExt3
                                        git checkout main
                                        git pull
                                        npm install
                                        git submodule update --init --recursive
                                        1. Or your MM (Or Chromium/Browser what you are using) is somewhat old, update it.
                                        • F
                                          furry131 @MMRIZE
                                          @MMRIZE
                                          OK thanks. I just ran your suggestions and restarted MM. It is running.
                                          I just installed MM last week and I used sdetweil’s install script. Also just ran the the update script he has. seems to only needing to update Node.js from v16.13.0 to v16.13.1.
                                          Must have been something odd with the install of the module then.
                                          Appreciate everyone’s help.
                                            MMRIZE
                                            UPDATE 1.5.0
                                            Now, the module has a new mode, day; it could show a relatively week-like view. You can adjust the beginning of the seven-day cells from today (or relatively by dayIndex).
                                            G 1 Reply Last reply
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 34
                                            • 35
                                            • 17 / 35
