    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      MMRIZE @pastormingle
      @pastormingle
      Did you test with my example URL or yours?
      I need the real URL of calendar feeds to diagnose. send URLs to my email. (eouia0819@gmail.com)
      P 1 Reply Last reply
        pastormingle @MMRIZE
        @MMRIZE should be in your email box… thanks.
        M 1 Reply Last reply
          @pastormingle replied. From now on, let’s discuss this with email. I’ll leave the summary here later.
            pastormingle @pastormingle
            @pastormingle Seems that when i loaded the outlook.ics it takes it about 10 min loaded when add addiational calendars. I have not errors in the log but it just slow to load when you restart if you have other calendars. What could it be? Do you have a fix for this?
              @pastormingle
              Is fetching slow? Or is drawing slow? Different reason, different solution.
              If fetching is slow; That is not my bad. Adjust interval of fetching calendar in calendar module.
              If drawing is slow(after fetched normally); Adjust waitFetch and refreshInterval. This thing is not “FIX”, just “configuration”
              However more frequent Fetching would give the ics host server more traffic.
              10mins late change, I think it’s sufficiently affordable. Your mirror is not the train time signboard of the station.
                @MMRIZE Not sure which is just doesn’t work till after 10 min passes… If i only put the outlook calendar in it’s instentances. where do you abjust the fetch?
                • W
                  whimsicality @MMRIZE
                  @MMRIZE thank you so much for this! I successfully hid the times with the CSS you gave. But when I input the eventtransformer code, it causes NaN:NaN to show before all the events. Do you have any insight?
                    MMRIZE @whimsicality
                    @whimsicality
                    Show me what you did.
                    W 1 Reply Last reply
                    • W
                      @MMRIZE
                        @whimsicality
                        Hmmm. Works for me.
                        Maybe your ev.startDate would not be a valid format. (Are you using default calendar module? Or others? - like MMM-GoogleCalendar or something)
                        You can check with this code.
                        eventTransformer: (ev) => {
                        	if (!ev.isFullday) {
                        		console.log("Check", ev.title, ev.startDate)
                        		let t = new Date(ev.startDate)
                        		let time = (t.getMinutes() == 0) ? String(t.getHours()) : String(t.getHours() + ":" + t.getMinutes())
                        		ev.title = `<span class="myTime">${time}</span> ${ev.title}`
                        	return ev
                        It will show additional info in your dev-console.
                        • F
                          furry131
                          Hello Good Sirs,
                          I have been banging my head against the wall for 2 days on this and cannot get my calendar to show up with any of the dates. I went back and read a few days back and saw the basic set up you did for fun holidays and tried to replicate it with the same code but I get the same results.
                          I can see my default running on the right side like it is supposed to. But the C3 loads on the bottom but doesn’t give any cells. (see screenshot) Just the header. I deleted the Module and reinstalled same thing. So I am assuming it is something to do with my config.
                          Any help is appreciated.
                          			disabled:false,
                          			header: "Furlong Calendar",
                          				broadcastPastEvents: true, // <= IMPORTANT to see past events
                          				maximumNumberOfDays: 45,
                          						symbol: "calendar-check",
                          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                          						color: "rgb(235,20,16)", // <= RECOMMENDED to assign color
        url: "webcal://p132-caldav.icloud.com/published/2/MTYxOTc4Nzc3MTYxOTc4N0UtCeAoDU9jR_G3F17Eh3VRz9FwPUKI9GaiJPDRlUx9w0xueLmCtnzAAks9h8v7F0TiHM6R7cKBwKH_2PXqGZ0",
        //color: "rgb(235,20,16)"
        url: "https://api.playmetrics.com/calendar/304/team/111688-1156AA5E.ics",
        // color: "rgb(235,20,16)"
                          	module: "MMM-CalendarExt3",
                          	position: "bottom_bar",
                          	header: "My Calendar for 3 weeks",
                          		mode: 'week',
                            sdetweil @furry131
                            @furry131 quick test… use the calendar url from the commandline
                            change webcal to https in the url
                            curl -sL the_url >somefile.ics
                            see if it downloads the file… that is effectively all we do… download the file(it is text) and then process it…
                            i bet there is an error reported in the place u start MM (npm start)
                            F 1 Reply Last reply
                            • F
                              furry131 @sdetweil
                              OK I changed the webcal to https and ran the script on my terminal. Nothing happens. I ran this"
                              curl -sL https:://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                              When I run npm start, I can see some errors, but it looks like some calendar events are broadcasting.
                              Ready to go! Please point your browser to: http://0.0.0.0:8080
                              Starting chromium browser now, have patience, it takes a minute
                              [18.08.2023 13:56.23.685] [ERROR] ERROR! Could not validate main module js file.
                              [18.08.2023 13:56.23.688] [ERROR] ReferenceError: HTMLElement is not defined
                                  at Object.<anonymous> (/home/johnf/MagicMirror/modules/MMM-CalendarExt3/MMM-CalendarExt3.js:1:26)
                                  at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                  at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                  at Module.load (node:internal/modules/cjs/loader:981:32)
                                  at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                  at Module.require (node:internal/modules/cjs/loader:1005:19)
                                  at require (node:internal/modules/cjs/helpers:102:18)
                                  at Class.loadModuleDefaultConfig (/home/johnf/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
                                  at /home/johnf/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
                                  at FSReqCallback.oncomplete (node:fs:199:5)
                              [18.08.2023 13:56.24.068] [ERROR] ERROR! Could not find main module js file for calendars
                              [18.08.2023 13:56.27.820] [LOG]   Create new calendarfetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 3600000
                              [18.08.2023 13:56.27.871] [LOG]   Create new calendarfetcher for url: https://p132-caldav.icloud.com/published/2/MTYxOTc4Nzc3MTYxOTc4N0UtCeAoDU9jR_G3F17Eh3VRz9FwPUKI9GaiJPDRlUx9w0xueLmCtnzAAks9h8v7F0TiHM6R7cKBwKH_2PXqGZ0 - Interval: 3600000
                              [18.08.2023 13:56.27.876] [LOG]   Create new calendarfetcher for url: https://api.playmetrics.com/calendar/304/team/111688-1156AA5E.ics - Interval: 3600000
                              [18.08.2023 13:56.27.939] [INFO]  Checking git for module: MMM-OpenmapWeather
                              [18.08.2023 13:56.27.992] [INFO]  Checking git for module: MMM-CalendarExt3
                              [18.08.2023 13:56.28.009] [INFO]  Checking git for module: MMM-Remote-Control
                              [18.08.2023 13:56.28.043] [INFO]  Checking git for module: MagicMirror
                              [18.08.2023 13:56.28.237] [INFO]  Calendar-Fetcher: Broadcasting 2 events.
                              [18.08.2023 13:56.28.426] [INFO]  Calendar-Fetcher: Broadcasting 31 events.
                              [18.08.2023 13:56.32.357] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                              [18.08.2023 13:56.32.358] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                              [18.08.2023 13:56.32.414] [INFO]  Calendar-Fetcher: Broadcasting 65 events.
                                sdetweil @furry131
                                @furry131 remove the double :: from the url, only one
                                https://
                                • F
                                  furry131 @sdetweil
                                  Ok that fat finger was part of the download issue!!!
                                  I do see it downloading.
                                  here is the first date output
                                  BEGIN:VCALENDAR
                                  VERSION:2.0
                                  PRODID:-//Calendar Labs//Calendar 1.0//EN
                                  CALSCALE:GREGORIAN
                                  METHOD:PUBLISH
                                  X-WR-CALNAME:US Holidays
                                  X-WR-TIMEZONE:Etc/GMT
                                  BEGIN:VEVENT
                                  SUMMARY:New Year's Day
                                  DTSTART;VALUE=DATE:20230101
                                  DTEND;VALUE=DATE:20230101
                                  DESCRIPTION:Visit https://calendarlabs.com/holidays/us/new-years-day.php to know more about New Year's Day. \n\n Like us on Facebook: http://fb.com/calendarlabs to get updates
                                  UID:6496c24c7c2eb1687601740@calendarlabs.com
                                  DTSTAMP:20230624T101540Z
                                  STATUS:CONFIRMED
                                  TRANSP:TRANSPARENT
                                  SEQUENCE:0
                                  END:VEVENT
                                  BEGIN:VEVENT
                                  SUMMARY:New Year's Day Holiday
                                  DTSTART;VALUE=DATE:20230102
                                  DTEND;VALUE=DATE:20230102
                                  DESCRIPTION:Visit https://calendarlabs.com/holidays/us/new-years-day.php to know more about New Year's Day Holiday. \n\n Like us on Facebook: http://fb.com/calendarlabs to get updates
                                  UID:6496c24c7c3541687601740@calendarlabs.com
                                  STATUS:CONFIRMED
                                  TRANSP:TRANSPARENT
                                  SEQUENCE:0
                                  END:VEVENT
                                    sdetweil @furry131
                                    @furry131 yeh, no holiday calendar event in the next 10 days, so … nothing of course…
                                    try the other calendar urls
                                    F 2 Replies Last reply
                                    • F
                                      furry131 @sdetweil
                                      soccer is showing up fine. I see old plus some coming up. The last 3 events are for tomorrow and Sunday.
                                      I will post results from my family calendar in another post not to mix up the data.
                                      johnf@mm:~/MagicMirror/config $ curl -sL https://api.playmetrics.com/calendar/304/team/111688-1156AA5E.ics
                                      BEGIN:VCALENDAR
                                      CALSCAL:GREGORIAN
                                      METHOD:PUBLISH
                                      PRODID:-//Playmetrics//EN
                                      VERSION:2.0
                                      X-PUBLISHED-TTL:PT1H
                                      X-WR-CALDESC:Calendar for the North 14B Select III soccer team
                                      X-WR-CALNAME:North 14B Select III
                                      X-WR-RELCALID:Team_111688_0@production
                                      BEGIN:VEVENT
                                      DESCRIPTION:For the first 5-10 minutes with Athletes and Parents. Then a
                                       little time just with parents.
                                      DTEND:20230727T003000Z
                                      DTSTAMP:20230816T212112Z
                                      DTSTART:20230727T000000Z
                                      LAST-MODIFIED:20230726T152913Z
                                      LOCATION:https://us04web.zoom.us/j/78643862130?pwd=a5pgPguIdPvNsxTbU5LfLH
                                       allqMLca.1
                                      SEQUENCE:1690385353
                                      STATUS:CONFIRMED
                                      SUMMARY:North 14B Select III - Coach Nando Rapids Kick-Off
                                      UID:GenericCalendarEvent_535357
                                      URL:https://playmetrics.com
                                      END:VEVENT
                                      BEGIN:VEVENT
                                      DESCRIPTION:Westfield Village Park #4 East 7v7 North Half #4 East 7v7 Nor
                                       th Half
                                      DTEND:20230808T020000Z
                                      DTSTART:20230808T003000Z
                                      LAST-MODIFIED:20230731T171050Z
                                      SEQUENCE:1690823450
                                      STATUS:CONFIRMED
                                      SUMMARY:North 14B Select III - Practice
                                      UID:Practice_2422486
                                      END:VEVENT
                                      BEGIN:VEVENT
                                       th Half
                                      DTEND:20230810T003000Z
                                      DTSTART:20230809T230000Z
                                      LAST-MODIFIED:20230809T151631Z
                                      SEQUENCE:1691594191
                                      STATUS:CONFIRMED
                                      UID:Practice_2422611
                                      END:VEVENT
                                      BEGIN:VEVENT
                                      DESCRIPTION:Westfield Village Park #4 East 7v7 South Half #4 East 7v7 Sou
                                       th Half
                                      DTEND:20230811T003000Z
                                      DTSTART:20230810T230000Z
                                      LAST-MODIFIED:20230809T151738Z
                                      SEQUENCE:1691594258
                                      STATUS:CONFIRMED
                                      UID:Practice_2422701
                                      END:VEVENT
                                      BEGIN:VEVENT
                                      DESCRIPTION:FC 14B Select I @ North 14B Select III\nArrive by 3:29 PM\nGa
                                       tes North Soccer Complex 11 A
                                      DTEND:20230812T225000Z
                                      DTSTART:20230812T220000Z
                                      LAST-MODIFIED:00010101T000000Z
                                      SEQUENCE:0
                                      STATUS:CONFIRMED
                                      SUMMARY:North 14B Select III - Game
                                      UID:Game_873812
                                      END:VEVENT
                                      BEGIN:VEVENT
                                      DESCRIPTION:North 14B Select III @ CR 14B Select 4\nArrive by 5:29 PM\nGa
                                      DTEND:20230813T005000Z
                                      DTSTART:20230813T000000Z
                                      SEQUENCE:0
                                      STATUS:CONFIRMED
                                      UID:Game_873811
                                      END:VEVENT
                                      BEGIN:VEVENT
                                       th Half
                                      DTEND:20230815T020000Z
                                      DTSTART:20230815T003000Z
                                      LAST-MODIFIED:20230809T151829Z
                                      SEQUENCE:1691594309
                                      STATUS:CONFIRMED
                                      UID:Practice_2422487
                                      END:VEVENT
                                      BEGIN:VEVENT
                                       th Half
                                      DTEND:20230817T003000Z
                                      DTSTART:20230816T230000Z
                                      LAST-MODIFIED:20230815T154145Z
                                      SEQUENCE:1692114105
                                      STATUS:CONFIRMED
                                      UID:Practice_2422612
                                      END:VEVENT
                                      BEGIN:VEVENT
                                       th Half
                                      DTEND:20230818T003000Z
                                      DTSTART:20230817T230000Z
                                      LAST-MODIFIED:20230814T160030Z
                                      SEQUENCE:1692028830
                                      STATUS:CONFIRMED
                                      UID:Practice_2422702
                                      END:VEVENT
                                      BEGIN:VEVENT
                                      DESCRIPTION:North 14B Select III @ Colorado Rapids Youth Soccer Club CR 1
                                       4B Select III (Rapids Classic Game #1)\nArrive by 10:30 AM\nUniform: Whi
                                       te Jersey with Black Shorts\nGates North Soccer Complex 9 B
                                      DTEND:20230819T190000Z
                                      DTSTART:20230819T170000Z
                                      SEQUENCE:0
                                      STATUS:CONFIRMED
                                      UID:Game_871031
                                      END:VEVENT
                                      BEGIN:VEVENT
                                      DESCRIPTION:Colorado Rapids Youth Soccer Club Central 14B Select III @ No
                                       rth 14B Select III (Rapids Classic Game #2)\nArrive by 3:30 PM\nUniform:
                                        Maroon Jersey with Black Shorts\nGates North Soccer Complex 13B
                                      DTEND:20230820T000000Z
                                      DTSTART:20230819T220000Z
                                      SEQUENCE:0
                                      STATUS:CONFIRMED
                                      UID:Game_871034
                                      END:VEVENT
                                      BEGIN:VEVENT
                                      DESCRIPTION:Colorado Rapids Youth Soccer Club South 14B Select V @ North
                                       14B Select III (Rapids Classic Game #3)\nArrive by 12:30 PM\nUniform: Ma
                                      DTEND:20230820T210000Z
                                      DTSTART:20230820T190000Z
                                      SEQUENCE:0
                                      STATUS:CONFIRMED
                                      UID:Game_871041
                                      END:VEVENT
                                      • F
                                        furry131 @sdetweil
                                        OK here is the ios calendar.
                                        I see lots of old stuff on there. but I for certain see something starting on 9/3 and 9/8. So I assume it is pulling the correct calendar down
                                        ###the following is from the beginning of the logs###
                                        BEGIN:VCALENDAR
                                        VERSION:2.0
                                        X-WR-CALNAME:Family
                                        X-APPLE-CALENDAR-COLOR:#ffcc00
                                        ####below here is from further down the log showing an upcoming event
                                        BEGIN:VEVENT
                                        CREATED:20230816T132451Z
                                        DTEND;TZID=America/Denver:20230903T140000
                                        DTSTAMP:20230816T132451Z
                                        DTSTART;TZID=America/Denver:20230903T100000
                                        LAST-MODIFIED:20230816T132451Z
                                        LOCATION:Walmart Supercenter\n200 W 136th Ave\, Westminster\, CO  80234\,
                                          United States
                                        SEQUENCE:0
                                        SUMMARY:Scouts popcorn
                                        UID:4B479445-47F6-4EE4-B4E4-2E45BE45949E
                                        URL;VALUE=URI:
                                        X-APPLE-STRUCTURED-LOCATION;VALUE=URI;X-ADDRESS="200 W 136th Ave, Westmin
                                         ster, CO  80234, United States";X-APPLE-MAPKIT-HANDLE=CAES7QIIrk0Qm/XnhY
                                         +ewPzYARoSCS9szVZe+ENAEZzB3y9mP1rAIqEBCg1Vbml0ZWQgU3RhdGVzEgJVUxoIQ29sb3
                                         JhZG8iAkNPKgxBZGFtcyBDb3VudHkyC1dlc3RtaW5zdGVyOgU4MDIzNEIbSW50ZXJjaGFuZ2
                                         UgQnVzaW5lc3MgQ2VudGVyUgtXIDEzNnRoIEF2ZVoDMjAwYg8yMDAgVyAxMzZ0aCBBdmWKAR
                                         tJbnRlcmNoYW5nZSBCdXNpbmVzcyBDZW50ZXIqE1dhbG1hcnQgU3VwZXJjZW50ZXIyDzIwMC
                                         BXIDEzNnRoIEF2ZTIWV2VzdG1pbnN0ZXIsIENPICA4MDIzNDINVW5pdGVkIFN0YXRlczgvUA
                                         FaVAolCJv154WPnsD82AESEgkvbM1WXvhDQBGcwd8vZj9awBiuTZADAaIfKgib9eeFj57A/N
                                         gBGh0KE1dhbG1hcnQgU3VwZXJjZW50ZXIQACoCZW5AAA==;X-APPLE-RADIUS=298.659415
                                         5911811;X-TITLE=Walmart Supercenter:geo:39.940379,-104.990612
                                        END:VEVENT
                                        BEGIN:VEVENT
                                        CREATED:20230816T131714Z
                                        DESCRIPTION:Oakhurst Park\n9255 Ammons St.\nWestminster\, CO 80021
                                        DTEND;TZID=America/Denver:20230908T184500
                                        DTSTAMP:20230816T131929Z
                                        DTSTART;TZID=America/Denver:20230908T171500
                                        LAST-MODIFIED:20230816T131928Z
                                        LOCATION:9255 Ammons Cir\nWestminster\, CO\, United States
                                        RELATED-TO;RELTYPE=X-CALENDARSERVER-RECURRENCE-SET:9C8B1CA1-25F8-4DFC-AE4
                                         2-ACCA1C4C81FF
                                        RRULE:FREQ=WEEKLY;UNTIL=20230929T231500Z
                                        SEQUENCE:0
                                        SUMMARY:Corvers footwork camp
                                        UID:FA306006-B4CD-4781-8228-BD46FDE21ACE
                                        URL;VALUE=URI:
                                        X-APPLE-STRUCTURED-LOCATION;VALUE=URI;X-ADDRESS="Westminster, CO, United
                                         States";X-APPLE-MAPKIT-HANDLE=CAESywEaEgn40spzM/BDQBFxPtBlxUVawCJqCg1Vbm
                                         l0ZWQgU3RhdGVzEgJVUxoIQ29sb3JhZG8iAkNPKhBKZWZmZXJzb24gQ291bnR5MgtXZXN0bW
                                         luc3RlcjoFODAwMjFSCkFtbW9ucyBDaXJaBDkyNTViDzkyNTUgQW1tb25zIENpcioPOTI1NS
                                         BBbW1vbnMgQ2lyMg85MjU1IEFtbW9ucyBDaXIyFldlc3RtaW5zdGVyLCBDTyAgODAwMjEyDV
                                         VuaXRlZCBTdGF0ZXNQAQ==;X-APPLE-RADIUS=0;X-APPLE-REFERENCEFRAME=0;X-TITLE
                                         =9255 Ammons Cir:geo:39.876570,-105.090173
                                        END:VEVENT
                                        BEGIN:VEVENT
                                          sdetweil @furry131
                                          @furry131 9/8 is along way away… maybe ext3 in month view can show that…
                                          default stops at 10 days I think. . actually 10 entries
                                          maximumEntries: 10,
                                          • F
                                            furry131 @sdetweil
                                            i found something in my IOS for tomorrow. so I would think it is pulling down ok.
                                            either way, the soccer one is pulling down current stuff this week.
                                            BEGIN:VEVENT
                                            CREATED:20230719T035111Z
                                            DTEND;VALUE=DATE:20230821
                                            DTSTAMP:20230810T232604Z
                                            DTSTART;VALUE=DATE:20230819
                                            LAST-MODIFIED:20230810T232604Z
                                            SEQUENCE:1
                                            SUMMARY:Soccer tournament
                                            UID:FB687F6C-CA14-4F4D-8AAD-FBB2D21688B2
                                            URL;VALUE=URI:
                                            END:VEVENT
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 34
                                            • 35
                                            • 17 / 35
