    MMM-CalendarExt3
    689 Posts 82 Posters 3.0m Views 86 Watching
      MMRIZE @pastormingle
      @pastormingle
      	header: "calendar source",
      	position: "top_left", // <-- Remove this line to hide this module.
      		broadcastPastEvents: true,
      		maximumNumberOfDays: 45,
      				symbol: "calendar-check",
      				url: "https://ics.calendarlabs.com/709/45a0bb64/Fun_Holidays.ics",
      				color: "red",
      				symbol: "car-side",
      				url: "webcal://sync.roktcalendar.com/webcal/cb99a33a-87e2-47a6-a11a-69f2eb563101",
      				color: "orange",
      				symbol: "recycle",
      				url: "https://www.kriftel.de/kalender/abfallkalender-2023-bezirk-1-3/events.ics",
      				color: "green",
      I just added additional calendars to the default calendar module.
      It will show;
        pastormingle @MMRIZE
        @MMRIZE Instead of the month i only one week or 7 days at all time displayed. Once the day has passed it should drop off.
          @pastormingle said in MMM-CalendarExt3:
          weeksInView:1 would one-week view of CX3. But what you really want was days view of CX2, and I have dropped that view from CX3 (Because the new CalendarExt3Agenda will get the role alternately, And I think it is better organized and easy to get info.)
          But if you prefer old days view style, just use legacy CX2 instead.
            @MMRIZE When i put in for 3 calendar it’s only displaying the one for google1 account.
            				url:"outlook",
            				color: "red",
            				symbol: "car-side",
            				url:"google1",
            				color: "orange",
            				symbol: "recycle",
            				url:"google2",
            				color: "green",
            	module: "MMM-CalendarExt3",
            	position: "bottom_bar",
            	header: "My Calendar for 3 weeks",
            		mode: 'week',
            M P 2 Replies Last reply Reply Quote 0
              @pastormingle
              Did you test with my example URL or yours?
              I need the real URL of calendar feeds to diagnose. send URLs to my email. (eouia0819@gmail.com)
                @MMRIZE should be in your email box… thanks.
                  @pastormingle replied. From now on, let’s discuss this with email. I’ll leave the summary here later.
                    pastormingle @pastormingle
                    @pastormingle Seems that when i loaded the outlook.ics it takes it about 10 min loaded when add addiational calendars. I have not errors in the log but it just slow to load when you restart if you have other calendars. What could it be? Do you have a fix for this?
                      @pastormingle
                      Is fetching slow? Or is drawing slow? Different reason, different solution.
                      If fetching is slow; That is not my bad. Adjust interval of fetching calendar in calendar module.
                      If drawing is slow(after fetched normally); Adjust waitFetch and refreshInterval. This thing is not “FIX”, just “configuration”
                      However more frequent Fetching would give the ics host server more traffic.
                      10mins late change, I think it’s sufficiently affordable. Your mirror is not the train time signboard of the station.
                        @MMRIZE Not sure which is just doesn’t work till after 10 min passes… If i only put the outlook calendar in it’s instentances. where do you abjust the fetch?
                        • W Offline
                          whimsicality @MMRIZE
                          @MMRIZE thank you so much for this! I successfully hid the times with the CSS you gave. But when I input the eventtransformer code, it causes NaN:NaN to show before all the events. Do you have any insight?
                            MMRIZE @whimsicality
                            @whimsicality
                            Show me what you did.
                            • W Offline
                              @MMRIZE
                                @whimsicality
                                Hmmm. Works for me.
                                Maybe your ev.startDate would not be a valid format. (Are you using default calendar module? Or others? - like MMM-GoogleCalendar or something)
                                You can check with this code.
                                eventTransformer: (ev) => {
                                	if (!ev.isFullday) {
                                		console.log("Check", ev.title, ev.startDate)
                                		let t = new Date(ev.startDate)
                                		let time = (t.getMinutes() == 0) ? String(t.getHours()) : String(t.getHours() + ":" + t.getMinutes())
                                		ev.title = `<span class="myTime">${time}</span> ${ev.title}`
                                	return ev
                                It will show additional info in your dev-console.
                                • F Offline
                                  furry131
                                  Hello Good Sirs,
                                  I have been banging my head against the wall for 2 days on this and cannot get my calendar to show up with any of the dates. I went back and read a few days back and saw the basic set up you did for fun holidays and tried to replicate it with the same code but I get the same results.
                                  I can see my default running on the right side like it is supposed to. But the C3 loads on the bottom but doesn’t give any cells. (see screenshot) Just the header. I deleted the Module and reinstalled same thing. So I am assuming it is something to do with my config.
                                  Any help is appreciated.
                                  			disabled:false,
                                  			header: "Furlong Calendar",
                                  				broadcastPastEvents: true, // <= IMPORTANT to see past events
                                  						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                                  						color: "rgb(235,20,16)", // <= RECOMMENDED to assign color
        url: "webcal://p132-caldav.icloud.com/published/2/MTYxOTc4Nzc3MTYxOTc4N0UtCeAoDU9jR_G3F17Eh3VRz9FwPUKI9GaiJPDRlUx9w0xueLmCtnzAAks9h8v7F0TiHM6R7cKBwKH_2PXqGZ0",
        //color: "rgb(235,20,16)"
        url: "https://api.playmetrics.com/calendar/304/team/111688-1156AA5E.ics",
        // color: "rgb(235,20,16)"
                                  		mode: 'week',
                                    sdetweil @furry131
                                    @furry131 quick test… use the calendar url from the commandline
                                    change webcal to https in the url
                                    curl -sL the_url >somefile.ics
                                    see if it downloads the file… that is effectively all we do… download the file(it is text) and then process it…
                                    i bet there is an error reported in the place u start MM (npm start)
                                    • F Offline
                                      furry131 @sdetweil
                                      OK I changed the webcal to https and ran the script on my terminal. Nothing happens. I ran this"
                                      curl -sL https:://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                                      When I run npm start, I can see some errors, but it looks like some calendar events are broadcasting.
                                      Ready to go! Please point your browser to: http://0.0.0.0:8080
                                      Starting chromium browser now, have patience, it takes a minute
                                      [18.08.2023 13:56.23.685] [ERROR] ERROR! Could not validate main module js file.
                                      [18.08.2023 13:56.23.688] [ERROR] ReferenceError: HTMLElement is not defined
                                          at Object.<anonymous> (/home/johnf/MagicMirror/modules/MMM-CalendarExt3/MMM-CalendarExt3.js:1:26)
                                          at Module._compile (node:internal/modules/cjs/loader:1101:14)
                                          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                                          at Module.load (node:internal/modules/cjs/loader:981:32)
                                          at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                          at Module.require (node:internal/modules/cjs/loader:1005:19)
                                          at require (node:internal/modules/cjs/helpers:102:18)
                                          at Class.loadModuleDefaultConfig (/home/johnf/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
                                          at /home/johnf/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
                                          at FSReqCallback.oncomplete (node:fs:199:5)
                                      [18.08.2023 13:56.24.068] [ERROR] ERROR! Could not find main module js file for calendars
                                      [18.08.2023 13:56.27.820] [LOG]   Create new calendarfetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 3600000
                                      [18.08.2023 13:56.27.871] [LOG]   Create new calendarfetcher for url: https://p132-caldav.icloud.com/published/2/MTYxOTc4Nzc3MTYxOTc4N0UtCeAoDU9jR_G3F17Eh3VRz9FwPUKI9GaiJPDRlUx9w0xueLmCtnzAAks9h8v7F0TiHM6R7cKBwKH_2PXqGZ0 - Interval: 3600000
                                      [18.08.2023 13:56.27.876] [LOG]   Create new calendarfetcher for url: https://api.playmetrics.com/calendar/304/team/111688-1156AA5E.ics - Interval: 3600000
                                      [18.08.2023 13:56.27.939] [INFO]  Checking git for module: MMM-OpenmapWeather
                                      [18.08.2023 13:56.27.992] [INFO]  Checking git for module: MMM-CalendarExt3
                                      [18.08.2023 13:56.28.009] [INFO]  Checking git for module: MMM-Remote-Control
                                      [18.08.2023 13:56.28.043] [INFO]  Checking git for module: MagicMirror
                                      [18.08.2023 13:56.28.237] [INFO]  Calendar-Fetcher: Broadcasting 2 events.
                                      [18.08.2023 13:56.28.426] [INFO]  Calendar-Fetcher: Broadcasting 31 events.
                                      [18.08.2023 13:56.32.357] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                                      [18.08.2023 13:56.32.358] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                                      [18.08.2023 13:56.32.414] [INFO]  Calendar-Fetcher: Broadcasting 65 events.
                                        sdetweil @furry131
                                        @furry131 remove the double :: from the url, only one
                                        https://
                                        • F Offline
                                          furry131 @sdetweil
                                          Ok that fat finger was part of the download issue!!!
                                          I do see it downloading.
                                          here is the first date output
                                          BEGIN:VCALENDAR
                                          VERSION:2.0
                                          PRODID:-//Calendar Labs//Calendar 1.0//EN
                                          CALSCALE:GREGORIAN
                                          METHOD:PUBLISH
                                          X-WR-CALNAME:US Holidays
                                          X-WR-TIMEZONE:Etc/GMT
                                          BEGIN:VEVENT
                                          SUMMARY:New Year's Day
                                          DTSTART;VALUE=DATE:20230101
                                          DTEND;VALUE=DATE:20230101
                                          DESCRIPTION:Visit https://calendarlabs.com/holidays/us/new-years-day.php to know more about New Year's Day. \n\n Like us on Facebook: http://fb.com/calendarlabs to get updates
                                          UID:6496c24c7c2eb1687601740@calendarlabs.com
                                          DTSTAMP:20230624T101540Z
                                          STATUS:CONFIRMED
                                          TRANSP:TRANSPARENT
                                          SEQUENCE:0
                                          END:VEVENT
                                          BEGIN:VEVENT
                                          SUMMARY:New Year's Day Holiday
                                          DTSTART;VALUE=DATE:20230102
                                          DTEND;VALUE=DATE:20230102
                                          DESCRIPTION:Visit https://calendarlabs.com/holidays/us/new-years-day.php to know more about New Year's Day Holiday. \n\n Like us on Facebook: http://fb.com/calendarlabs to get updates
                                          UID:6496c24c7c3541687601740@calendarlabs.com
                                          STATUS:CONFIRMED
                                          TRANSP:TRANSPARENT
                                          SEQUENCE:0
                                          END:VEVENT
                                            sdetweil @furry131
                                            @furry131 yeh, no holiday calendar event in the next 10 days, so … nothing of course…
                                            try the other calendar urls
                                            F 2 Replies Last reply Reply Quote 0
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 34
                                            • 35
                                            • 16 / 35
