    Default calendar is just loading! (Newbie)
    23 Posts 2 Posters 7.0k Views 2 Watching
      sdetweil @Max 0
      @Max-0 the calendar ics parser runs in the node_helper… its messages are output in the npm start window… or if using pm2 to autostart ,
      pm2 logs --lines=100
      you can also add “DEBUG” to the
      in config.js
      because there is so much output, I would do
      pm2 stop all
      npm start >somefile.txt 2>&1
      then after MM starts and no calendar appears… wait 15 secconds
      ctrl-m on the MM window to minimize and press ctrl-c to stop mm.
      the the contents of somefile.txt will give me the info to debug
      send to this same userid at gmail
      don’t post here or in mm issue as there is private data shown in the logs
        Max 0 @sdetweil
          Max 0
          @sdetweil I think I sent an email?
            sdetweil @Max 0
            @Max-0 I do not see any email
              Max 0
              What is the exact gmail?
                sdetweil @Max 0
                @Max-0 what is my username here
                use that at gmail
                .com
                sorry I won’t type it out these pages are scanned
                for seat engines and no chatgpt type ai engines
                  Max 0 @sdetweil
                  @sdetweil I just did that?
                  Is that correct? yes.
                    sdetweil @Max 0
                    @Max-0 but you did not set the debug in config.js first
                    M S 2 Replies Last reply Reply Quote 0
                      Max 0 @sdetweil
                      @sdetweil If you mean to add “DEBUG” in the config list, i did that but i can do it again and send you another mail
                        yes. there should be about 1000 lines of output in the file
