    Default calendar is just loading! (Newbie)
    23 Posts 2 Posters 8.5k Views 2 Watching
      yes. there should be about 1000 lines of output in the file
      M 1 Reply Last reply
        Max 0 @sdetweil
        @sdetweil I’ve definitely set Debug to the log level list, but I’m still getting those same some file.txt lines
          sdetweil @Max 0
          @Max-0 show me the loglevel from config.js, should look line this
          	logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
            Max 0 @sdetweil
              sdetweil @Max 0
              @Max-0 ok, when you run npm start you should see stuff like this
              default US holidy cal, one event
              UG] Event:
              {"type":"VEVENT","params":[],"summary":"Labor Day","start":"2023-09-04T05:00:00.000Z","datetype":"date","end":"2023-09-04T05:00:00.000Z","location":"United States","description":"Visit https://c>
              [24.08.2023 15:01.51.477] [DEBUG] start: Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
              [24.08.2023 15:01.51.477] [DEBUG] end:: Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
              [24.08.2023 15:01.51.477] [DEBUG] duration: 0
              [24.08.2023 15:01.51.477] [DEBUG] title: Labor Day
              [24.08.2023 15:01.51.477] [DEBUG]  if no tz, guess based on now
              [24.08.2023 15:01.51.485] [DEBUG] initial tz=America/Chicago
              [24.08.2023 15:01.51.485] [DEBUG] corrected tz=America/Chicago
              [24.08.2023 15:01.51.485] [DEBUG] start date/time=Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
              [24.08.2023 15:01.51.486] [DEBUG] start offset=-300
              [24.08.2023 15:01.51.486] [DEBUG] start date/time w tz =Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
              [24.08.2023 15:01.51.486] [DEBUG] event date=Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
              [24.08.2023 15:01.51.487] [DEBUG] event offset=-300 hour=0 event date=Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
              [24.08.2023 15:01.51.487] [DEBUG] adjustHours=0
              [24.08.2023 15:01.51.487] [DEBUG] Processing entry...
              [24.08.2023 15:01.51.487] [DEBUG] Event:
                Max 0 @sdetweil
                @sdetweil If you mean this should be in the somefile.txt, I double checked your instructions and did it a few times but I´m getting over and over the same text in the file! But I do not fully understand what you mean by 1 event in the calendar. Also when I check the dev console in the mirror, there are some errors which say "Refused to apply style "/“Error on loading stylesheet: css/custom.css” (Idk if that is important)
                S 2 Replies Last reply
                  sdetweil @Max 0
                  @Max-0 I am just showing 1 event from the debug log
                    sdetweil @Max 0
                    @Max-0 do
                    pm2 stop all
                    npm start >somefile.txt
                      Max 0 @sdetweil
                      @sdetweil without the 2>&1 behind the npm command, I´m getting less information than before! (is it important for the words int he command to be bold?)
                        sdetweil @Max 0
                        @Max-0 no bold in any of my command strings… command prompt doesn’t do bold anyhow…
                        got no idea where u are having trouble. this is the simplest command set ever
                          Max 0
                          I tried to delete and reinstall the whole programm. But now it won´t even start anymore and the last message in the terminal is “MESA-LOADER: failed to retrieve device information”
                            sdetweil @Max 0
                            @Max-0 that is just noise… no impact to MM
                            did you use my install script?
                              Max 0
                              nvm, got it working, but nevertheless thx
