    Default calendar is just loading! (Newbie)
    23 Posts 2 Posters 7.8k Views 2 Watching
      Max 0
      What is the exact gmail?
        sdetweil @Max 0
        @Max-0 what is my username here
        use that at gmail
        .com
        sorry I won’t type it out these pages are scanned
        for seat engines and no chatgpt type ai engines
          Max 0 @sdetweil
          @sdetweil I just did that?
          Is that correct? yes.
            sdetweil @Max 0
            @Max-0 but you did not set the debug in config.js first
            M S 2 Replies Last reply Reply Quote 0
              Max 0 @sdetweil
              @sdetweil If you mean to add “DEBUG” in the config list, i did that but i can do it again and send you another mail
                yes. there should be about 1000 lines of output in the file
                  Max 0 @sdetweil
                  @sdetweil I’ve definitely set Debug to the log level list, but I’m still getting those same some file.txt lines
                    sdetweil @Max 0
                    @Max-0 show me the loglevel from config.js, should look line this
                    	logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
                      Max 0 @sdetweil
                        sdetweil @Max 0
                        @Max-0 ok, when you run npm start you should see stuff like this
                        default US holidy cal, one event
                        UG] Event:
                        {"type":"VEVENT","params":[],"summary":"Labor Day","start":"2023-09-04T05:00:00.000Z","datetype":"date","end":"2023-09-04T05:00:00.000Z","location":"United States","description":"Visit https://c>
                        [24.08.2023 15:01.51.477] [DEBUG] start: Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
                        [24.08.2023 15:01.51.477] [DEBUG] end:: Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
                        [24.08.2023 15:01.51.477] [DEBUG] duration: 0
                        [24.08.2023 15:01.51.477] [DEBUG] title: Labor Day
                        [24.08.2023 15:01.51.477] [DEBUG]  if no tz, guess based on now
                        [24.08.2023 15:01.51.485] [DEBUG] initial tz=America/Chicago
                        [24.08.2023 15:01.51.485] [DEBUG] corrected tz=America/Chicago
                        [24.08.2023 15:01.51.485] [DEBUG] start date/time=Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
                        [24.08.2023 15:01.51.486] [DEBUG] start offset=-300
                        [24.08.2023 15:01.51.486] [DEBUG] start date/time w tz =Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
                        [24.08.2023 15:01.51.486] [DEBUG] event date=Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
                        [24.08.2023 15:01.51.487] [DEBUG] event offset=-300 hour=0 event date=Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
                        [24.08.2023 15:01.51.487] [DEBUG] adjustHours=0
                        [24.08.2023 15:01.51.487] [DEBUG] Processing entry...
                        [24.08.2023 15:01.51.487] [DEBUG] Event:
                          Max 0 @sdetweil
                          @sdetweil If you mean this should be in the somefile.txt, I double checked your instructions and did it a few times but I´m getting over and over the same text in the file! But I do not fully understand what you mean by 1 event in the calendar. Also when I check the dev console in the mirror, there are some errors which say "Refused to apply style "/“Error on loading stylesheet: css/custom.css” (Idk if that is important)
                            sdetweil @Max 0
                            @Max-0 I am just showing 1 event from the debug log
                              sdetweil @Max 0
                              @Max-0 do
                              pm2 stop all
                              npm start >somefile.txt
                                Max 0 @sdetweil
                                @sdetweil without the 2>&1 behind the npm command, I´m getting less information than before! (is it important for the words int he command to be bold?)
                                  sdetweil @Max 0
                                  @Max-0 no bold in any of my command strings… command prompt doesn’t do bold anyhow…
                                  got no idea where u are having trouble. this is the simplest command set ever
                                    Max 0
                                    I tried to delete and reinstall the whole programm. But now it won´t even start anymore and the last message in the terminal is “MESA-LOADER: failed to retrieve device information”
                                      sdetweil @Max 0
                                      @Max-0 that is just noise… no impact to MM
                                      did you use my install script?
                                        Max 0
                                        nvm, got it working, but nevertheless thx
