    MMM-Notion
    modulenot working
    5 Posts 2 Posters 1.4k Views 2 Watching
      Max 0
      I´ve downloaded the MMM-Notion Module and when i start the mirror it just says: Could not find database with ID: (my id). Make sure the relevant pages and databases are shared with your integration. So here are my question: Do I have to add the integration to the page and the database? (the id is correct and the secret key as well). And in the config it says under databases.layout.properties :“Required List of Properties, which will displayed on the view. Please use the exact name like in Notion. If leaving empty, there will be no properties visible” and i don´t know what that means
        sdetweil @Max 0
        @Max-0 did you do all the steps in the how to use section of the doc ?
        https://github.com/choffmann/MMM-Notion#how-to-use
          Max 0 @sdetweil
          @sdetweil yes but when i create an integration i can´t select the capibilities
            Max 0
            now i´ve tried different database ids and now, instead of an the error, there is an error showing up for only half a second when the module refreshes itself every minute which says: TypeError:Cannot read properties of undefined (reading ‘type’)
              sdetweil @Max 0
              @Max-0 I think you should post an issue on the module GitHub page to engage the module author
