    MMM-Fitbit2 Install Process
    15 Posts 3 Posters 5.2k Views 3 Watching
    • E Offline
      En-TACT
      I’m new to Magic Mirror and module installs therefore, I am stumped on next step to install dependencies for MMM-Fitbit2. I’m in the directory MagicMirror/modules/MMM-Fitbit2 and ran the command ./init.sh, however, I received this error: npm ERR! must provide string spec
      S V 2 Replies Last reply Reply Quote 0
      • V Offline
        Vizulize Module Developer @En-TACT
        @En-TACT Check that you have the correct client ID, client secret, and the redirect URI.
          sdetweil @En-TACT
          @En-TACT I think you will have to open an issue on the module GitHub page to engage the author to help fix this
          • V Offline
            @En-TACT init.sh just runs npm install (ref), so you can try the various StackOverflow suggestions to see if they help.
            • E Offline
              En-TACT @Vizulize
              @Vizulize, thank you for that support page! The following commands worked for me to install dependencies:
              sudo npm i -g npm-check-updates
              sudo npm init
              sudo npm install
              sudo ./init.sh
              Now, I’m stuck on the authorization step. After entering ./auth.sh, it idles after I enter my client ID and clientSecret -supposed to open a browser and create the python/tokens-.json file.
              Would love to have this running, but I think this module needs attention. I’ll reach out again to the author.
              V S 2 Replies Last reply Reply Quote 0
              • V Offline
                @En-TACT I am the author. What is your setup? Are you trying to run it headlessly?
                  sdetweil @En-TACT
                  @En-TACT you should not use sudo except for the first line where you were updating the global NPM version everything else should have been without sudo.
                  using sudo marks all the files as owned by root not by the user and that causes execution problems, has magic mirror runs under the users permission not root.
                  • E Offline
                    En-TACT @Vizulize
                    @Vizulize , I’m on authorization step. After I enter ./auth.sh via terminal, it prompts me for clientID and clientSecret. I can see the alpha-numeric characters I typed for clientID, but not for clientSecret. The cursor just sits there … is this intended? After I press enter, it does not open a browser.
                    Also, no python/tokens-.json file was creadted. Therefore my Fitbit module is only showing “Loading”.
                    My setup:
                    • Raspberry Pi 3 B+ v1.2
                    • USB Keyboard
                    • Wireless Mouse
                    • Raspbian Linux 11 (bullseye)
                    Thanks!
                    • E Offline
                      En-TACT @sdetweil
                      @sdetweil, should I repeat those steps again with first line sudo? Or, should I remove MMM-Fitbit module and start anew?
                      Just to be thorough to repeat the steps, I would run:
                      npm init
                      npm install
                      ./init.sh
                        sdetweil @En-TACT
                        @En-TACT The first step is done No need to fix that.
                        you should not do the NPM init at all
                        as it will overwrite the package.json the author provided
                        The other two steps depend on Python3 and I don’t know if the system you’re using has Python3 installed properly yet. The raspberry pi does not come with python3 installed by default
                        • E Offline
                          En-TACT @sdetweil
                          @sdetweil I ran the command, python --version. Returned Python 3.9.2.
                          Does that suffice, or is there something I can run to check python is properly installed?
                            sdetweil @En-TACT
                            @En-TACT The script runs python3 not python
                            • E Offline
                              En-TACT @sdetweil
                              @sdetweil I got a bit further than before after entering my authorization credentials … the Chrome browser eventually opened, logon Fitbit site, and selected all options. However, after I clicked accept, received this browser error message:
                              500 Internal Server Error
                              The server encountered an unexpected condition which prevented it from fulfilling the request.
                              File “/home/pi/.local/lib/python3.9/site-packages/cherrypy/_cprequest.py”, line 638, in respond
                              self._do_respond(path_info)
                              File “/home/pi/.local/lib/python3.9/site-packages/cherrypy/_cprequest.py”, line 697, in _do_respond
                              response.body = self.handler()
                              File “/home/pi/.local/lib/python3.9/site-packages/cherrypy/lib/encoding.py”, line 223, in call
                              self.body = self.oldhandler(*args, **kwargs)
                              File “/home/pi/.local/lib/python3.9/site-packages/cherrypy/_cpdispatch.py”, line 54, in call
                              return self.callable(*self.args, **self.kwargs)
                              File “/home/pi/MagicMirror/modules/MMM-Fitbit2/python/setup_access.py”, line 58, in index
                              self.oauth.fetch_access_token(code, self.redirect_uri)
                              File “/home/pi/.local/lib/python3.9/site-packages/fitbit/api.py”, line 142, in fetch_access_token
                              return self.session.fetch_token(
                              File “/usr/lib/python3/dist-packages/requests_oauthlib/oauth2_session.py”, line 244, in fetch_token
                              self._client.parse_request_body_response(r.text, scope=self.scope)
                              File “/usr/lib/python3/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py”, line 421, in parse_request_body_response
                              self.token = parse_token_response(body, scope=scope)
                              File “/usr/lib/python3/dist-packages/oauthlib/oauth2/rfc6749/parameters.py”, line 431, in parse_token_response
                              validate_token_parameters(params)
                              File “/usr/lib/python3/dist-packages/oauthlib/oauth2/rfc6749/parameters.py”, line 438, in validate_token_parameters
                              raise_from_error(params.get(‘error’), params)
                              File “/usr/lib/python3/dist-packages/oauthlib/oauth2/rfc6749/errors.py”, line 405, in raise_from_error
                              raise cls(**kwargs)
                              oauthlib.oauth2.rfc6749.errors.InvalidClientError: (invalid_client)
                                sdetweil @En-TACT
                                @En-TACT I do not know this part of the app process. sorry… the author will have to help here
                                • V Offline
                                  • E Offline
                                    En-TACT @Vizulize
                                    @Vizulize this module is working on my mirror, thank you!
