    MMM-Fitbit2 Install Process
    15 Posts 3 Posters 4.8k Views 3 Watching
    • E Offline
      En-TACT @Vizulize
      @Vizulize, thank you for that support page! The following commands worked for me to install dependencies:
      sudo npm i -g npm-check-updates
      sudo npm init
      sudo npm install
      sudo ./init.sh
      Now, I’m stuck on the authorization step. After entering ./auth.sh, it idles after I enter my client ID and clientSecret -supposed to open a browser and create the python/tokens-.json file.
      Would love to have this running, but I think this module needs attention. I’ll reach out again to the author.
      V S 2 Replies Last reply Reply Quote 0
      • V Offline
        Vizulize Module Developer @En-TACT
        @En-TACT I am the author. What is your setup? Are you trying to run it headlessly?
          sdetweil @En-TACT
          @En-TACT you should not use sudo except for the first line where you were updating the global NPM version everything else should have been without sudo.
          using sudo marks all the files as owned by root not by the user and that causes execution problems, has magic mirror runs under the users permission not root.
          • E Offline
            En-TACT @Vizulize
            @Vizulize , I’m on authorization step. After I enter ./auth.sh via terminal, it prompts me for clientID and clientSecret. I can see the alpha-numeric characters I typed for clientID, but not for clientSecret. The cursor just sits there … is this intended? After I press enter, it does not open a browser.
            Also, no python/tokens-.json file was creadted. Therefore my Fitbit module is only showing “Loading”.
            My setup:
            • Raspberry Pi 3 B+ v1.2
            • USB Keyboard
            • Wireless Mouse
            • Raspbian Linux 11 (bullseye)
            Thanks!
            • E Offline
              En-TACT @sdetweil
              @sdetweil, should I repeat those steps again with first line sudo? Or, should I remove MMM-Fitbit module and start anew?
              Just to be thorough to repeat the steps, I would run:
              npm init
              npm install
              ./init.sh
                sdetweil @En-TACT
                @En-TACT The first step is done No need to fix that.
                you should not do the NPM init at all
                as it will overwrite the package.json the author provided
                The other two steps depend on Python3 and I don’t know if the system you’re using has Python3 installed properly yet. The raspberry pi does not come with python3 installed by default
                • E Offline
                  En-TACT @sdetweil
                  @sdetweil I ran the command, python --version. Returned Python 3.9.2.
                  Does that suffice, or is there something I can run to check python is properly installed?
                    sdetweil @En-TACT
                    @En-TACT The script runs python3 not python
                    • E Offline
                      En-TACT @sdetweil
                      @sdetweil I got a bit further than before after entering my authorization credentials … the Chrome browser eventually opened, logon Fitbit site, and selected all options. However, after I clicked accept, received this browser error message:
                      500 Internal Server Error
                      The server encountered an unexpected condition which prevented it from fulfilling the request.
                      File “/home/pi/.local/lib/python3.9/site-packages/cherrypy/_cprequest.py”, line 638, in respond
                      self._do_respond(path_info)
                      File “/home/pi/.local/lib/python3.9/site-packages/cherrypy/_cprequest.py”, line 697, in _do_respond
                      response.body = self.handler()
                      File “/home/pi/.local/lib/python3.9/site-packages/cherrypy/lib/encoding.py”, line 223, in call
                      self.body = self.oldhandler(*args, **kwargs)
                      File “/home/pi/.local/lib/python3.9/site-packages/cherrypy/_cpdispatch.py”, line 54, in call
                      return self.callable(*self.args, **self.kwargs)
                      File “/home/pi/MagicMirror/modules/MMM-Fitbit2/python/setup_access.py”, line 58, in index
                      self.oauth.fetch_access_token(code, self.redirect_uri)
                      File “/home/pi/.local/lib/python3.9/site-packages/fitbit/api.py”, line 142, in fetch_access_token
                      return self.session.fetch_token(
                      File “/usr/lib/python3/dist-packages/requests_oauthlib/oauth2_session.py”, line 244, in fetch_token
                      self._client.parse_request_body_response(r.text, scope=self.scope)
                      File “/usr/lib/python3/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py”, line 421, in parse_request_body_response
                      self.token = parse_token_response(body, scope=scope)
                      File “/usr/lib/python3/dist-packages/oauthlib/oauth2/rfc6749/parameters.py”, line 431, in parse_token_response
                      validate_token_parameters(params)
                      File “/usr/lib/python3/dist-packages/oauthlib/oauth2/rfc6749/parameters.py”, line 438, in validate_token_parameters
                      raise_from_error(params.get(‘error’), params)
                      File “/usr/lib/python3/dist-packages/oauthlib/oauth2/rfc6749/errors.py”, line 405, in raise_from_error
                      raise cls(**kwargs)
                      oauthlib.oauth2.rfc6749.errors.InvalidClientError: (invalid_client)
                      S V 2 Replies Last reply Reply Quote 0
                        sdetweil @En-TACT
                        @En-TACT I do not know this part of the app process. sorry… the author will have to help here
