    Hourly weather showing up as undefined location
    14 Posts 3 Posters 4.5k Views 3 Watching
      jimmy_382837
      I am trying to get both the daily and the hourly forecast to show up via the default weather module. The daily works fine, but the hourly shows up as undefined. Any thoughts? Screen shots and config pasted below.
      I tried the lat / lon with and without quotes and with single quotes, and I get the same undefined result each time.
      I am using the same API key for both, if that makes a difference.
      	module: "weather",
      	header: "Daily Weather Forecast",
      		type: "forecast",
      		locationID: "XXX",
      		apiKey: "XXX",
      		roundTemp: true,
      		maxNumberOfDays: 8,
      		appendLocationNameToHeader: false,
      		fade: false
      	module: "weather",
      	header: "Hourly Weather Forecast",
      		weatherEndpoint: "/onecall",
      		type: "hourly",
      		lat: "XX.XXXX",
      		lon: "-XX.XXXX",
      		apiKey: "XXX",
      		initialLoadDelay: 5000,
      		maxEntries: 12,
      		roundTemp: true,
      		fade: false
        jimmy_382837 @sdetweil
        @sdetweil ah yes, i had to subscribe to the one call 3.0 api and then wait about a half an hour for my api to update. now it works - thanks for helping me troubleshoot!
          sdetweil @jimmy_382837
          @jimmy_382837 true/false and numbers do not use quotes.
          so your lat/long values are wrong
            @sdetweil thank you for the reply - however, when i try to take the quotes out, i still get the undefined issue. any other things i should try?
            	module: "weather",
            		type: "hourly",
            		lat: XX.XXX,
            		lon: -XX.XXX,
            		apiKey: "XXX",
            		maxEntries: 12,
            		roundTemp: true,
            		fade: false
            rejasR 1 Reply Last reply Reply Quote 0
            • rejasR Offline
              rejas Module Developer @jimmy_382837
              @jimmy_382837 Can not reproduce it. What lat/lon and locationID are you using?
                sdetweil @rejas
                @rejas he doesn’t have a locationID specified
                • rejasR Offline
                  rejas Module Developer @sdetweil
                  @sdetweil In his first psot he has, just wanted to make sure I get the whole config related to weather.
                    jimmy_382837 @rejas
                    @rejas this is my exact config with the lat / lon below, minus the api key. i pulled the lat / lon off of openweathermap.org’s search for austin, us.
                    i didn’t include the locationID, given i thought the module ignored it when on hourly mode.
                    	module: "weather",
                    		type: "hourly",
                    		lat: 30.267,
                    		lon: -97.743,
                    		apiKey: "xxxxxxxxxx",
                    		maxEntries: 12,
                    		roundTemp: true,
                    		fade: false
                      @jimmy_382837 openweathermap requires a location or locationID value
                      see the note on the location property
                        @sdetweil thanks - and sorry this is a pain and probably stupid user error on my part, but even when i put in a locationID, it still gives me the undefined error.
                        			module: "weather",
                        				type: "hourly",
                        				lat: 30.267,
                        				lon: -97.743,
                        				locationID: 4671654,
                        				apiKey: "xxxxxxx",
                        				maxEntries: 12,
                        				roundTemp: true,
                        				fade: false
                          @jimmy_382837 ok, looking thru the doc, as u picked hourly and and /onecall then locationID is not used…
                          so, I would try to make the lat/lon more specific with additional decimal places. the example shows 4, u only have 3. all my code using the onecall api uses 6
