    Problem installing new module (beginner), CalendarEXT3 not displaying
    36 Posts 4 Posters 15.4k Views 4 Watching
      Manino @sdetweil
      @sdetweil What? The screen still look the same. September then a line. I have added all my calendars now but can’t view them in the month calendar. No errror.
      			broadcastPastEvents: true, // <= IMPORTANT to see past events
      					url: "https://calendar.google.com/calendar/xxxxxxxx",
      					name: "Familj", // <= RECOMMEND to assign name
      					color: "red", // <= RECOMMEND to assign color
      					name: "Jobb", // <= RECOMMEND to assign name
      					url: "https://calendar.google.com/calendar/xxxxx",
      					name: "Lila kalender", // <= RECOMMEND to assign name
         module: "MMM-CalendarExt3",
         position: "lower_third",
         title: "",
             mode: "month",
       /* instanceId: "basicCalendar", */
            locale: 'sv-SE',
            maxEventLines: 5,
            firstDayOfWeek: 1,
           calendarSet: ['Familj', 'Jobb', 'Lila kalender'],
        sdetweil @Manino
        @Manino do you see all the events from the calendars in the default calendar?
        i am not the EXT3 author…
        I start with no calendarsets in ext3
        I used this and it works
          position: "bottom_bar",
          title: "",
            mode: "month",
            maxEventLines: 5,
            firstDayOfWeek: 1,
            calendarSet: [],
        M 1 Reply Last reply
          Manino @sdetweil
          @sdetweil thanks for your printscreen and your time. As what I can see, I have exactly the same config when it comes to the EXT3. Including the open/close brace. (Did’nt copy paste them last time). And now for my picture i did exactly as you.
          When I have bottom_bar the EXT3 also almost drowning. How can it be so different. Can you see something?
            sdetweil @Manino
            @Manino I do not know @MMRIZE can u help?
            M M 2 Replies Last reply
              Manino @sdetweil
              @sdetweil Thanks for trying, I really appreciate it!
                MMRIZE @sdetweil
                @sdetweil @Manino
                Maybe your 3 calendars might have tons of events(at least 10) since long long ago time(at least 1 year).
                Past events might be too many, so all of the quota for broadcasting was already consumed by the older events.
                To test it, remove 3 calendars, try ‘us-holiday’ calendar of the default config example.
                If so, check maximumNumberOfDays and maximumEntries of the default calendar module.
                I think it is not the bug of that module but unexpected behaviour. Generally, for past events, People will regard newer events than older events as more important. But broadcasting of this calendar module contains older events prior to newer ones.
                S M 2 Replies Last reply
                  sdetweil @MMRIZE
                  @MMRIZE said in Problem installing new module (beginner), CalendarEXT3 not displaying:
                  but you could walk from end of list back to before today, and now know forward looking and past looking… keep going back to the start date of the calendar view … this is what I do with a port of your code to another platform…
                    Manino @MMRIZE
                    @MMRIZE bad news, all my calendars are new. No old event. I’m an apple user and usually not use google calendar at all. :(
                      MMRIZE @Manino
                      @Manino
                      But your picture above post shows you have Google Calendar. Could you send me the real URLs of icals? eouia0819@gmail.com
                      To represent your symptom, I need real data.
                      AFAIK, without proper maximumNumberOfDays and maximumEntries values, the bunch of broadcasting will be filled with prior events first up to maximumEntries. So the casted payload will not contain recent newer ones.
                      Is something changed in default calendar?
                        Manino @MMRIZE
                        @MMRIZE You got mail! Yes, I do have Google Calendar. And it’s all brand new for me. No old event.
                          MMRIZE @Manino
                          @Manino
                          I tested URL you sent me. (Green is that one. I hope this will not be too privacy things.)
                              mode: 'month',
                              locale: 'sv-SE',
                                  symbol: "calendar-check",
                                  url: "https://ics.calendarlabs.com/709/45a0bb64/Fun_Holidays.ics",
                                  color: "red",
                                  url: "https://calendar.google.com/calendar/ical/7a9...4/basic.ics", // <- Your real iCAL URL
                                  color: "green",
                            Manino @MMRIZE
                            @MMRIZE No pivacy things, its ok thank you.
                            Glad to see it works for you, in that way there is’nt anything wrong with my google calendar. I appreciate you took your time and look it up!
                            I did copy paste your config into mine and sorry to say but it did’nt work. Then i get back to my own config again but that does’nt work either.
                            You can see I get the calendar into the default one. But the month is all empty. And I have to choose “lower_third” becuase on “bottom_bar” september is drowning, I can hardly see it then. Something is really wrong. Maybe I have to start from the beginning again. I mean, it works for you so something is really wrong over here.
                              Manino @MMRIZE
                              @MMRIZE this one is from an all brand new installation of the MM and EXT3. I did end the installation with the ”npm install”. Copy paste your config into mine and got this. I’am clearly doing something wrong but I can’t undestand what to do different.
                                MMRIZE @Manino
                                @Manino
                                Let’s test things.
                                1. Remove all other modules except calendar and MMM-CalendarExt3 then run again.
                                  1-1) If no issue; Some of other modules might make interference.
                                  1-2) Still happens; Run MM as dev mode (npm run start:dev) => This will show front-end dev console and there might be some useful console log. (or you can populate dev-console on MM with Ctrl+Shift+i or equivalent shortcut keys by your system)
                                2. Just in case, the first rendering takes time so wait a while after running it.
                                  Manino @MMRIZE
                                  @MMRIZE Can you see something? I takes time for my posts to be accepted but now I have an all band new installation of the MM and the EXT3.
                                  I did comment out(?) all the default models except the calendar. Correct? Still got the same view as above (my latest post), except the clock and date.
                                  manino@raspberrypi:~ $ cd MagicMirror
                                  manino@raspberrypi:~/MagicMirror $ npm run start:dev
                                  magicmirror@2.24.0 start:dev
                                  DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js dev
                                  [22.09.2023 09:26.03.030] [LOG] Starting MagicMirror: v2.24.0
                                  [22.09.2023 09:26.03.044] [LOG] Loading config …
                                  [22.09.2023 09:26.03.053] [DEBUG] config template file not exists, no envsubst
                                  [22.09.2023 09:26.03.067] [LOG] Loading module helpers …
                                  [22.09.2023 09:26.03.070] [LOG] No helper found for module: MMM-CalendarExt3.
                                  [22.09.2023 09:26.03.620] [LOG] Initializing new module helper …
                                  [22.09.2023 09:26.03.621] [LOG] Module helper loaded: calendar
                                  [22.09.2023 09:26.03.622] [LOG] All module helpers loaded.
                                  [22.09.2023 09:26.03.640] [LOG] Starting server on port 8080 …
                                  [22.09.2023 09:26.04.084] [ERROR] Whoops! There was an uncaught exception…
                                  [22.09.2023 09:26.04.097] [ERROR] Error: listen EADDRINUSE: address already in use ::1:8080
                                  at Server.setupListenHandle [as _listen2] (node:net:1740:16)
                                  at listenInCluster (node:net:1788:12)
                                  at GetAddrInfoReqWrap.doListen [as callback] (node:net:1937:7)
                                  at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:110:8) {
                                  code: ‘EADDRINUSE’,
                                  errno: -98,
                                  syscall: ‘listen’,
                                  address: ‘::1’,
                                  port: 8080
                                  [22.09.2023 09:26.04.098] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  [22.09.2023 09:26.04.098] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                  MESA-LOADER: failed to retrieve device information
                                    MMRIZE @Manino
                                    @Manino
                                    You need to stop “pm2” first before try dev mode. This error means just you are executing mm twice(one from pm2 and one from npm run start:dev). That error is not related with your original issue.
                                      sdetweil @MMRIZE
                                      @MMRIZE @Manino do
                                      pm2 stop all
                                      then u can do
                                      npm start
                                      (ctrl-c to stop)
                                      to test
                                        Manino @MMRIZE
                                        @MMRIZE @sdetweil Oh, tnx! This is what I got. Have no idea if this is correct either. Thanks for your patience.
                                        manino@raspberrypi:~/MagicMirror $ pm2 stop all
                                        [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                                        [PM2] [MagicMirror](0) ✓
                                        │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                        │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                                        manino@raspberrypi:~/MagicMirror $ npm start
                                        [22.09.2023 21:59.20.958] [LOG]   Starting MagicMirror: v2.24.0
                                        [22.09.2023 21:59.20.971] [LOG]   Loading config ...
                                        [22.09.2023 21:59.20.980] [DEBUG] config template file not exists, no envsubst
                                        [22.09.2023 21:59.20.989] [LOG]   Loading module helpers ...
                                        [22.09.2023 21:59.20.997] [LOG]   No helper found for module: MMM-CalendarExt3.
                                        [22.09.2023 21:59.21.413] [LOG]   Initializing new module helper ...
                                        [22.09.2023 21:59.21.414] [LOG]   Module helper loaded: calendar
                                        [22.09.2023 21:59.21.415] [LOG]   All module helpers loaded.
                                        [22.09.2023 21:59.21.436] [LOG]   Starting server on port 8080 ...
                                        [22.09.2023 21:59.21.866] [LOG]   Server started ...
                                        [22.09.2023 21:59.21.869] [LOG]   Connecting socket for: calendar
                                        [22.09.2023 21:59.21.870] [LOG]   Starting node helper for: calendar
                                        [22.09.2023 21:59.21.872] [LOG]   Sockets connected & modules started ...
                                        [22.09.2023 21:59.21.950] [LOG]   Launching application.
                                        ../../buildtools/third_party/libc++/trunk/include/vector:1471: assertion __n < size() failed: vector[] index out of bounds[1602:0922/215923.760165:ERROR:gpu_process_host.cc(954)] GPU process exited unexpectedly: exit_code=6
                                        ../../buildtools/third_party/libc++/trunk/include/vector:1471: assertion __n < size() failed: vector[] index out of bounds[1602:0922/215924.743937:ERROR:gpu_process_host.cc(954)] GPU process exited unexpectedly: exit_code=6
                                        ../../buildtools/third_party/libc++/trunk/include/vector:1471: assertion __n < size() failed: vector[] index out of bounds[1602:0922/215925.960665:ERROR:gpu_process_host.cc(954)] GPU process exited unexpectedly: exit_code=6
                                        [22.09.2023 21:59.25.999] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/709/45a0bb64/Fun_Holidays.ics - Interval: 3600000
                                        [22.09.2023 21:59.26.871] [INFO]  Calendar-Fetcher: Broadcasting 59 events.
                                        [1645:0922/215926.898550:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                                        ^C/home/manino/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                                        S 2 Replies Last reply
                                          sdetweil @Manino
                                          @Manino
                                          ‘/home/manino/package.json’
                                          you are not in the MagicMirror folder
                                          cd MagicMirror
                                            sdetweil @Manino
                                            @Manino do this
                                            export ELECTRON_DISABLE_GPU=1
                                            npm start
                                            if that works, the add
                                            in the ~/MagicMirror/installers/mm.sh
                                            on a new line before the line with npm start
