    2 modules side by side
    9 Posts 5 Posters 2.7k Views 6 Watching
    • G Offline
      GodSmackedOrange
      Hey All,
      I have searched the forum and follow as many instructions as I could but I could not get any to work,
      My family command center is almost done, I am a complete novice to CSS and HTML so please help me as if I were an alien,
      I have both MMM-GoogleTrafficTimes and MMM-AnyList in the “top_center” position however I’d like, if possible, to left align MMM-GoogleTrafficTimes and right align MMM-AnyList, no matter what I do they stacked vertically, all the changes I have done from forum search so far just made them take up more space or less but still vertically stacked,
      Any and all help appreciated please
      • G Offline
        GodSmackedOrange @sdetweil
        @sdetweil @MMRIZE
        Got it guys,
        So I have MMM-GoogleTravelTimes and 3x MMM-AnyLists all in the top_center,
        I used the following code from MMRIZE and added a margin to creating padding between modules, code below -
        .region.top.center .container .module {
        float: left;
        max-width: 32%;
        margin: 0 50px;
        Thanks guys!!
          sdetweil @GodSmackedOrange
          @GodSmackedOrange I just replied to your post in discord about the same topic.
          there’s no configuration way to do this You may be able to do it with CSS by changing the layout of the region the modules are in top center to display: flex, flexdirection:leftright
          you can try this In the developers window by pressing ctrl- alt-i on the magicmirror keyboard
          and selecting the elements tab to view the web page contents structured AKA the Dom.
          if u select an element you can change its properties on the right hand side top box so that’s where you could apply display flex
            MMRIZE @sdetweil
            Unfortunately override display:flex into .container is not so easy. Because, MM’s hide/show mechanism depends on container’s display value (none/block) and it is hard-coded in the HTML tag. (I think it would be a bad legacy approach to be fixed in some day.)
            Anyway, without that overriding, It is possible anyhow limitedly.
              float: left;
              max-width: 32%;
            and I put 3 modules (2 clocks, 1 calendar) in top_center region.
            G 2 Replies Last reply Reply Quote 0
            • G Offline
              GodSmackedOrange @MMRIZE
              @MMRIZE Thats not put the side to side but it looks like they are both squished up together, I’m assuming because that top_center is only a thin strip,
              anyway to make it wider?
              • G Offline
                @MMRIZE Never Mind, I’ve got it looking kinda of right now, I have added 2 more lists, so now I have travel time, list1, list 2 and list 3, only thing left is maybe if I could add some padding between them?
                  @GodSmackedOrange well center is the center region,
                  top is across all left/center/right
                  • G Offline
                    @sdetweil @MMRIZE
                    Got it guys,
                    float: left;
                    max-width: 32%;
                    margin: 0 50px;
                    Thanks guys!!
                      bertories @GodSmackedOrange
                      @GodSmackedOrange said in 2 modules side by side:
                      float: left;
                      max-width: 32%;
                      margin: 0 50px;
                      I tried this along with another post and I get the same thing. The two weather modules go next to each other, but they end up in the same spot. The one module isn’t at the same hieght as the other.
                      https://www.dropbox.com/scl/fi/377vilalfvri9btnyc195/Screenshot-5.png?rlkey=77qpb4f05qh5zp6iqfa8e28o0&dl=0
                      • BKeyportB Offline
                        BKeyport Module Developer @bertories
                        Just a FYI, it may also work thusly:
                        /* adjust modules to display side by side */
                        .MMM-ValuesByNotification, .MMM-OpenWeatherForecast {
                        	display: inline-flex;
                        	margin-right: 5px;
                        	margin-left: 5px;
                        the catch is that you have to have the modules in your config in the exact order you do in this css entry.
