    Can't install new version
    7 Posts 2 Posters 1.6k Views 2 Watching
      musson @sdetweil
      @sdetweil Thank you
        sdetweil @musson
        @musson try the upgrade script again, with force instead of apply
        it will remove and and add the right version of node the right way, including on buster
        please advise your results
          musson @sdetweil
          @sdetweil I was doing a install on a fresh bullseye system.
          I will try the install script again. I have nothing to update, sorry.
            sdetweil @musson
            @musson sorry, missed 'install ’ words this morning…
              musson
              The install was successful :)
              I still get a bunch of these waning’s though that’s probably not your issue.
              Thanks for all the effort you put into this project.
              (node:2431) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
              • S sdetweil moved this topic from General Discussion on
