    Magic Mirror Update fail
    8 Posts 4 Posters 2.1k Views 4 Watching
    • F Offline
      Freddy_boy
      I just attempted to update to the latest version of Magic Mirror, and now I can’t get it to start… Can anyone provide any suggestions? Here is what I am seeing now:
      pi@raspberrypi:~/MagicMirror $ npm run start
      magicmirror@2.25.0 start
      [03.10.2023 12:06.38.811] [LOG] Starting MagicMirror: v2.25.0
      [03.10.2023 12:06.38.822] [LOG] Loading config …
      [03.10.2023 12:06.38.825] [DEBUG] config template file not exists, no envsubst
      [03.10.2023 12:06.38.829] [LOG] Loading module helpers …
      [03.10.2023 12:06.38.831] [LOG] No helper found for module: alert.
      [03.10.2023 12:06.38.868] [LOG] Initializing new module helper …
      [03.10.2023 12:06.38.870] [LOG] Module helper loaded: updatenotification
      [03.10.2023 12:06.38.871] [LOG] No helper found for module: clock.
      [03.10.2023 12:06.39.093] [LOG] Initializing new module helper …
      [03.10.2023 12:06.39.094] [LOG] Module helper loaded: calendar
      [03.10.2023 12:06.39.095] [LOG] No helper found for module: calendar_monthly.
      [03.10.2023 12:06.39.099] [LOG] Initializing new module helper …
      [03.10.2023 12:06.39.100] [LOG] Module helper loaded: MMM-Pir
      [03.10.2023 12:06.39.104] [ERROR] (node:2935) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘node-fetch’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-Weather/node_helper.js
      • at node:internal/modules/cjs/loader:1084:15
        at Function. (node:electron/js2c/browser_init:2:117419)
        at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at node:internal/modules/cjs/loader:929:27
        at Function._load (node:electron/js2c/asar_bundle:2:13327)
        at Module.require (node:internal/modules/cjs/loader:1150:19)
        at require (node:internal/modules/cjs/helpers:110:18)
        at Object. (/home/pi/MagicMirror/modules/MMM-Weather/node_helper.js:11:15)
        at Module._compile (node:internal/modules/cjs/loader:1271:14)
        at Object…js (node:internal/modules/cjs/loader:1326:10)
        at Module.load (node:internal/modules/cjs/loader:1126:32)
        at node:internal/modules/cjs/loader:967:12
        at loadModule (/home/pi/MagicMirror/js/app.js:180:19)
        (Use electron --trace-warnings ... to show where the warning was created)
        [03.10.2023 12:06.39.104] [ERROR] (node:2935) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
        WARNING: v3dv is neither a complete nor a conformant Vulkan implementation. Testing use only.
        [2935:1003/120639.849727:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.portal.Error.NotFound: Requested setting not found
        MESA-LOADER: failed to retrieve device information
        MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
        failed to load driver: kms_swrast
        MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
        failed to load swrast driver
      …and it just sits there… Can anyone help me to decipher these messages? Thanks…
        sdetweil @Freddy_boy
        @Freddy_boy said in Magic Mirror Update fail:
        this library was removed from the base in 2.25
        see
        • F Offline
          Freddy_boy @sdetweil
          Thanks for the reply… I’ve gone to my MagicMirror/modules folder, and I can confirm that there is no module called ‘node-fetch’. Your post indicates that to fix this, the library needs to be installed in the module folder. The procedure continues to indicate that I need to change directories to the module that is having the problem… but it doesn’t exist…? Am I reading this correctly?
            The procedure continues to indicate that I need to change directories to the module that is having the problem, but it doesn’t exist…
            I don’t understand
            is the module having trouble…
            that is the folder to be active for the rest of my instructions
            • F Offline
              Ok. I went to my /home/pi/MagicMirror/modules/MMM-Weather/ folder and I ran the ‘npm install node-fetch’ command. I am getting a different error now:
              [03.10.2023 16:57.03.945] [LOG] Starting MagicMirror: v2.25.0
              [03.10.2023 16:57.03.956] [LOG] Loading config …
              [03.10.2023 16:57.03.958] [DEBUG] config template file not exists, no envsubst
              [03.10.2023 16:57.03.962] [LOG] Loading module helpers …
              [03.10.2023 16:57.03.964] [LOG] No helper found for module: alert.
              [03.10.2023 16:57.03.998] [LOG] Initializing new module helper …
              [03.10.2023 16:57.04.001] [LOG] Module helper loaded: updatenotification
              [03.10.2023 16:57.04.004] [LOG] No helper found for module: clock.
              [03.10.2023 16:57.04.238] [LOG] Initializing new module helper …
              [03.10.2023 16:57.04.239] [LOG] Module helper loaded: calendar
              [03.10.2023 16:57.04.240] [LOG] No helper found for module: calendar_monthly.
              [03.10.2023 16:57.04.244] [LOG] Initializing new module helper …
              [03.10.2023 16:57.04.245] [LOG] Module helper loaded: MMM-Pir
              [03.10.2023 16:57.04.342] [ERROR] (node:3203) UnhandledPromiseRejectionWarning: Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/modules/MMM-Weather/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/MMM-Weather/node_helper.js not supported.
              Instead change the require of index.js in /home/pi/MagicMirror/modules/MMM-Weather/node_helper.js to a dynamic import() which is available in all CommonJS modules.
              at loadModules (/home/pi/MagicMirror/js/app.js:210:10)
              at async App.start (/home/pi/MagicMirror/js/app.js:258:3)
              [03.10.2023 16:57.04.342] [ERROR] (node:3203) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
              [3203:1003/165705.081300:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.portal.Error.NotFound: Requested setting not found
              • karsten13K Online
                karsten13 @Freddy_boy
                @Freddy_boy
                npm install node-fetch will install the latest version which is a v3.x
                mm does not support typescript and so needs a v2.x version.
                you have to look up the latest v2.x release and install this. This is a problem of MMM-Weather and should be fixed there.
                BKeyportB F 2 Replies Last reply Reply Quote 1
                • BKeyportB Offline
                  BKeyport Module Developer @karsten13
                  it also looks like the module isn’t supported anymore, at least the original is “Public archive” status - It’s a @bugsounet module, so I’d suggest going over to https://forum.bugsounet.fr/ for support if any is given.
                  • F Offline
                    Freddy_boy @karsten13
                    @karsten13
                    Success! I ran the following command:
                    npm install node-fetch@2
                    … and now it’s back up and running again! Thanks for the quick response!
