    MMM-Remote-Control API and remote fails after V2.25.0 update
    21 Posts 3 Posters 4.1k Views 3 Watching
      sdetweil @rhbauman
      @rhbauman can you show the address and IpWhitelist values from config.js
      R karsten13K 2 Replies Last reply Reply Quote 0
        rhbauman @sdetweil
        let config = {
        	address:    "0.0.0.0", // to listen on any interface
                      // - "localhost", 	// Address to listen on, can be:
        	port: 8080,
        	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.249.0/24"], 	// Set [] to allow all IP addresses
        • karsten13K Offline
          karsten13 @sdetweil
          [03.10.2023 21:02.54.966] [ERROR] Error when starting node_helper for module MMM-Remote-Control:
          [03.10.2023 21:02.54.969] [ERROR] Error: Cannot find module 'node-fetch'
          Require stack:
          - /opt/magic_mirror/modules/MMM-Remote-Control/scripts/download_modules.js
          - /opt/magic_mirror/modules/MMM-Remote-Control/node_helper.js
          so https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
            sdetweil @rhbauman
            @rhbauman set
            ipWhitelist:[],
              rhbauman @sdetweil
              No difference.
              root@snowy:~# curl -X GET http://192.168.249.34:8080/api/test
              <!DOCTYPE html>
              <html lang="en">
              <head>
              <meta charset="utf-8">
              <title>Error</title>
              </head>
              <body>
              <pre>Cannot GET /api/test</pre>
              </body>
              </html>
                sdetweil @rhbauman
                @rhbauman did you also fix this
                https://forum.magicmirror.builders/topic/18046/mmm-remote-control-api-and-remote-fails-after-v2-25-0-update/4?_=1696419416964
                  rhbauman @sdetweil
                  I posted the startup section of the log file. You can see there are no error messages about missing modules. It seems you’re trying to suggest solutions to all the problems similar to this one that have been covered before. I appreciate that but I did research this problem before posting here.
                  Have you updated your MM to V2.25 and tried to access the Remote-Control API? Does it work for you?
                    sdetweil @rhbauman
                    @rhbauman I don’t use this module, but if Karsten posts, then you listen. the
                    node_fetch library was removed in this release.
                      rhbauman @sdetweil
                      And if I post, please read it and think about what you are about to post before adding noise to the discussion. I am not seeing any error messages about missing modules and I am not getting a black screen.
                      Perhaps you could load Remote-Control and let me know if you can duplicate my problem?
                        sdetweil @rhbauman
                        and came up on my phone
                        my module config
                            module: 'MMM-Remote-Control',
                            // position: 'bottom_left',
                                customCommand: {},  // Optional, See "Using Custom Commands" below
                                showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                                secureEndpoints: true, // Optional, See API/README.md
                                // uncomment any of the lines below if you're gonna use it
                                // customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                                apiKey: "12345", // Optional, See API/README.md for details
                                // classes: {} // Optional, See "Custom Classes" below
                        my top line mm config
                        let config = {
                        	address: "0.0.0.0",	// Address to listen on, can be:
                        	port: 8090,
                        	basePath: "/",			// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                        	ipWhitelist: [],	// Set [] to allow all IP addresses
