    Repeating entries don't appear in Upcoming Events.
    11 Posts 3 Posters 4.5k Views 3 Watching
      sdetweil @Cliff365
      @Cliff365 is this using the default calendar module?
      Cliff365C 1 Reply Last reply
      • Cliff365C
        Cliff365 @sdetweil
        @sdetweil Yes, it’s the default module.
          sdetweil @Cliff365
          @Cliff365 we only display the start date/time. and tomorrow we will display nth day of list, and the next day shows nth+1. we WILL NOT display today start AND tomorrow AND the next all at once
          • Cliff365C
            Cliff365 @sdetweil
            @sdetweil That’s what I suspected. FWIW, in my case it would be extremely helpful for the repeating entry to appear for each day the appointment repeats.
            S lavolp3L 2 Replies Last reply
              sdetweil @Cliff365
              @Cliff365 it would take recoding the module to make the additional entries appear.
              I would look to other modules that provide that support
              • lavolp3L
                lavolp3 Module Developer @Cliff365
                @Cliff365 Just so I understand correctly: You want a multi-day event, like a holiday, appear for every upcoming day?
                You could consider using the daily view of the calendar, there your event would be split into days. Maybe it helps?
                IIRC it is the timeFormat: 'dateheaders'option in the config
                "timeFormat
                Display event times as absolute dates, or relative time, or using absolute date headers with times for each event next to it
                Possible values: absolute or relative or dateheaders
                Default value: relative"
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                • Cliff365C
                  Cliff365 @lavolp3
                  @lavolp3 This might help. We use a calendar to let the kids know it is their turn to clean the recroom on a weekend. So ‘Tommy-Recroom’ appears in upcoming events for Friday. If Tommy forgets on Friday, his alert is now gone. To compensate for that, I have to enter Tommy for Friday, Saturday, Sunday so his name stays on upcoming events.
                  In my case, it would be fantastic if a single ‘Tommy-Recroom’ appeared on a recurring event for that day.
                  Does that make sense now?
                    sdetweil @Cliff365
                    @Cliff365 in the default calendar you can do
                    sliceMultiDayEvents: true
                    this will separate each day of multi day into separates…
                    but now you will have the opposite problem…
                    one event with recurring for f/s/s will be 3 events. 1 for each day
                    Cliff365C 2 Replies Last reply
                    • Cliff365C
                      Cliff365 @sdetweil
                      @sdetweil I’ll give that a try. That might just work for my situation. Thanks!
                      • Cliff365C
                        Cliff365 @sdetweil
                        @sdetweil “one event with recurring for f/s/s will be 3 events. 1 for each day”
                        Totally fine with that. That’s what I have now, but now I have much less typing.
