    Error updating MM
    9 Posts 4 Posters 2.3k Views 4 Watching
    • K Offline
      kevmang
      Hi Everyone
      My MM upgrade seems to have hit abit of a snag. Here is the log file after trying to update. The error I’m getting seems to be a little bit different to the other ones posted here (but root cause probably the same). Does anyone have any tips on how to get my MM running again?
      pi@raspberrypi:~/MagicMirror/modules$ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"  force
      Reading package lists... Done
      Building dependency tree
        libc-ares2 libuv1 rpi-eeprom-images
      Use 'sudo apt autoremove' to remove them.
      The following packages will be REMOVED:
        nodejs*
      0 upgraded, 0 newly installed, 1 to remove and 404 not upgraded.
      After this operation, 185 MB disk space will be freed.
      (Reading database ... 100567 files and directories currently installed.)
      Removing nodejs (20.8.0-1nodesource1) ...
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules' not empty so not removed
      Processing triggers for man-db (2.8.5-2) ...
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      ca-certificates is already the newest version (20200601~deb10u2).
      curl is already the newest version (7.64.0-4+deb10u6).
      gnupg is already the newest version (2.2.12-1+rpi1+deb10u1).
      0 upgraded, 0 newly installed, 0 to remove and 404 not upgraded.
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
      Get:1 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
      Get:2 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5,267 B]
      Hit:3 http://archive.raspberrypi.org/debian buster InRelease
      Hit:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Fetched 17.4 kB in 34s (507 B/s)
      The following NEW packages will be installed:
        nodejs
      0 upgraded, 1 newly installed, 0 to remove and 404 not upgraded.
      Need to get 0 B/26.8 MB of archives.
      After this operation, 177 MB of additional disk space will be used.
      Selecting previously unselected package nodejs.
      (Reading database ... 94745 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.18.0-1nodesource1_armhf.deb ...
      Unpacking nodejs (18.18.0-1nodesource1) ...
      Setting up nodejs (18.18.0-1nodesource1) ...
      doing test run = false
      Minimum Node version: v18.18.0
      Installed Node version: v16.11.1
      Node should be upgraded.
      Installing Node.js ...
      gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
      The following packages will be upgraded:
        nodejs
      1 upgraded, 0 newly installed, 0 to remove and 404 not upgraded.
      Need to get 0 B/27.0 MB of archives.
      After this operation, 5,819 kB of additional disk space will be used.
      apt-listchanges: Reading changelogs...
      (Reading database ... 100369 files and directories currently installed.)
      Preparing to unpack .../nodejs_20.5.1-deb-1nodesource1_armhf.deb ...
      Unpacking nodejs (20.5.1-deb-1nodesource1) over (18.18.0-1nodesource1) ...
      Setting up nodejs (20.5.1-deb-1nodesource1) ...
      node version is
      Node.js installation Done! version=v16.11.1
      force: line 240: [: too many arguments
      Minimum npm version: V9.8.1
      Installed npm version: V8.0.0
      npm should be upgraded.
      Installing npm ...
      E: Unable to correct problems, you have held broken packages.
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: npm@9.8.1
      npm ERR! notsup Not compatible with your version of node/npm: npm@9.8.1
      npm ERR! notsup Required: {"node":"^14.17.0 || ^16.13.0 || >=18.0.0"}
      npm ERR! notsup Actual:   {"npm":"8.0.0","node":"v16.11.1"}
      npm ERR!     /root/.npm/_logs/2023-10-04T14_24_00_147Z-debug.log
      npm installation Done! version=V8.0.0
      saving custom.css
      upgrading from version 2.25.0 to 2.25.0
      fetching latest revisions
      npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.25.0
      npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.25.0
      npm ERR! notsup Required: {"node":">=18"}
      npm ERR!     /home/pi/.npm/_logs/2023-10-04T14_24_06_797Z-debug.log
        sdetweil @kevmang
        @kevmang said in Error updating MM:
        nodejs
        (Reading database … 94745 files and directories currently installed.)
        Preparing to unpack …/nodejs_18.18.0-1nodesource1_armhf.deb …
        Unpacking nodejs (18.18.0-1nodesource1) …
        Setting up nodejs (18.18.0-1nodesource1) …
        Processing triggers for man-db (2.8.5-2) …
        yeh, thats interesting… says success and failure at the same time, but DID fail…
        can u run this my itself
        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)”
          sdetweil @kevmang
          @kevmang also, do these commands
          nvm
          and
          n
          I wonder if there was a separate way to install node…
          I know I use them at times…
          • K Offline
            kevmang @sdetweil
            @sdetweil Thanks for your advice. I’ve completely removed npm and node and that solved the errors when installing but MM still doesn’t appear. Here is the log from the install:
            pi@raspberrypi:~$ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
              nodejs*
            0 upgraded, 0 newly installed, 1 to remove and 401 not upgraded.
            After this operation, 177 MB disk space will be freed.
            (Reading database ... 100354 files and directories currently installed.)
            Removing nodejs (18.18.0-1nodesource1) ...
            Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:2 http://archive.raspberrypi.org/debian buster InRelease
            0 upgraded, 0 newly installed, 0 to remove and 401 not upgraded.
            deb [  signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
            Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:4 http://archive.raspberrypi.org/debian buster InRelease
            Fetched 17.4 kB in 1s (15.1 kB/s)
              nodejs
            0 upgraded, 1 newly installed, 0 to remove and 401 not upgraded.
            (Reading database ... 94730 files and directories currently installed.)
            Installed Node version: v18.18.0
            No Node.js upgrade necessary.
            Installed npm version: V9.8.1
            No npm upgrade necessary.
            saving custom.css
            local version 2.25.0 already same as master 2.25.0
            restoring custom.css
              sdetweil @kevmang
              @kevmang
              you need to use force on the upgrade command instead of apply
              also, show the output of npm start
              K 1 Reply Last reply Reply Quote 1
              • K Offline
                kevmang @sdetweil
                @sdetweil Thanks for the help! Used force to re-install MagicMirror again but still had an electron issue so I deleted the entier node_modules director as wel as the package_lock file and re-installed the modules. Then I had an error with MMM-MyCalendar which I fixed using the advice from here: https://github.com/jclarke0000/MMM-MyCalendar/issues/40
                Most importantly everything works just fine now :) Thanks again!
                S S 2 Replies Last reply Reply Quote 1
                  sdetweil @kevmang
                  @kevmang awesome,!!! thanks for the feedback
                    sil3ntstorm @kevmang
                    @kevmang Did you completely empty the node_modules folder? Did you have to run bash again from above?
                    And then you had to completely reinstall all the modules you previously had on it?
                      stoffel @sil3ntstorm
                      @sil3ntstorm i make sudo rm -r /usr/lib/node_modules
                      then i used the upgrade-script
                      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply.
                      the script above
                      not work for me, error arch=: Zeile 1: “#!/bin/bash: Datei oder Verzeichnis nicht gefunden.
                      after that i make npm install in the MagicMirror directory. Now all works fine for me
