    Error updating MM
    9 Posts 4 Posters 2.1k Views 4 Watching
      sdetweil @kevmang
      @kevmang said in Error updating MM:
      The following NEW packages will be installed:
      nodejs
      0 upgraded, 1 newly installed, 0 to remove and 404 not upgraded.
      Need to get 0 B/26.8 MB of archives.
      After this operation, 177 MB of additional disk space will be used.
      Selecting previously unselected package nodejs.
      (Reading database … 94745 files and directories currently installed.)
      Preparing to unpack …/nodejs_18.18.0-1nodesource1_armhf.deb …
      Unpacking nodejs (18.18.0-1nodesource1) …
      Setting up nodejs (18.18.0-1nodesource1) …
      Processing triggers for man-db (2.8.5-2) …
      yeh, thats interesting… says success and failure at the same time, but DID fail…
      can u run this my itself
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)”
        sdetweil @kevmang
        @kevmang also, do these commands
        nvm
        and
        n
        I wonder if there was a separate way to install node…
        I know I use them at times…
        • K Offline
          kevmang @sdetweil
          @sdetweil Thanks for your advice. I’ve completely removed npm and node and that solved the errors when installing but MM still doesn’t appear. Here is the log from the install:
          pi@raspberrypi:~$ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
          Reading package lists... Done
          Building dependency tree
          The following packages will be REMOVED:
            nodejs*
          0 upgraded, 0 newly installed, 1 to remove and 401 not upgraded.
          After this operation, 177 MB disk space will be freed.
          (Reading database ... 100354 files and directories currently installed.)
          Removing nodejs (18.18.0-1nodesource1) ...
          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules' not empty so not removed
          Processing triggers for man-db (2.8.5-2) ...
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          ca-certificates is already the newest version (20200601~deb10u2).
          curl is already the newest version (7.64.0-4+deb10u6).
          gnupg is already the newest version (2.2.12-1+rpi1+deb10u1).
          0 upgraded, 0 newly installed, 0 to remove and 401 not upgraded.
          deb [  signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
          Get:1 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
          Get:2 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5,267 B]
          Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:4 http://archive.raspberrypi.org/debian buster InRelease
          Fetched 17.4 kB in 1s (15.1 kB/s)
            nodejs
          0 upgraded, 1 newly installed, 0 to remove and 401 not upgraded.
          (Reading database ... 94730 files and directories currently installed.)
          Preparing to unpack .../nodejs_18.18.0-1nodesource1_armhf.deb ...
          Unpacking nodejs (18.18.0-1nodesource1) ...
          Setting up nodejs (18.18.0-1nodesource1) ...
          doing test run = false
          Minimum Node version: v18.18.0
          Installed Node version: v18.18.0
          No Node.js upgrade necessary.
          Minimum npm version: V9.8.1
          Installed npm version: V9.8.1
          No npm upgrade necessary.
          saving custom.css
          local version 2.25.0 already same as master 2.25.0
          restoring custom.css
            sdetweil @kevmang
            @kevmang
            you need to use force on the upgrade command instead of apply
            also, show the output of npm start
            K 1 Reply Last reply Reply Quote 1
            • K Offline
              kevmang @sdetweil
              @sdetweil Thanks for the help! Used force to re-install MagicMirror again but still had an electron issue so I deleted the entier node_modules director as wel as the package_lock file and re-installed the modules. Then I had an error with MMM-MyCalendar which I fixed using the advice from here: https://github.com/jclarke0000/MMM-MyCalendar/issues/40
              Most importantly everything works just fine now :) Thanks again!
              S S 2 Replies Last reply Reply Quote 1
                sdetweil @kevmang
                @kevmang awesome,!!! thanks for the feedback
                  sil3ntstorm @kevmang
                  @kevmang Did you completely empty the node_modules folder? Did you have to run bash again from above?
                  And then you had to completely reinstall all the modules you previously had on it?
                    stoffel @sil3ntstorm
                    @sil3ntstorm i make sudo rm -r /usr/lib/node_modules
                    then i used the upgrade-script
                    bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply.
                    the script above
                    not work for me, error arch=: Zeile 1: “#!/bin/bash: Datei oder Verzeichnis nicht gefunden.
                    after that i make npm install in the MagicMirror directory. Now all works fine for me
