    Update is not working..I need help please
    41 Posts 5 Posters 13.6k Views 5 Watching
      sdetweil @sil3ntstorm
      @sil3ntstorm you can try the node20_install script
      or you can try with upgrading mm using my upgrade script
      S StoffbeuteluweS 2 Replies Last reply Reply Quote 1
        sil3ntstorm @sdetweil
        @sdetweil I installed it, thanks
        • StoffbeuteluweS Offline
          Stoffbeuteluwe Project Sponsor @sdetweil
          @sdetweil Hi thanks for answering, the problem was 3 modules
          the module
          MMM-DWD-WarnWeather
          MMM-Snake
          MMM-MyCalendar
          without the modules it works fine and with the modules it doesn’t work and I don’t know wy???
          anybody an idea??
          S S 2 Replies Last reply Reply Quote 0
            sdetweil @Stoffbeuteluwe
            @Stoffbeuteluwe it’s this
            we removed node-fetch
            I think
            MMM-DWD-WarnWeather
            put out a fix
            git pull in that module folder and npm install
              sil3ntstorm @Stoffbeuteluwe
              @Stoffbeuteluwe Did you just deactivate the 3 modules in config.js, or did you also delete the 3 folders in the Modules folder? Did you have to do anything else to make it work?
              S StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                @sil3ntstorm we removed some libraries in this release that modules use but don’t document So you have to fix the modules manually by installing the missing libraries.
                I posted a link to the troubleshooting Post that shows you how to find the library and what to do about it
                  Stoffbeuteluwe Project Sponsor @sil3ntstorm
                  @sil3ntstorm I only deleted the module folder…
                    thanks DWD-Warnweather is fine
                    I can’t get MMM-MyCalendar to work, I’ve tried everything but unfortunately it doesn’t work.
                    As soon as the module folder (MMM-MyCalendar) is in the modules folder it doesn’t work…
                    Unfortunately I don’t know what to do next, sorry
                      @Stoffbeuteluwe show the output of the npm start
                      best way
                      pm2 stop all
                      npm start >somefile.txt 2>&1
                      wait 20 seconds
                      ctrl -c in the window for the above commands
                      then edit somefile.txt
                      and search for
                      Cannot find module
                      then next few lines will tell you which mmm module is affected
                        > magicmirror@2.25.0 start
                        [09.10.2023 21:11.47.231] [LOG]   Starting MagicMirror: v2.25.0
                        [09.10.2023 21:11.47.231] [LOG]   Loading config ...
                        [09.10.2023 21:11.47.232] [DEBUG] config template file not exists, no envsubst
                        [09.10.2023 21:11.47.233] [LOG]   Loading module helpers ...
                        [09.10.2023 21:11.47.233] [LOG]   No helper found for module: alert.
                        [09.10.2023 21:11.47.257] [LOG]   Initializing new module helper ...
                        [09.10.2023 21:11.47.257] [LOG]   Module helper loaded: MMM-Remote-Control
                        [09.10.2023 21:11.47.258] [LOG]   Initializing new module helper ...
                        [09.10.2023 21:11.47.258] [LOG]   Module helper loaded: updatenotification
                        [09.10.2023 21:11.47.258] [LOG]   No helper found for module: MMM-Snow.
                        [09.10.2023 21:11.47.258] [LOG]   No helper found for module: MMM-MyWordClock.
                        [09.10.2023 21:11.47.258] [LOG]   No helper found for module: clock.
                        [09.10.2023 21:11.47.258] [LOG]   No helper found for module: calendar_monthly.
                        [09.10.2023 21:11.47.275] [LOG]   Initializing new module helper ...
                        [09.10.2023 21:11.47.275] [LOG]   Module helper loaded: calendar
                        [09.10.2023 21:11.47.276] [ERROR] (node:78446) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
                        Require stack:
                        - /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js
                        - /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js
                        - /Users/patrickhahn/MM/js/app.js
                        - /Users/patrickhahn/MM/js/electron.js
                        - /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js
                            at node:internal/modules/cjs/loader:1084:15
                            at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                            at Module._resolveFilename (/Users/patrickhahn/MM/node_modules/module-alias/index.js:49:29)
                            at node:internal/modules/cjs/loader:929:27
                            at Function._load (node:electron/js2c/asar_bundle:2:13327)
                            at Module.require (node:internal/modules/cjs/loader:1150:19)
                            at require (node:internal/modules/cjs/helpers:110:18)
                            at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
                            at Module._compile (node:internal/modules/cjs/loader:1271:14)
                            at Object..js (node:internal/modules/cjs/loader:1326:10)
                            at Module.load (node:internal/modules/cjs/loader:1126:32)
                            at node:internal/modules/cjs/loader:967:12
                            at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:8:25)
                        (Use `Electron --trace-warnings ...` to show where the warning was created)
                        [09.10.2023 21:11.47.276] [ERROR] (node:78446) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                        2023-10-09 21:11:47.294 Electron[78446:1242307] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
                        /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron exited with signal SIGINT
                        • 1 / 5
