    Update is not working..I need help please
    41 Posts 5 Posters 13.6k Views 5 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor
      i am on a Mac mini
      i have done git pull and npm install not working
      i have tried a new installation not working
      Last login: Sat Oct  7 15:16:11 on console
      patrickhahn@Mac-mini ~ % cd MagicMirror
      patrickhahn@Mac-mini MagicMirror % npm start
      evalmachine.<anonymous>:45
      } = primordials;
      ReferenceError: primordials is not defined
          at evalmachine.<anonymous>:45:5
          at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/fs.js:11:8)
          at Module._compile (internal/modules/cjs/loader.js:1085:14)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
          at Module.load (internal/modules/cjs/loader.js:950:32)
          at Function.Module._load (internal/modules/cjs/loader.js:790:14)
          at Module.require (internal/modules/cjs/loader.js:974:19)
          at require (internal/modules/cjs/helpers.js:92:18)
          at Object.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:3:27)
      I hope someone can help …thanks
        Stoffbeuteluwe Project Sponsor @sdetweil
        the solution is to change the line 11 an 12 of calendarfetcher.js to this …
        /*const fetch = require("fetch");*/
        /*const digest = require("digest-fetch");*/
        now it works :folded_hands: :smiling_face_with_sunglasses:
          Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
          now I have installed node
          after git pull and npm install it shows this …
          > magicmirror@2.25.0 start
          [07.10.2023 16:44.38.170] [LOG]   Starting MagicMirror: v2.25.0
          [07.10.2023 16:44.38.171] [LOG]   Loading config ...
          [07.10.2023 16:44.38.171] [DEBUG] config template file not exists, no envsubst
          [07.10.2023 16:44.38.172] [LOG]   Loading module helpers ...
          [07.10.2023 16:44.38.172] [LOG]   No helper found for module: alert.
          [07.10.2023 16:44.38.200] [LOG]   Initializing new module helper ...
          [07.10.2023 16:44.38.200] [LOG]   Module helper loaded: MMM-Remote-Control
          [07.10.2023 16:44.38.201] [LOG]   Initializing new module helper ...
          [07.10.2023 16:44.38.201] [LOG]   Module helper loaded: updatenotification
          [07.10.2023 16:44.38.201] [LOG]   No helper found for module: MMM-Snow.
          [07.10.2023 16:44.38.201] [LOG]   No helper found for module: MMM-MyWordClock.
          [07.10.2023 16:44.38.201] [LOG]   No helper found for module: clock.
          [07.10.2023 16:44.38.203] [LOG]   No helper found for module: calendar_monthly.
          [07.10.2023 16:44.38.222] [LOG]   Initializing new module helper ...
          [07.10.2023 16:44.38.222] [LOG]   Module helper loaded: calendar
          [07.10.2023 16:44.38.223] [ERROR] (node:28140) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
          Require stack:
          - /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js
          - /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js
          - /Users/patrickhahn/MM/js/app.js
          - /Users/patrickhahn/MM/js/electron.js
          - /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js
              at node:internal/modules/cjs/loader:1084:15
              at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
              at Module._resolveFilename (/Users/patrickhahn/MM/node_modules/module-alias/index.js:49:29)
              at node:internal/modules/cjs/loader:929:27
              at Function._load (node:electron/js2c/asar_bundle:2:13327)
              at Module.require (node:internal/modules/cjs/loader:1150:19)
              at require (node:internal/modules/cjs/helpers:110:18)
              at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
              at Module._compile (node:internal/modules/cjs/loader:1271:14)
              at Object..js (node:internal/modules/cjs/loader:1326:10)
              at Module.load (node:internal/modules/cjs/loader:1126:32)
              at node:internal/modules/cjs/loader:967:12
              at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:8:25)
          (Use `Electron --trace-warnings ...` to show where the warning was created)
          [07.10.2023 16:44.38.223] [ERROR] (node:28140) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          2023-10-07 16:44:38.247 Electron[28140:158548] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
            sdetweil @Stoffbeuteluwe
            @Stoffbeuteluwe your version of node is not good enough You need either 18 or 20
            node -v
            will tell you
              sil3ntstorm @sdetweil
              I don’t have version 20 either but rather 16.14.2. How can I install version 20? Can you please help me?
                sdetweil @sil3ntstorm
                @sil3ntstorm you can try the node20_install script
                or you can try with upgrading mm using my upgrade script
                S StoffbeuteluweS 2 Replies Last reply Reply Quote 1
                  @sdetweil I installed it, thanks
                    @sdetweil Hi thanks for answering, the problem was 3 modules
                    the module
                    MMM-DWD-WarnWeather
                    MMM-Snake
                    MMM-MyCalendar
                    without the modules it works fine and with the modules it doesn’t work and I don’t know wy???
                    anybody an idea??
                    S S 2 Replies Last reply Reply Quote 0
                      @Stoffbeuteluwe it’s this
                      we removed node-fetch
                      I think
                      MMM-DWD-WarnWeather
                      put out a fix
                      git pull in that module folder and npm install
                        sil3ntstorm @Stoffbeuteluwe
                        @Stoffbeuteluwe Did you just deactivate the 3 modules in config.js, or did you also delete the 3 folders in the Modules folder? Did you have to do anything else to make it work?
                        S StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                          @sil3ntstorm we removed some libraries in this release that modules use but don’t document So you have to fix the modules manually by installing the missing libraries.
                          I posted a link to the troubleshooting Post that shows you how to find the library and what to do about it
                          • 1 / 5
