    Update is not working..I need help please
    41 Posts 5 Posters 19.3k Views 5 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @sdetweil
      @sdetweil Hi thanks for answering, the problem was 3 modules
      the module
      MMM-DWD-WarnWeather
      MMM-Snake
      MMM-MyCalendar
      without the modules it works fine and with the modules it doesn’t work and I don’t know wy???
      anybody an idea??
      S S 2 Replies Last reply Reply Quote 0
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe it’s this
        we removed node-fetch
        I think
        MMM-DWD-WarnWeather
        put out a fix
        git pull in that module folder and npm install
          sil3ntstorm @Stoffbeuteluwe
          @Stoffbeuteluwe Did you just deactivate the 3 modules in config.js, or did you also delete the 3 folders in the Modules folder? Did you have to do anything else to make it work?
          S StoffbeuteluweS 2 Replies Last reply Reply Quote 0
            sdetweil @sil3ntstorm
            @sil3ntstorm we removed some libraries in this release that modules use but don’t document So you have to fix the modules manually by installing the missing libraries.
            I posted a link to the troubleshooting Post that shows you how to find the library and what to do about it
              Stoffbeuteluwe Project Sponsor @sil3ntstorm
              @sil3ntstorm I only deleted the module folder…
                thanks DWD-Warnweather is fine
                I can’t get MMM-MyCalendar to work, I’ve tried everything but unfortunately it doesn’t work.
                As soon as the module folder (MMM-MyCalendar) is in the modules folder it doesn’t work…
                Unfortunately I don’t know what to do next, sorry
                  @Stoffbeuteluwe show the output of the npm start
                  best way
                  pm2 stop all
                  npm start >somefile.txt 2>&1
                  wait 20 seconds
                  ctrl -c in the window for the above commands
                  then edit somefile.txt
                  and search for
                  Cannot find module
                  then next few lines will tell you which mmm module is affected
                    > magicmirror@2.25.0 start
                    [09.10.2023 21:11.47.231] [LOG]   Starting MagicMirror: v2.25.0
                    [09.10.2023 21:11.47.231] [LOG]   Loading config ...
                    [09.10.2023 21:11.47.232] [DEBUG] config template file not exists, no envsubst
                    [09.10.2023 21:11.47.233] [LOG]   Loading module helpers ...
                    [09.10.2023 21:11.47.233] [LOG]   No helper found for module: alert.
                    [09.10.2023 21:11.47.257] [LOG]   Initializing new module helper ...
                    [09.10.2023 21:11.47.257] [LOG]   Module helper loaded: MMM-Remote-Control
                    [09.10.2023 21:11.47.258] [LOG]   Initializing new module helper ...
                    [09.10.2023 21:11.47.258] [LOG]   Module helper loaded: updatenotification
                    [09.10.2023 21:11.47.258] [LOG]   No helper found for module: MMM-Snow.
                    [09.10.2023 21:11.47.258] [LOG]   No helper found for module: MMM-MyWordClock.
                    [09.10.2023 21:11.47.258] [LOG]   No helper found for module: clock.
                    [09.10.2023 21:11.47.258] [LOG]   No helper found for module: calendar_monthly.
                    [09.10.2023 21:11.47.275] [LOG]   Initializing new module helper ...
                    [09.10.2023 21:11.47.275] [LOG]   Module helper loaded: calendar
                    [09.10.2023 21:11.47.276] [ERROR] (node:78446) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
                    Require stack:
                    - /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js
                    - /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js
                    - /Users/patrickhahn/MM/js/app.js
                    - /Users/patrickhahn/MM/js/electron.js
                    - /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js
                        at node:internal/modules/cjs/loader:1084:15
                        at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                        at Module._resolveFilename (/Users/patrickhahn/MM/node_modules/module-alias/index.js:49:29)
                        at node:internal/modules/cjs/loader:929:27
                        at Function._load (node:electron/js2c/asar_bundle:2:13327)
                        at Module.require (node:internal/modules/cjs/loader:1150:19)
                        at require (node:internal/modules/cjs/helpers:110:18)
                        at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
                        at Module._compile (node:internal/modules/cjs/loader:1271:14)
                        at Object..js (node:internal/modules/cjs/loader:1326:10)
                        at Module.load (node:internal/modules/cjs/loader:1126:32)
                        at node:internal/modules/cjs/loader:967:12
                        at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:8:25)
                    (Use `Electron --trace-warnings ...` to show where the warning was created)
                    [09.10.2023 21:11.47.276] [ERROR] (node:78446) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                    2023-10-09 21:11:47.294 Electron[78446:1242307] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
                    /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron exited with signal SIGINT
                      @Stoffbeuteluwe said in Update is not working..I need help please:
                      Cannot find module ‘fetch’
                      yes, and the module doesn’t provide a package.json, so npm install can’t fix it…
                      BUT fetch is provided in the base node 18 and 20… SO
                      edit the
                      and comment out the line (11) , by adding // to the start of the line
                      const fetch = require("fetch");
                        i have done this
                        /* MagicMirror²
                         * Node Helper: Calendar - CalendarFetcher
                         * By Michael Teeuw https://michaelteeuw.nl
                         * MIT Licensed.
                        const CalendarUtils = require("./calendarutils");
                        const Log = require("logger");
                        const NodeHelper = require("node_helper");
                        const ical = require("node-ical");
                        //const fetch = require("fetch");
                        const digest = require("digest-fetch");
                        const https = require("https");
                         * @param {string} url The url of the calendar to fetch
                         * @param {number} reloadInterval Time in ms the calendar is fetched again
                         * @param {string[]} excludedEvents An array of words / phrases from event titles that will be excluded from being shown.
                         * @param {number} maximumEntries The maximum number of events fetched.
                         * @param {number} maximumNumberOfDays The maximum number of days an event should be in the future.
                         * @param {object} auth The object containing options for authentication against the calendar.
                         * @param {boolean} includePastEvents If true events from the past maximumNumberOfDays will be fetched too
                         * @param {boolean} selfSignedCert If true, the server certificate is not verified against the list of supplied CAs.
                         * @class
                        but it still does not work
                          @Stoffbeuteluwe you are on the wrong level of code
                          neither are there in 2.25
                          do
                          git checkout modules/default/calendar/calendarfetcher.js
                          then
                          git status
                          show the results
                          karsten13K StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                          • karsten13K Offline
                            karsten13 @sdetweil
                            MMM-MyCalendar is a mess, the author copied (meanwhile old) versions of our code into his repo, so the problem is calendarfetcher.js of the module.
                              @sdetweil said in Update is not working..I need help please:
                              git status
                              patrickhahn@Mac-mini MM % git checkout modules/default/calendar/calendarfetcher.js
                              Updated 0 paths from the index
                              patrickhahn@Mac-mini MM % git status
                              On branch master
                              Your branch is up to date with 'origin/master'.
                              Untracked files:
                                (use "git add <file>..." to include in what will be committed)
                              	css/icons/
                              	new_package.json
                              	run-start.sh
                              nothing added to commit but untracked files present (use "git add" to track)
                                @Stoffbeuteluwe ok, now do
                                git pull
                                npm run install-mm
                                  @sdetweil it is still the same problem…
                                    @Stoffbeuteluwe can you show me the output of
                                    git status
                                    git pull
                                      On branch master
                                      Untracked files:
                                      	css/icons/
                                      	new_package.json
                                      	run-start.sh
                                      patrickhahn@Mac-mini MM % git pull
                                      Already up to date.
                                      patrickhahn@Mac-mini MM % patrickhahn@Mac-mini MM % git status
                                      On branch master
                                      Untracked files:
                                              css/icons/
                                              new_package.json
                                              run-start.sh
                                        @Stoffbeuteluwe ok, next, lets check the version of the code, should be 2.25.0
                                        grep version package.json
                                          Last login: Thu Oct 12 16:43:21 on ttys000
                                          patrickhahn@Mac-mini ~ % cd MM
                                          patrickhahn@Mac-mini MM % grep version package.json
                                          	"version": "2.25.0",
                                            @Stoffbeuteluwe and
                                            node -v, npm -v
                                            if node v18 or v20 then
                                            rm -rf node_modules
                                            rm package-lock.json
                                            npm run install-mm
