    Update is not working..I need help please
    41 Posts 5 Posters 22.3k Views 5 Watching
      sil3ntstorm @sdetweil
      @sdetweil I installed it, thanks
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @sdetweil
        @sdetweil Hi thanks for answering, the problem was 3 modules
        the module
        MMM-DWD-WarnWeather
        MMM-Snake
        MMM-MyCalendar
        without the modules it works fine and with the modules it doesn’t work and I don’t know wy???
        anybody an idea??
        S S 2 Replies Last reply
          sdetweil @Stoffbeuteluwe
          @Stoffbeuteluwe it’s this
          we removed node-fetch
          I think
          MMM-DWD-WarnWeather
          put out a fix
          git pull in that module folder and npm install
          StoffbeuteluweS 1 Reply Last reply
            sil3ntstorm @Stoffbeuteluwe
            @Stoffbeuteluwe Did you just deactivate the 3 modules in config.js, or did you also delete the 3 folders in the Modules folder? Did you have to do anything else to make it work?
            S StoffbeuteluweS 2 Replies Last reply
              sdetweil @sil3ntstorm
              @sil3ntstorm we removed some libraries in this release that modules use but don’t document So you have to fix the modules manually by installing the missing libraries.
              I posted a link to the troubleshooting Post that shows you how to find the library and what to do about it
              • StoffbeuteluweS
                Stoffbeuteluwe Project Sponsor @sil3ntstorm
                @sil3ntstorm I only deleted the module folder…
                • StoffbeuteluweS
                  thanks DWD-Warnweather is fine
                  I can’t get MMM-MyCalendar to work, I’ve tried everything but unfortunately it doesn’t work.
                  As soon as the module folder (MMM-MyCalendar) is in the modules folder it doesn’t work…
                  Unfortunately I don’t know what to do next, sorry
                    @Stoffbeuteluwe show the output of the npm start
                    best way
                    pm2 stop all
                    npm start >somefile.txt 2>&1
                    wait 20 seconds
                    ctrl -c in the window for the above commands
                    then edit somefile.txt
                    and search for
                    Cannot find module
                    then next few lines will tell you which mmm module is affected
                    • StoffbeuteluweS
                      > magicmirror@2.25.0 start
                      [09.10.2023 21:11.47.231] [LOG]   Starting MagicMirror: v2.25.0
                      [09.10.2023 21:11.47.231] [LOG]   Loading config ...
                      [09.10.2023 21:11.47.232] [DEBUG] config template file not exists, no envsubst
                      [09.10.2023 21:11.47.233] [LOG]   Loading module helpers ...
                      [09.10.2023 21:11.47.233] [LOG]   No helper found for module: alert.
                      [09.10.2023 21:11.47.257] [LOG]   Initializing new module helper ...
                      [09.10.2023 21:11.47.257] [LOG]   Module helper loaded: MMM-Remote-Control
                      [09.10.2023 21:11.47.258] [LOG]   Initializing new module helper ...
                      [09.10.2023 21:11.47.258] [LOG]   Module helper loaded: updatenotification
                      [09.10.2023 21:11.47.258] [LOG]   No helper found for module: MMM-Snow.
                      [09.10.2023 21:11.47.258] [LOG]   No helper found for module: MMM-MyWordClock.
                      [09.10.2023 21:11.47.258] [LOG]   No helper found for module: clock.
                      [09.10.2023 21:11.47.258] [LOG]   No helper found for module: calendar_monthly.
                      [09.10.2023 21:11.47.275] [LOG]   Initializing new module helper ...
                      [09.10.2023 21:11.47.275] [LOG]   Module helper loaded: calendar
                      [09.10.2023 21:11.47.276] [ERROR] (node:78446) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
                      Require stack:
                      - /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js
                      - /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js
                      - /Users/patrickhahn/MM/js/app.js
                      - /Users/patrickhahn/MM/js/electron.js
                      - /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js
                          at node:internal/modules/cjs/loader:1084:15
                          at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
                          at Module._resolveFilename (/Users/patrickhahn/MM/node_modules/module-alias/index.js:49:29)
                          at node:internal/modules/cjs/loader:929:27
                          at Function._load (node:electron/js2c/asar_bundle:2:13327)
                          at Module.require (node:internal/modules/cjs/loader:1150:19)
                          at require (node:internal/modules/cjs/helpers:110:18)
                          at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
                          at Module._compile (node:internal/modules/cjs/loader:1271:14)
                          at Object..js (node:internal/modules/cjs/loader:1326:10)
                          at Module.load (node:internal/modules/cjs/loader:1126:32)
                          at node:internal/modules/cjs/loader:967:12
                          at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:8:25)
                      (Use `Electron --trace-warnings ...` to show where the warning was created)
                      [09.10.2023 21:11.47.276] [ERROR] (node:78446) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                      2023-10-09 21:11:47.294 Electron[78446:1242307] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
                      /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron exited with signal SIGINT
                        @Stoffbeuteluwe said in Update is not working..I need help please:
                        Cannot find module ‘fetch’
                        yes, and the module doesn’t provide a package.json, so npm install can’t fix it…
                        BUT fetch is provided in the base node 18 and 20… SO
                        edit the
                        and comment out the line (11) , by adding // to the start of the line
                        const fetch = require("fetch");
                        • StoffbeuteluweS
                          i have done this
                          /* MagicMirror²
                           * Node Helper: Calendar - CalendarFetcher
                           * By Michael Teeuw https://michaelteeuw.nl
                           * MIT Licensed.
                          const CalendarUtils = require("./calendarutils");
                          const Log = require("logger");
                          const NodeHelper = require("node_helper");
                          const ical = require("node-ical");
                          //const fetch = require("fetch");
                          const digest = require("digest-fetch");
                          const https = require("https");
                           * @param {string} url The url of the calendar to fetch
                           * @param {number} reloadInterval Time in ms the calendar is fetched again
                           * @param {string[]} excludedEvents An array of words / phrases from event titles that will be excluded from being shown.
                           * @param {number} maximumEntries The maximum number of events fetched.
                           * @param {number} maximumNumberOfDays The maximum number of days an event should be in the future.
                           * @param {object} auth The object containing options for authentication against the calendar.
                           * @param {boolean} includePastEvents If true events from the past maximumNumberOfDays will be fetched too
                           * @param {boolean} selfSignedCert If true, the server certificate is not verified against the list of supplied CAs.
                           * @class
                          but it still does not work
                            @Stoffbeuteluwe you are on the wrong level of code
                            neither are there in 2.25
                            do
                            git checkout modules/default/calendar/calendarfetcher.js
                            then
                            git status
                            show the results
                            karsten13K StoffbeuteluweS 2 Replies Last reply
                            • karsten13K
                              karsten13 @sdetweil
                              MMM-MyCalendar is a mess, the author copied (meanwhile old) versions of our code into his repo, so the problem is calendarfetcher.js of the module.
                              • StoffbeuteluweS
                                @sdetweil said in Update is not working..I need help please:
                                git status
                                patrickhahn@Mac-mini MM % git checkout modules/default/calendar/calendarfetcher.js
                                Updated 0 paths from the index
                                patrickhahn@Mac-mini MM % git status
                                On branch master
                                Your branch is up to date with 'origin/master'.
                                Untracked files:
                                  (use "git add <file>..." to include in what will be committed)
                                	css/icons/
                                	new_package.json
                                	run-start.sh
                                nothing added to commit but untracked files present (use "git add" to track)
                                  @Stoffbeuteluwe ok, now do
                                  git pull
                                  npm run install-mm
                                  • StoffbeuteluweS
                                    @sdetweil it is still the same problem…
                                      @Stoffbeuteluwe can you show me the output of
                                      git status
                                      git pull
                                      • StoffbeuteluweS
                                        On branch master
                                        Untracked files:
                                        	css/icons/
                                        	new_package.json
                                        	run-start.sh
                                        patrickhahn@Mac-mini MM % git pull
                                        Already up to date.
                                        patrickhahn@Mac-mini MM % patrickhahn@Mac-mini MM % git status
                                        On branch master
                                        Untracked files:
                                                css/icons/
                                                new_package.json
                                                run-start.sh
                                          @Stoffbeuteluwe ok, next, lets check the version of the code, should be 2.25.0
                                          grep version package.json
                                          • StoffbeuteluweS
                                            Last login: Thu Oct 12 16:43:21 on ttys000
                                            patrickhahn@Mac-mini ~ % cd MM
                                            patrickhahn@Mac-mini MM % grep version package.json
                                            	"version": "2.25.0",
