    Update is not working..I need help please
    41 Posts 5 Posters 22.2k Views 5 Watching
      sdetweil @Stoffbeuteluwe
      @Stoffbeuteluwe said in Update is not working..I need help please:
      Cannot find module ‘fetch’
      yes, and the module doesn’t provide a package.json, so npm install can’t fix it…
      BUT fetch is provided in the base node 18 and 20… SO
      edit the
      /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js
      and comment out the line (11) , by adding // to the start of the line
      const fetch = require("fetch");
      StoffbeuteluweS 1 Reply Last reply
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @sdetweil
        i have done this
        /* MagicMirror²
         * Node Helper: Calendar - CalendarFetcher
         * By Michael Teeuw https://michaelteeuw.nl
         * MIT Licensed.
        const CalendarUtils = require("./calendarutils");
        const Log = require("logger");
        const NodeHelper = require("node_helper");
        const ical = require("node-ical");
        //const fetch = require("fetch");
        const digest = require("digest-fetch");
        const https = require("https");
         * @param {string} url The url of the calendar to fetch
         * @param {number} reloadInterval Time in ms the calendar is fetched again
         * @param {string[]} excludedEvents An array of words / phrases from event titles that will be excluded from being shown.
         * @param {number} maximumEntries The maximum number of events fetched.
         * @param {number} maximumNumberOfDays The maximum number of days an event should be in the future.
         * @param {object} auth The object containing options for authentication against the calendar.
         * @param {boolean} includePastEvents If true events from the past maximumNumberOfDays will be fetched too
         * @param {boolean} selfSignedCert If true, the server certificate is not verified against the list of supplied CAs.
         * @class
        but it still does not work
          @Stoffbeuteluwe you are on the wrong level of code
          neither are there in 2.25
          do
          git checkout modules/default/calendar/calendarfetcher.js
          then
          git status
          show the results
          karsten13K StoffbeuteluweS 2 Replies Last reply
          • karsten13K
            karsten13 @sdetweil
            MMM-MyCalendar is a mess, the author copied (meanwhile old) versions of our code into his repo, so the problem is calendarfetcher.js of the module.
            • StoffbeuteluweS
              @sdetweil said in Update is not working..I need help please:
              git status
              patrickhahn@Mac-mini MM % git checkout modules/default/calendar/calendarfetcher.js
              Updated 0 paths from the index
              patrickhahn@Mac-mini MM % git status
              On branch master
              Your branch is up to date with 'origin/master'.
              Untracked files:
                (use "git add <file>..." to include in what will be committed)
              	css/icons/
              	new_package.json
              	run-start.sh
              nothing added to commit but untracked files present (use "git add" to track)
                @Stoffbeuteluwe ok, now do
                git pull
                npm run install-mm
                • StoffbeuteluweS
                  @sdetweil it is still the same problem…
                    @Stoffbeuteluwe can you show me the output of
                    git status
                    git pull
                    • StoffbeuteluweS
                      On branch master
                      Untracked files:
                      	css/icons/
                      	new_package.json
                      	run-start.sh
                      patrickhahn@Mac-mini MM % git pull
                      Already up to date.
                      patrickhahn@Mac-mini MM % patrickhahn@Mac-mini MM % git status
                      On branch master
                      Untracked files:
                              css/icons/
                              new_package.json
                              run-start.sh
                        @Stoffbeuteluwe ok, next, lets check the version of the code, should be 2.25.0
                        grep version package.json
                        • StoffbeuteluweS
                          Last login: Thu Oct 12 16:43:21 on ttys000
                          patrickhahn@Mac-mini ~ % cd MM
                          patrickhahn@Mac-mini MM % grep version package.json
                          	"version": "2.25.0",
                            @Stoffbeuteluwe and
                            node -v, npm -v
                            if node v18 or v20 then
                            rm -rf node_modules
                            rm package-lock.json
                            npm run install-mm
                            • StoffbeuteluweS
                              I have installed the newest version of node the 20
                              patrickhahn@Mac-mini MM % node-v
                              zsh: command not found: node-v
                              patrickhahn@Mac-mini MM % npm-v
                              zsh: command not found: npm-v
                              patrickhahn@Mac-mini MM % rm -rf node_modules
                              patrickhahn@Mac-mini MM % rm package-lock.json
                              patrickhahn@Mac-mini MM % npm run install-mm
                              > magicmirror@2.25.0 install-mm
                              > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                              npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
                              > magicmirror@2.25.0 postinstall
                              > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                              > magicmirror@2.25.0 install-vendor
                              > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                              up to date in 106ms
                              > magicmirror@2.25.0 install-fonts
                              > echo "Installing fonts ...
                              > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                              up to date in 100ms
                              > magicmirror@2.25.0 prepare
                              > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                              no husky installed.
                              added 334 packages in 33s
                              • StoffbeuteluweS
                                I think I have to live without MMM-MyCalendar and try the default calendar
                                without MMM-MyCalender module …the Mirror works fine
                                  @Stoffbeuteluwe but u can fix mycalendar
                                  see the output of npm start
                                  it’s likely the node-fetch lib we removed
                                  just add it back.in the module folder
                                  see
                                  for how to update the module
                                  • StoffbeuteluweS
                                    i have installed fetch and digest-fetch but it won’t start
                                    Last login: Thu Oct 12 18:10:21 on ttys000
                                    patrickhahn@Mac-mini MM % npm start
                                    > magicmirror@2.25.0 start
                                    [12.10.2023 18:13.01.206] [LOG]   Starting MagicMirror: v2.25.0
                                    [12.10.2023 18:13.01.207] [LOG]   Loading config ...
                                    [12.10.2023 18:13.01.207] [DEBUG] config template file not exists, no envsubst
                                    [12.10.2023 18:13.01.208] [LOG]   Loading module helpers ...
                                    [12.10.2023 18:13.01.208] [LOG]   No helper found for module: alert.
                                    [12.10.2023 18:13.01.232] [LOG]   Initializing new module helper ...
                                    [12.10.2023 18:13.01.233] [LOG]   Module helper loaded: MMM-Remote-Control
                                    [12.10.2023 18:13.01.233] [LOG]   Initializing new module helper ...
                                    [12.10.2023 18:13.01.233] [LOG]   Module helper loaded: updatenotification
                                    [12.10.2023 18:13.01.233] [LOG]   No helper found for module: MMM-Snow.
                                    [12.10.2023 18:13.01.233] [LOG]   No helper found for module: MMM-MyWordClock.
                                    [12.10.2023 18:13.01.233] [LOG]   No helper found for module: clock.
                                    [12.10.2023 18:13.01.233] [LOG]   No helper found for module: calendar_monthly.
                                    [12.10.2023 18:13.01.251] [LOG]   Initializing new module helper ...
                                    [12.10.2023 18:13.01.251] [LOG]   Module helper loaded: calendar
                                    [12.10.2023 18:13.01.252] [ERROR] (node:2102) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
                                    Require stack:
                                    - /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js
                                    - /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js
                                    - /Users/patrickhahn/MM/js/app.js
                                    - /Users/patrickhahn/MM/js/electron.js
                                    - /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js
                                        at node:internal/modules/cjs/loader:1084:15
                                        at Function.<anonymous> (node:electron/js2c/browser_init:2:117576)
                                        at Module._resolveFilename (/Users/patrickhahn/MM/node_modules/module-alias/index.js:49:29)
                                        at node:internal/modules/cjs/loader:929:27
                                        at Function._load (node:electron/js2c/asar_bundle:2:13327)
                                        at Module.require (node:internal/modules/cjs/loader:1150:19)
                                        at require (node:internal/modules/cjs/helpers:110:18)
                                        at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
                                        at Module._compile (node:internal/modules/cjs/loader:1271:14)
                                        at Object..js (node:internal/modules/cjs/loader:1326:10)
                                        at Module.load (node:internal/modules/cjs/loader:1126:32)
                                        at node:internal/modules/cjs/loader:967:12
                                        at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:8:25)
                                    (Use `Electron --trace-warnings ...` to show where the warning was created)
                                    [12.10.2023 18:13.01.252] [ERROR] (node:2102) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                    2023-10-12 18:13:01.270 Electron[2102:3348103] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
                                    ^C/Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron exited with signal SIGINT
                                    patrickhahn@Mac-mini MM % cd modules
                                    patrickhahn@Mac-mini modules % cd MMM-MyCalendar
                                    patrickhahn@Mac-mini MMM-MyCalendar % ls package.json
                                    ls: package.json: No such file or directory
                                    patrickhahn@Mac-mini MMM-MyCalendar % npm init -y
                                    Wrote to /Users/patrickhahn/MM/modules/MMM-MyCalendar/package.json:
                                      "name": "mmm-mycalendar",
                                      "version": "1.0.0",
                                      "description": "This calendar module is functionally the same as the default calendar app, however its presentation is different.",
                                      "main": "MMM-MyCalendar.js",
                                      "scripts": {
                                        "test": "echo \"Error: no test specified\" && exit 1"
                                      "keywords": [],
                                      "author": "",
                                      "license": "ISC"
                                    patrickhahn@Mac-mini MMM-MyCalendar % npm install fetch
                                    added 6 packages, and audited 7 packages in 2s
                                    found 0 vulnerabilities
                                    patrickhahn@Mac-mini MMM-MyCalendar % cd
                                    [12.10.2023 18:14.34.291] [LOG]   Starting MagicMirror: v2.25.0
                                    [12.10.2023 18:14.34.292] [LOG]   Loading config ...
                                    [12.10.2023 18:14.34.292] [DEBUG] config template file not exists, no envsubst
                                    [12.10.2023 18:14.34.293] [LOG]   Loading module helpers ...
                                    [12.10.2023 18:14.34.293] [LOG]   No helper found for module: alert.
                                    [12.10.2023 18:14.34.317] [LOG]   Initializing new module helper ...
                                    [12.10.2023 18:14.34.317] [LOG]   Module helper loaded: MMM-Remote-Control
                                    [12.10.2023 18:14.34.318] [LOG]   Initializing new module helper ...
                                    [12.10.2023 18:14.34.318] [LOG]   Module helper loaded: updatenotification
                                    [12.10.2023 18:14.34.318] [LOG]   No helper found for module: MMM-Snow.
                                    [12.10.2023 18:14.34.318] [LOG]   No helper found for module: MMM-MyWordClock.
                                    [12.10.2023 18:14.34.318] [LOG]   No helper found for module: clock.
                                    [12.10.2023 18:14.34.318] [LOG]   No helper found for module: calendar_monthly.
                                    [12.10.2023 18:14.34.336] [LOG]   Initializing new module helper ...
                                    [12.10.2023 18:14.34.336] [LOG]   Module helper loaded: calendar
                                    [12.10.2023 18:14.34.339] [ERROR] (node:2138) UnhandledPromiseRejectionWarning: Error: Cannot find module 'digest-fetch'
                                    Require stack:
                                        at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:12:16)
                                    [12.10.2023 18:14.34.339] [ERROR] (node:2138) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                    2023-10-12 18:14:34.356 Electron[2138:3349277] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
                                      "version": "1.0.0",
                                      "scripts": {
                                      "keywords": [],
                                      "author": "",
                                      "license": "ISC",
                                      "dependencies": {
                                        "fetch": "^1.1.0"
                                      "devDependencies": {}
                                    patrickhahn@Mac-mini MMM-MyCalendar % npm install digest-fetch
                                    added 8 packages, and audited 15 packages in 2s
                                    [12.10.2023 18:16.37.004] [LOG]   Starting MagicMirror: v2.25.0
                                    [12.10.2023 18:16.37.005] [LOG]   Loading config ...
                                    [12.10.2023 18:16.37.005] [DEBUG] config template file not exists, no envsubst
                                    [12.10.2023 18:16.37.006] [LOG]   Loading module helpers ...
                                    [12.10.2023 18:16.37.006] [LOG]   No helper found for module: alert.
                                    [12.10.2023 18:16.37.030] [LOG]   Initializing new module helper ...
                                    [12.10.2023 18:16.37.030] [LOG]   Module helper loaded: MMM-Remote-Control
                                    [12.10.2023 18:16.37.031] [LOG]   Initializing new module helper ...
                                    [12.10.2023 18:16.37.031] [LOG]   Module helper loaded: updatenotification
                                    [12.10.2023 18:16.37.031] [LOG]   No helper found for module: MMM-Snow.
                                    [12.10.2023 18:16.37.031] [LOG]   No helper found for module: MMM-MyWordClock.
                                    [12.10.2023 18:16.37.031] [LOG]   No helper found for module: clock.
                                    [12.10.2023 18:16.37.031] [LOG]   No helper found for module: calendar_monthly.
                                    [12.10.2023 18:16.37.049] [LOG]   Initializing new module helper ...
                                    [12.10.2023 18:16.37.049] [LOG]   Module helper loaded: calendar
                                    [12.10.2023 18:16.37.060] [ERROR] (node:2177) UnhandledPromiseRejectionWarning: Error [ERR_REQUIRE_ESM]: require() of ES Module /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_modules/digest-fetch/digest-fetch-src.js from /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js not supported.
                                    Instead change the require of digest-fetch-src.js in /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules.
                                        at loadModule (/Users/patrickhahn/MM/js/app.js:180:19)
                                        at loadModules (/Users/patrickhahn/MM/js/app.js:210:10)
                                        at async App.start (/Users/patrickhahn/MM/js/app.js:258:3)
                                    [12.10.2023 18:16.37.060] [ERROR] (node:2177) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                    2023-10-12 18:16:37.079 Electron[2177:3350680] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
                                    S mumblebajM 2 Replies Last reply
                                      @Stoffbeuteluwe the default digest-fetch expects a different runtime…
                                      they say to do this in the module folder
                                      npm install digest-fetch@v2 node-fetch@v2
                                      • mumblebajM
                                        mumblebaj Module Developer @Stoffbeuteluwe
                                        @Stoffbeuteluwe Seems like you may have installed the wrong version of digest-fetch. You have a later version than what the module handles looks like to me. Not sure what version the module requires.
                                        • StoffbeuteluweS
                                          Stoffbeuteluwe Project Sponsor @mumblebaj
                                          @mumblebaj @sdetweil
                                          Yeah Yeah it works …a big THANK YOU to you
                                          without you guys I wouldn’t have made it:clapping_hands: :grinning_face_with_big_eyes:
                                            @Stoffbeuteluwe awesome!! thanks for the feedback
                                            • 2 / 3
