    Update is not working..I need help please
    41 Posts 5 Posters 19.1k Views 5 Watching
      @Stoffbeuteluwe show the output of the npm start
      best way
      pm2 stop all
      npm start >somefile.txt 2>&1
      wait 20 seconds
      ctrl -c in the window for the above commands
      then edit somefile.txt
      and search for
      Cannot find module
      then next few lines will tell you which mmm module is affected
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @sdetweil
        > magicmirror@2.25.0 start
        [09.10.2023 21:11.47.231] [LOG]   Starting MagicMirror: v2.25.0
        [09.10.2023 21:11.47.231] [LOG]   Loading config ...
        [09.10.2023 21:11.47.232] [DEBUG] config template file not exists, no envsubst
        [09.10.2023 21:11.47.233] [LOG]   Loading module helpers ...
        [09.10.2023 21:11.47.233] [LOG]   No helper found for module: alert.
        [09.10.2023 21:11.47.257] [LOG]   Initializing new module helper ...
        [09.10.2023 21:11.47.257] [LOG]   Module helper loaded: MMM-Remote-Control
        [09.10.2023 21:11.47.258] [LOG]   Initializing new module helper ...
        [09.10.2023 21:11.47.258] [LOG]   Module helper loaded: updatenotification
        [09.10.2023 21:11.47.258] [LOG]   No helper found for module: MMM-Snow.
        [09.10.2023 21:11.47.258] [LOG]   No helper found for module: MMM-MyWordClock.
        [09.10.2023 21:11.47.258] [LOG]   No helper found for module: clock.
        [09.10.2023 21:11.47.258] [LOG]   No helper found for module: calendar_monthly.
        [09.10.2023 21:11.47.275] [LOG]   Initializing new module helper ...
        [09.10.2023 21:11.47.275] [LOG]   Module helper loaded: calendar
        [09.10.2023 21:11.47.276] [ERROR] (node:78446) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
        Require stack:
        - /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js
        - /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js
        - /Users/patrickhahn/MM/js/app.js
        - /Users/patrickhahn/MM/js/electron.js
        - /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js
            at node:internal/modules/cjs/loader:1084:15
            at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
            at Module._resolveFilename (/Users/patrickhahn/MM/node_modules/module-alias/index.js:49:29)
            at node:internal/modules/cjs/loader:929:27
            at Function._load (node:electron/js2c/asar_bundle:2:13327)
            at Module.require (node:internal/modules/cjs/loader:1150:19)
            at require (node:internal/modules/cjs/helpers:110:18)
            at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
            at Module._compile (node:internal/modules/cjs/loader:1271:14)
            at Object..js (node:internal/modules/cjs/loader:1326:10)
            at Module.load (node:internal/modules/cjs/loader:1126:32)
            at node:internal/modules/cjs/loader:967:12
            at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:8:25)
        (Use `Electron --trace-warnings ...` to show where the warning was created)
        [09.10.2023 21:11.47.276] [ERROR] (node:78446) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
        2023-10-09 21:11:47.294 Electron[78446:1242307] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
        /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron exited with signal SIGINT
          sdetweil @Stoffbeuteluwe
          @Stoffbeuteluwe said in Update is not working..I need help please:
          Cannot find module ‘fetch’
          yes, and the module doesn’t provide a package.json, so npm install can’t fix it…
          BUT fetch is provided in the base node 18 and 20… SO
          edit the
          and comment out the line (11) , by adding // to the start of the line
          const fetch = require("fetch");
            i have done this
            /* MagicMirror²
             * Node Helper: Calendar - CalendarFetcher
             * By Michael Teeuw https://michaelteeuw.nl
             * MIT Licensed.
            const CalendarUtils = require("./calendarutils");
            const Log = require("logger");
            const NodeHelper = require("node_helper");
            const ical = require("node-ical");
            //const fetch = require("fetch");
            const digest = require("digest-fetch");
            const https = require("https");
             * @param {string} url The url of the calendar to fetch
             * @param {number} reloadInterval Time in ms the calendar is fetched again
             * @param {string[]} excludedEvents An array of words / phrases from event titles that will be excluded from being shown.
             * @param {number} maximumEntries The maximum number of events fetched.
             * @param {number} maximumNumberOfDays The maximum number of days an event should be in the future.
             * @param {object} auth The object containing options for authentication against the calendar.
             * @param {boolean} includePastEvents If true events from the past maximumNumberOfDays will be fetched too
             * @param {boolean} selfSignedCert If true, the server certificate is not verified against the list of supplied CAs.
             * @class
            but it still does not work
              @Stoffbeuteluwe you are on the wrong level of code
              neither are there in 2.25
              do
              git checkout modules/default/calendar/calendarfetcher.js
              then
              git status
              show the results
              karsten13K StoffbeuteluweS 2 Replies Last reply Reply Quote 0
              • karsten13K Offline
                karsten13 @sdetweil
                MMM-MyCalendar is a mess, the author copied (meanwhile old) versions of our code into his repo, so the problem is calendarfetcher.js of the module.
                  @sdetweil said in Update is not working..I need help please:
                  git status
                  patrickhahn@Mac-mini MM % git checkout modules/default/calendar/calendarfetcher.js
                  Updated 0 paths from the index
                  patrickhahn@Mac-mini MM % git status
                  On branch master
                  Your branch is up to date with 'origin/master'.
                  Untracked files:
                    (use "git add <file>..." to include in what will be committed)
                  	css/icons/
                  	new_package.json
                  	run-start.sh
                  nothing added to commit but untracked files present (use "git add" to track)
                    @Stoffbeuteluwe ok, now do
                    git pull
                    npm run install-mm
                      @sdetweil it is still the same problem…
                        @Stoffbeuteluwe can you show me the output of
                        git status
                        git pull
                          On branch master
                          Untracked files:
                          	css/icons/
                          	new_package.json
                          	run-start.sh
                          patrickhahn@Mac-mini MM % git pull
                          Already up to date.
                          patrickhahn@Mac-mini MM % patrickhahn@Mac-mini MM % git status
                          On branch master
                          Untracked files:
                                  css/icons/
                                  new_package.json
                                  run-start.sh
                            @Stoffbeuteluwe ok, next, lets check the version of the code, should be 2.25.0
                            grep version package.json
                              Last login: Thu Oct 12 16:43:21 on ttys000
                              patrickhahn@Mac-mini ~ % cd MM
                              patrickhahn@Mac-mini MM % grep version package.json
                              	"version": "2.25.0",
                                @Stoffbeuteluwe and
                                node -v, npm -v
                                if node v18 or v20 then
                                rm -rf node_modules
                                rm package-lock.json
                                npm run install-mm
                                  I have installed the newest version of node the 20
                                  patrickhahn@Mac-mini MM % node-v
                                  zsh: command not found: node-v
                                  patrickhahn@Mac-mini MM % npm-v
                                  zsh: command not found: npm-v
                                  patrickhahn@Mac-mini MM % rm -rf node_modules
                                  patrickhahn@Mac-mini MM % rm package-lock.json
                                  patrickhahn@Mac-mini MM % npm run install-mm
                                  > magicmirror@2.25.0 install-mm
                                  > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                                  npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
                                  > magicmirror@2.25.0 postinstall
                                  > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                                  > magicmirror@2.25.0 install-vendor
                                  > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                  up to date in 106ms
                                  > magicmirror@2.25.0 install-fonts
                                  > echo "Installing fonts ...
                                  > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                  up to date in 100ms
                                  > magicmirror@2.25.0 prepare
                                  > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                                  no husky installed.
                                  added 334 packages in 33s
                                    I think I have to live without MMM-MyCalendar and try the default calendar
                                    without MMM-MyCalender module …the Mirror works fine
                                      @Stoffbeuteluwe but u can fix mycalendar
                                      see the output of npm start
                                      it’s likely the node-fetch lib we removed
                                      just add it back.in the module folder
                                      see
                                      for how to update the module
                                        i have installed fetch and digest-fetch but it won’t start
                                        Last login: Thu Oct 12 18:10:21 on ttys000
                                        patrickhahn@Mac-mini MM % npm start
                                        [12.10.2023 18:13.01.206] [LOG]   Starting MagicMirror: v2.25.0
                                        [12.10.2023 18:13.01.207] [LOG]   Loading config ...
                                        [12.10.2023 18:13.01.207] [DEBUG] config template file not exists, no envsubst
                                        [12.10.2023 18:13.01.208] [LOG]   Loading module helpers ...
                                        [12.10.2023 18:13.01.208] [LOG]   No helper found for module: alert.
                                        [12.10.2023 18:13.01.232] [LOG]   Initializing new module helper ...
                                        [12.10.2023 18:13.01.233] [LOG]   Module helper loaded: MMM-Remote-Control
                                        [12.10.2023 18:13.01.233] [LOG]   Initializing new module helper ...
                                        [12.10.2023 18:13.01.233] [LOG]   Module helper loaded: updatenotification
                                        [12.10.2023 18:13.01.233] [LOG]   No helper found for module: MMM-Snow.
                                        [12.10.2023 18:13.01.233] [LOG]   No helper found for module: MMM-MyWordClock.
                                        [12.10.2023 18:13.01.233] [LOG]   No helper found for module: clock.
                                        [12.10.2023 18:13.01.233] [LOG]   No helper found for module: calendar_monthly.
                                        [12.10.2023 18:13.01.251] [LOG]   Initializing new module helper ...
                                        [12.10.2023 18:13.01.251] [LOG]   Module helper loaded: calendar
                                        [12.10.2023 18:13.01.252] [ERROR] (node:2102) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
                                        Require stack:
                                            at Function.<anonymous> (node:electron/js2c/browser_init:2:117576)
                                        [12.10.2023 18:13.01.252] [ERROR] (node:2102) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                        2023-10-12 18:13:01.270 Electron[2102:3348103] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
                                        ^C/Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron exited with signal SIGINT
                                        patrickhahn@Mac-mini MM % cd modules
                                        patrickhahn@Mac-mini modules % cd MMM-MyCalendar
                                        patrickhahn@Mac-mini MMM-MyCalendar % ls package.json
                                        ls: package.json: No such file or directory
                                        patrickhahn@Mac-mini MMM-MyCalendar % npm init -y
                                        Wrote to /Users/patrickhahn/MM/modules/MMM-MyCalendar/package.json:
                                          "name": "mmm-mycalendar",
                                          "version": "1.0.0",
                                          "description": "This calendar module is functionally the same as the default calendar app, however its presentation is different.",
                                          "main": "MMM-MyCalendar.js",
                                          "scripts": {
                                            "test": "echo \"Error: no test specified\" && exit 1"
                                          "keywords": [],
                                          "author": "",
                                          "license": "ISC"
                                        patrickhahn@Mac-mini MMM-MyCalendar % npm install fetch
                                        added 6 packages, and audited 7 packages in 2s
                                        found 0 vulnerabilities
                                        patrickhahn@Mac-mini MMM-MyCalendar % cd
                                        [12.10.2023 18:14.34.291] [LOG]   Starting MagicMirror: v2.25.0
                                        [12.10.2023 18:14.34.292] [LOG]   Loading config ...
                                        [12.10.2023 18:14.34.292] [DEBUG] config template file not exists, no envsubst
                                        [12.10.2023 18:14.34.293] [LOG]   Loading module helpers ...
                                        [12.10.2023 18:14.34.293] [LOG]   No helper found for module: alert.
                                        [12.10.2023 18:14.34.317] [LOG]   Initializing new module helper ...
                                        [12.10.2023 18:14.34.317] [LOG]   Module helper loaded: MMM-Remote-Control
                                        [12.10.2023 18:14.34.318] [LOG]   Initializing new module helper ...
                                        [12.10.2023 18:14.34.318] [LOG]   Module helper loaded: updatenotification
                                        [12.10.2023 18:14.34.318] [LOG]   No helper found for module: MMM-Snow.
                                        [12.10.2023 18:14.34.318] [LOG]   No helper found for module: MMM-MyWordClock.
                                        [12.10.2023 18:14.34.318] [LOG]   No helper found for module: clock.
                                        [12.10.2023 18:14.34.318] [LOG]   No helper found for module: calendar_monthly.
                                        [12.10.2023 18:14.34.336] [LOG]   Initializing new module helper ...
                                        [12.10.2023 18:14.34.336] [LOG]   Module helper loaded: calendar
                                        [12.10.2023 18:14.34.339] [ERROR] (node:2138) UnhandledPromiseRejectionWarning: Error: Cannot find module 'digest-fetch'
                                        Require stack:
                                            at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:12:16)
                                        [12.10.2023 18:14.34.339] [ERROR] (node:2138) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                        2023-10-12 18:14:34.356 Electron[2138:3349277] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
                                          "version": "1.0.0",
                                          "scripts": {
                                          "keywords": [],
                                          "author": "",
                                          "license": "ISC",
                                          "dependencies": {
                                            "fetch": "^1.1.0"
                                          "devDependencies": {}
                                        patrickhahn@Mac-mini MMM-MyCalendar % npm install digest-fetch
                                        added 8 packages, and audited 15 packages in 2s
                                        [12.10.2023 18:16.37.004] [LOG]   Starting MagicMirror: v2.25.0
                                        [12.10.2023 18:16.37.005] [LOG]   Loading config ...
                                        [12.10.2023 18:16.37.005] [DEBUG] config template file not exists, no envsubst
                                        [12.10.2023 18:16.37.006] [LOG]   Loading module helpers ...
                                        [12.10.2023 18:16.37.006] [LOG]   No helper found for module: alert.
                                        [12.10.2023 18:16.37.030] [LOG]   Initializing new module helper ...
                                        [12.10.2023 18:16.37.030] [LOG]   Module helper loaded: MMM-Remote-Control
                                        [12.10.2023 18:16.37.031] [LOG]   Initializing new module helper ...
                                        [12.10.2023 18:16.37.031] [LOG]   Module helper loaded: updatenotification
                                        [12.10.2023 18:16.37.031] [LOG]   No helper found for module: MMM-Snow.
                                        [12.10.2023 18:16.37.031] [LOG]   No helper found for module: MMM-MyWordClock.
                                        [12.10.2023 18:16.37.031] [LOG]   No helper found for module: clock.
                                        [12.10.2023 18:16.37.031] [LOG]   No helper found for module: calendar_monthly.
                                        [12.10.2023 18:16.37.049] [LOG]   Initializing new module helper ...
                                        [12.10.2023 18:16.37.049] [LOG]   Module helper loaded: calendar
                                        [12.10.2023 18:16.37.060] [ERROR] (node:2177) UnhandledPromiseRejectionWarning: Error [ERR_REQUIRE_ESM]: require() of ES Module /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_modules/digest-fetch/digest-fetch-src.js from /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js not supported.
                                        Instead change the require of digest-fetch-src.js in /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules.
                                            at loadModule (/Users/patrickhahn/MM/js/app.js:180:19)
                                            at loadModules (/Users/patrickhahn/MM/js/app.js:210:10)
                                            at async App.start (/Users/patrickhahn/MM/js/app.js:258:3)
                                        [12.10.2023 18:16.37.060] [ERROR] (node:2177) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                                        2023-10-12 18:16:37.079 Electron[2177:3350680] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
                                        S mumblebajM 2 Replies Last reply Reply Quote 0
                                          @Stoffbeuteluwe the default digest-fetch expects a different runtime…
                                          they say to do this in the module folder
                                          npm install digest-fetch@v2 node-fetch@v2
                                          • mumblebajM Offline
                                            mumblebaj Module Developer @Stoffbeuteluwe
                                            @Stoffbeuteluwe Seems like you may have installed the wrong version of digest-fetch. You have a later version than what the module handles looks like to me. Not sure what version the module requires.
                                            • 2 / 3
