    Update is not working..I need help please
    41 Posts 5 Posters 18.6k Views 5 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @sdetweil
      i have installed fetch and digest-fetch but it won’t start
      Last login: Thu Oct 12 18:10:21 on ttys000
      patrickhahn@Mac-mini ~ % cd MM
      patrickhahn@Mac-mini MM % npm start
      > magicmirror@2.25.0 start
      [12.10.2023 18:13.01.206] [LOG]   Starting MagicMirror: v2.25.0
      [12.10.2023 18:13.01.207] [LOG]   Loading config ...
      [12.10.2023 18:13.01.207] [DEBUG] config template file not exists, no envsubst
      [12.10.2023 18:13.01.208] [LOG]   Loading module helpers ...
      [12.10.2023 18:13.01.208] [LOG]   No helper found for module: alert.
      [12.10.2023 18:13.01.232] [LOG]   Initializing new module helper ...
      [12.10.2023 18:13.01.233] [LOG]   Module helper loaded: MMM-Remote-Control
      [12.10.2023 18:13.01.233] [LOG]   Initializing new module helper ...
      [12.10.2023 18:13.01.233] [LOG]   Module helper loaded: updatenotification
      [12.10.2023 18:13.01.233] [LOG]   No helper found for module: MMM-Snow.
      [12.10.2023 18:13.01.233] [LOG]   No helper found for module: MMM-MyWordClock.
      [12.10.2023 18:13.01.233] [LOG]   No helper found for module: clock.
      [12.10.2023 18:13.01.233] [LOG]   No helper found for module: calendar_monthly.
      [12.10.2023 18:13.01.251] [LOG]   Initializing new module helper ...
      [12.10.2023 18:13.01.251] [LOG]   Module helper loaded: calendar
      [12.10.2023 18:13.01.252] [ERROR] (node:2102) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
      Require stack:
      - /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js
      - /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js
      - /Users/patrickhahn/MM/js/app.js
      - /Users/patrickhahn/MM/js/electron.js
      - /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js
          at node:internal/modules/cjs/loader:1084:15
          at Function.<anonymous> (node:electron/js2c/browser_init:2:117576)
          at Module._resolveFilename (/Users/patrickhahn/MM/node_modules/module-alias/index.js:49:29)
          at node:internal/modules/cjs/loader:929:27
          at Function._load (node:electron/js2c/asar_bundle:2:13327)
          at Module.require (node:internal/modules/cjs/loader:1150:19)
          at require (node:internal/modules/cjs/helpers:110:18)
          at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
          at Module._compile (node:internal/modules/cjs/loader:1271:14)
          at Object..js (node:internal/modules/cjs/loader:1326:10)
          at Module.load (node:internal/modules/cjs/loader:1126:32)
          at node:internal/modules/cjs/loader:967:12
          at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:8:25)
      (Use `Electron --trace-warnings ...` to show where the warning was created)
      [12.10.2023 18:13.01.252] [ERROR] (node:2102) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      2023-10-12 18:13:01.270 Electron[2102:3348103] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
      ^C/Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron exited with signal SIGINT
      patrickhahn@Mac-mini MM % cd modules
      patrickhahn@Mac-mini modules % cd MMM-MyCalendar
      patrickhahn@Mac-mini MMM-MyCalendar % ls package.json
      ls: package.json: No such file or directory
      patrickhahn@Mac-mini MMM-MyCalendar % npm init -y
      Wrote to /Users/patrickhahn/MM/modules/MMM-MyCalendar/package.json:
        "name": "mmm-mycalendar",
        "version": "1.0.0",
        "description": "This calendar module is functionally the same as the default calendar app, however its presentation is different.",
        "main": "MMM-MyCalendar.js",
        "scripts": {
          "test": "echo \"Error: no test specified\" && exit 1"
        "keywords": [],
        "author": "",
        "license": "ISC"
      patrickhahn@Mac-mini MMM-MyCalendar % npm install fetch
      added 6 packages, and audited 7 packages in 2s
      found 0 vulnerabilities
      patrickhahn@Mac-mini MMM-MyCalendar % cd
      [12.10.2023 18:14.34.291] [LOG]   Starting MagicMirror: v2.25.0
      [12.10.2023 18:14.34.292] [LOG]   Loading config ...
      [12.10.2023 18:14.34.292] [DEBUG] config template file not exists, no envsubst
      [12.10.2023 18:14.34.293] [LOG]   Loading module helpers ...
      [12.10.2023 18:14.34.293] [LOG]   No helper found for module: alert.
      [12.10.2023 18:14.34.317] [LOG]   Initializing new module helper ...
      [12.10.2023 18:14.34.317] [LOG]   Module helper loaded: MMM-Remote-Control
      [12.10.2023 18:14.34.318] [LOG]   Initializing new module helper ...
      [12.10.2023 18:14.34.318] [LOG]   Module helper loaded: updatenotification
      [12.10.2023 18:14.34.318] [LOG]   No helper found for module: MMM-Snow.
      [12.10.2023 18:14.34.318] [LOG]   No helper found for module: MMM-MyWordClock.
      [12.10.2023 18:14.34.318] [LOG]   No helper found for module: clock.
      [12.10.2023 18:14.34.318] [LOG]   No helper found for module: calendar_monthly.
      [12.10.2023 18:14.34.336] [LOG]   Initializing new module helper ...
      [12.10.2023 18:14.34.336] [LOG]   Module helper loaded: calendar
      [12.10.2023 18:14.34.339] [ERROR] (node:2138) UnhandledPromiseRejectionWarning: Error: Cannot find module 'digest-fetch'
      Require stack:
          at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:12:16)
      [12.10.2023 18:14.34.339] [ERROR] (node:2138) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      2023-10-12 18:14:34.356 Electron[2138:3349277] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
        "version": "1.0.0",
        "scripts": {
        "keywords": [],
        "author": "",
        "license": "ISC",
        "dependencies": {
          "fetch": "^1.1.0"
        "devDependencies": {}
      patrickhahn@Mac-mini MMM-MyCalendar % npm install digest-fetch
      added 8 packages, and audited 15 packages in 2s
      [12.10.2023 18:16.37.004] [LOG]   Starting MagicMirror: v2.25.0
      [12.10.2023 18:16.37.005] [LOG]   Loading config ...
      [12.10.2023 18:16.37.005] [DEBUG] config template file not exists, no envsubst
      [12.10.2023 18:16.37.006] [LOG]   Loading module helpers ...
      [12.10.2023 18:16.37.006] [LOG]   No helper found for module: alert.
      [12.10.2023 18:16.37.030] [LOG]   Initializing new module helper ...
      [12.10.2023 18:16.37.030] [LOG]   Module helper loaded: MMM-Remote-Control
      [12.10.2023 18:16.37.031] [LOG]   Initializing new module helper ...
      [12.10.2023 18:16.37.031] [LOG]   Module helper loaded: updatenotification
      [12.10.2023 18:16.37.031] [LOG]   No helper found for module: MMM-Snow.
      [12.10.2023 18:16.37.031] [LOG]   No helper found for module: MMM-MyWordClock.
      [12.10.2023 18:16.37.031] [LOG]   No helper found for module: clock.
      [12.10.2023 18:16.37.031] [LOG]   No helper found for module: calendar_monthly.
      [12.10.2023 18:16.37.049] [LOG]   Initializing new module helper ...
      [12.10.2023 18:16.37.049] [LOG]   Module helper loaded: calendar
      [12.10.2023 18:16.37.060] [ERROR] (node:2177) UnhandledPromiseRejectionWarning: Error [ERR_REQUIRE_ESM]: require() of ES Module /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_modules/digest-fetch/digest-fetch-src.js from /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js not supported.
      Instead change the require of digest-fetch-src.js in /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules.
          at loadModule (/Users/patrickhahn/MM/js/app.js:180:19)
          at loadModules (/Users/patrickhahn/MM/js/app.js:210:10)
          at async App.start (/Users/patrickhahn/MM/js/app.js:258:3)
      [12.10.2023 18:16.37.060] [ERROR] (node:2177) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      2023-10-12 18:16:37.079 Electron[2177:3350680] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
      S mumblebajM 2 Replies Last reply Reply Quote 0
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe the default digest-fetch expects a different runtime…
        they say to do this in the module folder
        npm install digest-fetch@v2 node-fetch@v2
        • mumblebajM Offline
          mumblebaj Module Developer @Stoffbeuteluwe
          @Stoffbeuteluwe Seems like you may have installed the wrong version of digest-fetch. You have a later version than what the module handles looks like to me. Not sure what version the module requires.
            Stoffbeuteluwe Project Sponsor @mumblebaj
            @mumblebaj @sdetweil
            Yeah Yeah it works …a big THANK YOU to you
            without you guys I wouldn’t have made it:clapping_hands: :grinning_face_with_big_eyes:
              @Stoffbeuteluwe awesome!! thanks for the feedback
                Hello, I was happy a little too early…
                the mirror starts but the calendar module says loading now
                Do you have an idea what could be causing this?
                I haven’t changed the config.
                Last login: Thu Oct 12 20:53:00 on ttys000
                [12.10.2023 20:59.23.100] [LOG]   Starting MagicMirror: v2.25.0
                [12.10.2023 20:59.23.101] [LOG]   Loading config ...
                [12.10.2023 20:59.23.101] [DEBUG] config template file not exists, no envsubst
                [12.10.2023 20:59.23.102] [LOG]   Loading module helpers ...
                [12.10.2023 20:59.23.102] [LOG]   No helper found for module: alert.
                [12.10.2023 20:59.23.127] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.127] [LOG]   Module helper loaded: MMM-Remote-Control
                [12.10.2023 20:59.23.129] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.129] [LOG]   Module helper loaded: updatenotification
                [12.10.2023 20:59.23.129] [LOG]   No helper found for module: MMM-Snow.
                [12.10.2023 20:59.23.129] [LOG]   No helper found for module: MMM-MyWordClock.
                [12.10.2023 20:59.23.129] [LOG]   No helper found for module: clock.
                [12.10.2023 20:59.23.129] [LOG]   No helper found for module: calendar_monthly.
                [12.10.2023 20:59.23.148] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.148] [LOG]   Module helper loaded: calendar
                [12.10.2023 20:59.23.157] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.157] [LOG]   Module helper loaded: MMM-MyCalendar
                [12.10.2023 20:59.23.157] [LOG]   No helper found for module: compliments.
                [12.10.2023 20:59.23.162] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.162] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
                [12.10.2023 20:59.23.162] [WARN]  No /Users/patrickhahn/MM/js/../modules/weatherforecast/weatherforecast.js found for module: weatherforecast.
                [12.10.2023 20:59.23.162] [LOG]   No helper found for module: weatherforecast.
                [12.10.2023 20:59.23.166] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.166] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
                [12.10.2023 20:59.23.178] [LOG]   Module helper loaded: MMM-Sonos
                [12.10.2023 20:59.23.254] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.254] [LOG]   Module helper loaded: MMM-TelegramBot
                [12.10.2023 20:59.23.283] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.283] [LOG]   Module helper loaded: MMM-AlexaControl
                [12.10.2023 20:59.23.314] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.314] [LOG]   Module helper loaded: MMM-DWD-Pollen
                [12.10.2023 20:59.23.314] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.25.0
                [12.10.2023 20:59.23.314] [LOG]   Version is ok!
                [12.10.2023 20:59.23.314] [LOG]   Module helper loaded: MMM-Fuel
                [12.10.2023 20:59.23.325] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.325] [LOG]   Module helper loaded: newsfeed
                [12.10.2023 20:59.23.325] [LOG]   No helper found for module: helloworld.
                [12.10.2023 20:59.23.366] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.366] [LOG]   Module helper loaded: MMM-Tado
                [12.10.2023 20:59.23.367] [LOG]   No helper found for module: MMM-YouTube.
                [12.10.2023 20:59.23.367] [LOG]   No helper found for module: MMM-EasyBack.
                [12.10.2023 20:59.23.394] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.394] [LOG]   Module helper loaded: MMM-ImagesPhotos
                [12.10.2023 20:59.23.395] [LOG]   No helper found for module: MMM-EasyPix.
                [12.10.2023 20:59.23.395] [LOG]   No helper found for module: MMM-EyeCandy.
                [12.10.2023 20:59.23.395] [LOG]   No helper found for module: MMM-SimpleLogo.
                [12.10.2023 20:59.23.395] [LOG]   No helper found for module: MMM-RandomPhoto.
                [12.10.2023 20:59.23.423] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.423] [LOG]   Module helper loaded: MMM-Lunartic
                [12.10.2023 20:59.23.451] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.451] [LOG]   Module helper loaded: MMM-Lunartic2
                [12.10.2023 20:59.23.451] [LOG]   No helper found for module: MMM-Globe.
                [12.10.2023 20:59.23.451] [LOG]   No helper found for module: MMM-Globe2.
                [12.10.2023 20:59.23.477] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.477] [LOG]   Module helper loaded: MMM-EARTH
                [12.10.2023 20:59.23.478] [LOG]   No helper found for module: MMM-EarthWinds.
                [12.10.2023 20:59.23.480] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.480] [LOG]   Module helper loaded: MMM-MyWastePickup
                [12.10.2023 20:59.23.508] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.508] [LOG]   Module helper loaded: MMM-COVID19-Inc
                [12.10.2023 20:59.23.538] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.538] [LOG]   Module helper loaded: MMM-Todoist
                [12.10.2023 20:59.23.538] [LOG]   No helper found for module: MMM-Gastzugang.
                [12.10.2023 20:59.23.541] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.542] [LOG]   Module helper loaded: mmm-hue-lights
                [12.10.2023 20:59.23.542] [LOG]   No helper found for module: MMM-HolidayLights.
                [12.10.2023 20:59.23.569] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.569] [LOG]   Module helper loaded: MMM-MyStandings
                [12.10.2023 20:59.23.570] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.570] [LOG]   Module helper loaded: MMM-MyScoreboard
                [12.10.2023 20:59.23.570] [LOG]   No helper found for module: clock2.
                [12.10.2023 20:59.23.570] [LOG]   No helper found for module: clock3.
                [12.10.2023 20:59.23.570] [LOG]   No helper found for module: MMM-Xmas.
                [12.10.2023 20:59.23.570] [WARN]  No /Users/patrickhahn/MM/js/../modules/MMM-Snake/MMM-Snake.js found for module: MMM-Snake.
                [12.10.2023 20:59.23.570] [LOG]   No helper found for module: MMM-Snake.
                [12.10.2023 20:59.23.570] [LOG]   Module helper loaded: MMM-Fitbit2
                [12.10.2023 20:59.23.574] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.574] [LOG]   Module helper loaded: MMM-SoccerLiveScore
                [12.10.2023 20:59.23.600] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.600] [LOG]   Module helper loaded: MMM-COVID19-SPARKLINE
                [12.10.2023 20:59.23.641] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.641] [LOG]   Module helper loaded: MMM-rfacts
                [12.10.2023 20:59.23.654] [LOG]   Initializing new module helper ...
                [12.10.2023 20:59.23.655] [LOG]   Module helper loaded: MMM-Screencast
                [12.10.2023 20:59.23.655] [LOG]   All module helpers loaded.
                [12.10.2023 20:59.23.655] [LOG]   Starting server on port 8080 ...
                [12.10.2023 20:59.23.655] [WARN]  You're using a full whitelist configuration to allow for all IPs
                [12.10.2023 20:59.23.657] [LOG]   Server started ...
                [12.10.2023 20:59.23.657] [LOG]   Connecting socket for: MMM-Remote-Control
                [12.10.2023 20:59.23.657] [LOG]   Starting node helper for: MMM-Remote-Control
                [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: updatenotification
                [12.10.2023 20:59.23.661] [LOG]   Starting module helper: updatenotification
                [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: calendar
                [12.10.2023 20:59.23.661] [LOG]   Starting node helper for: calendar
                [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-MyCalendar
                [12.10.2023 20:59.23.661] [LOG]   Starting node helper for: MMM-MyCalendar
                [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-OpenWeatherForecast
                [12.10.2023 20:59.23.661] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
                [12.10.2023 20:59.23.661] [LOG]   MMM-DWD-WarnWeather helper started...
                [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-Sonos
                [12.10.2023 20:59.23.661] [LOG]   Starting module helper: MMM-Sonos
                [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-TelegramBot
                [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-AlexaControl
                [12.10.2023 20:59.23.661] [LOG]   MMM-AlexaControl helper, started...
                [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-DWD-Pollen
                [12.10.2023 20:59.23.661] [LOG]   MMM-DWD-Pollen helper started ...
                [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-Fuel
                [12.10.2023 20:59.23.661] [LOG]   Starting module helper: MMM-Fuel
                [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: newsfeed
                [12.10.2023 20:59.23.662] [LOG]   Starting node helper for: newsfeed
                [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-Tado
                [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-ImagesPhotos
                [12.10.2023 20:59.23.662] [LOG]   Starting node helper for: MMM-ImagesPhotos
                [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-Lunartic
                [12.10.2023 20:59.23.662] [LOG]   Starting node_helper for: MMM-Lunartic
                [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-Lunartic2
                [12.10.2023 20:59.23.662] [LOG]   Starting node_helper for: MMM-Lunartic2
                [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-EARTH
                [12.10.2023 20:59.23.662] [LOG]   Starting module: MMM-EARTH
                [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-MyWastePickup
                [12.10.2023 20:59.23.662] [LOG]   Starting node_helper for module: MMM-MyWastePickup
                [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-COVID19-Inc
                [12.10.2023 20:59.23.662] [LOG]   Starting node helper for: MMM-COVID19-Inc
                [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-Todoist
                [12.10.2023 20:59.23.662] [LOG]   Starting node helper for: MMM-Todoist
                [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: mmm-hue-lights
                [12.10.2023 20:59.23.662] [LOG]   Starting node_helper for module [mmm-hue-lights]
                [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-MyStandings
                [12.10.2023 20:59.23.662] [LOG]   MMM-MyStandings helper started ...
                [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-MyScoreboard
                [12.10.2023 20:59.23.662] [LOG]   Starting node_helper for module [MMM-MyScoreboard]
                [12.10.2023 20:59.23.695] [LOG]   Connecting socket for: MMM-Fitbit2
                [12.10.2023 20:59.23.695] [LOG]   Starting module helper: MMM-Fitbit2
                [12.10.2023 20:59.23.695] [LOG]   Connecting socket for: MMM-SoccerLiveScore
                [12.10.2023 20:59.23.695] [LOG]   Starting node helper for: MMM-SoccerLiveScore
                [12.10.2023 20:59.23.695] [LOG]   Connecting socket for: MMM-COVID19-SPARKLINE
                [12.10.2023 20:59.23.696] [LOG]   Starting node helper for: MMM-COVID19-SPARKLINE
                [12.10.2023 20:59.23.696] [LOG]   Connecting socket for: MMM-rfacts
                [12.10.2023 20:59.23.696] [LOG]   Starting module: MMM-rfacts
                [12.10.2023 20:59.23.696] [LOG]   Connecting socket for: MMM-Screencast
                [12.10.2023 20:59.23.696] [LOG]   Sockets connected & modules started ...
                2023-10-12 20:59:23.714 Electron[13999:65212] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
                [12.10.2023 20:59.23.716] [LOG]   Launching application.
                [12.10.2023 20:59.23.889] [ERROR] ERROR! Could not find main module js file for MMM-Lunartic1
                [12.10.2023 20:59.25.230] [LOG]   Create new calendarfetcher for url: http://p126-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmo7RzjFf-TUZWLk0TuOam3UYf6_Am2G7toTrvToJiYzhItBQd6YHovaHHc7VaXkBx4 - Interval: 3600000
                [12.10.2023 20:59.25.244] [LOG]   Create new calendarfetcher for url: http://p126-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmpj-F2SettLCAt0Uv_YZaqGwSNCegMcedybfhqOCaZ6b0DxoMXJSOezr1VmZHWy9-U - Interval: 3600000
                [12.10.2023 20:59.25.245] [LOG]   Create new calendarfetcher for url: http://p126-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmo1PgYX3cXsO3IVusWJ4iKzb4xm1PfKu7EKUkJ-O4aQPdZpBXeb7r60PaikWG0Kp4A - Interval: 3600000
                [12.10.2023 20:59.25.245] [LOG]   Create new calendarfetcher for url: http://p126-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmo7RzjFf-TUZWLk0TuOam3UYf6_Am2G7toTrvToJiYzhItBQd6YHovaHHc7VaXkBx4 - Interval: 300000
                [12.10.2023 20:59.25.245] [ERROR] Whoops! There was an uncaught exception...
                [12.10.2023 20:59.25.245] [ERROR] TypeError: fetch is not a function
                    at fetchCalendar (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:62:14)
                    at CalendarFetcher.startFetch (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:110:3)
                    at Class.createFetcher (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:73:11)
                    at Class.socketNotificationReceived (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:21:9)
                    at Socket.<anonymous> (/Users/patrickhahn/MM/js/node_helper.js:104:11)
                    at Socket.emit (node:events:513:28)
                    at Socket.emitUntyped (/Users/patrickhahn/MM/node_modules/socket.io/dist/typed-events.js:69:22)
                    at /Users/patrickhahn/MM/node_modules/socket.io/dist/socket.js:704:39
                    at processTicksAndRejections (node:internal/process/task_queues:77:11)
                [12.10.2023 20:59.25.245] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [12.10.2023 20:59.25.245] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                [12.10.2023 20:59.25.245] [LOG]   Create new calendarfetcher for url: http://p126-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmpj-F2SettLCAt0Uv_YZaqGwSNCegMcedybfhqOCaZ6b0DxoMXJSOezr1VmZHWy9-U - Interval: 300000
                [12.10.2023 20:59.25.246] [ERROR] TypeError: fetch is not a function
                [12.10.2023 20:59.25.246] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [12.10.2023 20:59.25.246] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                [12.10.2023 20:59.25.246] [LOG]   Create new calendarfetcher for url: http://p126-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmo1PgYX3cXsO3IVusWJ4iKzb4xm1PfKu7EKUkJ-O4aQPdZpBXeb7r60PaikWG0Kp4A - Interval: 300000
                [12.10.2023 20:59.25.246] [ERROR] Whoops! There was an uncaught exception...
                  @Stoffbeuteluwe show the output from where we have npm start so we can see what the messages are
                      @Stoffbeuteluwe said in Update is not working..I need help please:
                      don’t know why.
                      StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                        Anyway, thank you very much for your help
                        greetings from Germany
                          the solution is to change the line 11 an 12 of calendarfetcher.js to this …
                          /*const fetch = require("fetch");*/
                          /*const digest = require("digest-fetch");*/
                          now it works :folded_hands: :smiling_face_with_sunglasses:
                            @Stoffbeuteluwe awesome. thanks for the feedback
                            • 2 / 3
