    Update is not working..I need help please
    41 Posts 5 Posters 22.2k Views 5 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @sdetweil
      I think I have to live without MMM-MyCalendar and try the default calendar
      without MMM-MyCalender module …the Mirror works fine
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe but u can fix mycalendar
        see the output of npm start
        it’s likely the node-fetch lib we removed
        just add it back.in the module folder
        see
        for how to update the module
        StoffbeuteluweS 1 Reply Last reply
        • StoffbeuteluweS
          i have installed fetch and digest-fetch but it won’t start
          Last login: Thu Oct 12 18:10:21 on ttys000
          patrickhahn@Mac-mini ~ % cd MM
          patrickhahn@Mac-mini MM % npm start
          > magicmirror@2.25.0 start
          [12.10.2023 18:13.01.206] [LOG]   Starting MagicMirror: v2.25.0
          [12.10.2023 18:13.01.207] [LOG]   Loading config ...
          [12.10.2023 18:13.01.207] [DEBUG] config template file not exists, no envsubst
          [12.10.2023 18:13.01.208] [LOG]   Loading module helpers ...
          [12.10.2023 18:13.01.208] [LOG]   No helper found for module: alert.
          [12.10.2023 18:13.01.232] [LOG]   Initializing new module helper ...
          [12.10.2023 18:13.01.233] [LOG]   Module helper loaded: MMM-Remote-Control
          [12.10.2023 18:13.01.233] [LOG]   Initializing new module helper ...
          [12.10.2023 18:13.01.233] [LOG]   Module helper loaded: updatenotification
          [12.10.2023 18:13.01.233] [LOG]   No helper found for module: MMM-Snow.
          [12.10.2023 18:13.01.233] [LOG]   No helper found for module: MMM-MyWordClock.
          [12.10.2023 18:13.01.233] [LOG]   No helper found for module: clock.
          [12.10.2023 18:13.01.233] [LOG]   No helper found for module: calendar_monthly.
          [12.10.2023 18:13.01.251] [LOG]   Initializing new module helper ...
          [12.10.2023 18:13.01.251] [LOG]   Module helper loaded: calendar
          [12.10.2023 18:13.01.252] [ERROR] (node:2102) UnhandledPromiseRejectionWarning: Error: Cannot find module 'fetch'
          Require stack:
          - /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js
          - /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js
          - /Users/patrickhahn/MM/js/app.js
          - /Users/patrickhahn/MM/js/electron.js
          - /Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/Resources/default_app.asar/main.js
              at node:internal/modules/cjs/loader:1084:15
              at Function.<anonymous> (node:electron/js2c/browser_init:2:117576)
              at Module._resolveFilename (/Users/patrickhahn/MM/node_modules/module-alias/index.js:49:29)
              at node:internal/modules/cjs/loader:929:27
              at Function._load (node:electron/js2c/asar_bundle:2:13327)
              at Module.require (node:internal/modules/cjs/loader:1150:19)
              at require (node:internal/modules/cjs/helpers:110:18)
              at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:11:15)
              at Module._compile (node:internal/modules/cjs/loader:1271:14)
              at Object..js (node:internal/modules/cjs/loader:1326:10)
              at Module.load (node:internal/modules/cjs/loader:1126:32)
              at node:internal/modules/cjs/loader:967:12
              at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:8:25)
          (Use `Electron --trace-warnings ...` to show where the warning was created)
          [12.10.2023 18:13.01.252] [ERROR] (node:2102) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          2023-10-12 18:13:01.270 Electron[2102:3348103] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
          ^C/Users/patrickhahn/MM/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron exited with signal SIGINT
          patrickhahn@Mac-mini MM % cd modules
          patrickhahn@Mac-mini modules % cd MMM-MyCalendar
          patrickhahn@Mac-mini MMM-MyCalendar % ls package.json
          ls: package.json: No such file or directory
          patrickhahn@Mac-mini MMM-MyCalendar % npm init -y
          Wrote to /Users/patrickhahn/MM/modules/MMM-MyCalendar/package.json:
            "name": "mmm-mycalendar",
            "version": "1.0.0",
            "description": "This calendar module is functionally the same as the default calendar app, however its presentation is different.",
            "main": "MMM-MyCalendar.js",
            "scripts": {
              "test": "echo \"Error: no test specified\" && exit 1"
            "keywords": [],
            "author": "",
            "license": "ISC"
          patrickhahn@Mac-mini MMM-MyCalendar % npm install fetch
          added 6 packages, and audited 7 packages in 2s
          found 0 vulnerabilities
          patrickhahn@Mac-mini MMM-MyCalendar % cd
          [12.10.2023 18:14.34.291] [LOG]   Starting MagicMirror: v2.25.0
          [12.10.2023 18:14.34.292] [LOG]   Loading config ...
          [12.10.2023 18:14.34.292] [DEBUG] config template file not exists, no envsubst
          [12.10.2023 18:14.34.293] [LOG]   Loading module helpers ...
          [12.10.2023 18:14.34.293] [LOG]   No helper found for module: alert.
          [12.10.2023 18:14.34.317] [LOG]   Initializing new module helper ...
          [12.10.2023 18:14.34.317] [LOG]   Module helper loaded: MMM-Remote-Control
          [12.10.2023 18:14.34.318] [LOG]   Initializing new module helper ...
          [12.10.2023 18:14.34.318] [LOG]   Module helper loaded: updatenotification
          [12.10.2023 18:14.34.318] [LOG]   No helper found for module: MMM-Snow.
          [12.10.2023 18:14.34.318] [LOG]   No helper found for module: MMM-MyWordClock.
          [12.10.2023 18:14.34.318] [LOG]   No helper found for module: clock.
          [12.10.2023 18:14.34.318] [LOG]   No helper found for module: calendar_monthly.
          [12.10.2023 18:14.34.336] [LOG]   Initializing new module helper ...
          [12.10.2023 18:14.34.336] [LOG]   Module helper loaded: calendar
          [12.10.2023 18:14.34.339] [ERROR] (node:2138) UnhandledPromiseRejectionWarning: Error: Cannot find module 'digest-fetch'
          Require stack:
              at Object.<anonymous> (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:12:16)
          [12.10.2023 18:14.34.339] [ERROR] (node:2138) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          2023-10-12 18:14:34.356 Electron[2138:3349277] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
            "version": "1.0.0",
            "scripts": {
            "keywords": [],
            "author": "",
            "license": "ISC",
            "dependencies": {
              "fetch": "^1.1.0"
            "devDependencies": {}
          patrickhahn@Mac-mini MMM-MyCalendar % npm install digest-fetch
          added 8 packages, and audited 15 packages in 2s
          [12.10.2023 18:16.37.004] [LOG]   Starting MagicMirror: v2.25.0
          [12.10.2023 18:16.37.005] [LOG]   Loading config ...
          [12.10.2023 18:16.37.005] [DEBUG] config template file not exists, no envsubst
          [12.10.2023 18:16.37.006] [LOG]   Loading module helpers ...
          [12.10.2023 18:16.37.006] [LOG]   No helper found for module: alert.
          [12.10.2023 18:16.37.030] [LOG]   Initializing new module helper ...
          [12.10.2023 18:16.37.030] [LOG]   Module helper loaded: MMM-Remote-Control
          [12.10.2023 18:16.37.031] [LOG]   Initializing new module helper ...
          [12.10.2023 18:16.37.031] [LOG]   Module helper loaded: updatenotification
          [12.10.2023 18:16.37.031] [LOG]   No helper found for module: MMM-Snow.
          [12.10.2023 18:16.37.031] [LOG]   No helper found for module: MMM-MyWordClock.
          [12.10.2023 18:16.37.031] [LOG]   No helper found for module: clock.
          [12.10.2023 18:16.37.031] [LOG]   No helper found for module: calendar_monthly.
          [12.10.2023 18:16.37.049] [LOG]   Initializing new module helper ...
          [12.10.2023 18:16.37.049] [LOG]   Module helper loaded: calendar
          [12.10.2023 18:16.37.060] [ERROR] (node:2177) UnhandledPromiseRejectionWarning: Error [ERR_REQUIRE_ESM]: require() of ES Module /Users/patrickhahn/MM/modules/MMM-MyCalendar/node_modules/digest-fetch/digest-fetch-src.js from /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js not supported.
          Instead change the require of digest-fetch-src.js in /Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules.
              at loadModule (/Users/patrickhahn/MM/js/app.js:180:19)
              at loadModules (/Users/patrickhahn/MM/js/app.js:210:10)
              at async App.start (/Users/patrickhahn/MM/js/app.js:258:3)
          [12.10.2023 18:16.37.060] [ERROR] (node:2177) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          2023-10-12 18:16:37.079 Electron[2177:3350680] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
          S mumblebajM 2 Replies Last reply
            @Stoffbeuteluwe the default digest-fetch expects a different runtime…
            they say to do this in the module folder
            npm install digest-fetch@v2 node-fetch@v2
            • mumblebajM
              mumblebaj Module Developer @Stoffbeuteluwe
              @Stoffbeuteluwe Seems like you may have installed the wrong version of digest-fetch. You have a later version than what the module handles looks like to me. Not sure what version the module requires.
              • StoffbeuteluweS
                Stoffbeuteluwe Project Sponsor @mumblebaj
                @mumblebaj @sdetweil
                Yeah Yeah it works …a big THANK YOU to you
                without you guys I wouldn’t have made it:clapping_hands: :grinning_face_with_big_eyes:
                  @Stoffbeuteluwe awesome!! thanks for the feedback
                  • StoffbeuteluweS
                    Hello, I was happy a little too early…
                    the mirror starts but the calendar module says loading now
                    Do you have an idea what could be causing this?
                    I haven’t changed the config.
                    Last login: Thu Oct 12 20:53:00 on ttys000
                    [12.10.2023 20:59.23.100] [LOG]   Starting MagicMirror: v2.25.0
                    [12.10.2023 20:59.23.101] [LOG]   Loading config ...
                    [12.10.2023 20:59.23.101] [DEBUG] config template file not exists, no envsubst
                    [12.10.2023 20:59.23.102] [LOG]   Loading module helpers ...
                    [12.10.2023 20:59.23.102] [LOG]   No helper found for module: alert.
                    [12.10.2023 20:59.23.127] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.127] [LOG]   Module helper loaded: MMM-Remote-Control
                    [12.10.2023 20:59.23.129] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.129] [LOG]   Module helper loaded: updatenotification
                    [12.10.2023 20:59.23.129] [LOG]   No helper found for module: MMM-Snow.
                    [12.10.2023 20:59.23.129] [LOG]   No helper found for module: MMM-MyWordClock.
                    [12.10.2023 20:59.23.129] [LOG]   No helper found for module: clock.
                    [12.10.2023 20:59.23.129] [LOG]   No helper found for module: calendar_monthly.
                    [12.10.2023 20:59.23.148] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.148] [LOG]   Module helper loaded: calendar
                    [12.10.2023 20:59.23.157] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.157] [LOG]   Module helper loaded: MMM-MyCalendar
                    [12.10.2023 20:59.23.157] [LOG]   No helper found for module: compliments.
                    [12.10.2023 20:59.23.162] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.162] [LOG]   Module helper loaded: MMM-OpenWeatherForecast
                    [12.10.2023 20:59.23.162] [WARN]  No /Users/patrickhahn/MM/js/../modules/weatherforecast/weatherforecast.js found for module: weatherforecast.
                    [12.10.2023 20:59.23.162] [LOG]   No helper found for module: weatherforecast.
                    [12.10.2023 20:59.23.166] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.166] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
                    [12.10.2023 20:59.23.178] [LOG]   Module helper loaded: MMM-Sonos
                    [12.10.2023 20:59.23.254] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.254] [LOG]   Module helper loaded: MMM-TelegramBot
                    [12.10.2023 20:59.23.283] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.283] [LOG]   Module helper loaded: MMM-AlexaControl
                    [12.10.2023 20:59.23.314] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.314] [LOG]   Module helper loaded: MMM-DWD-Pollen
                    [12.10.2023 20:59.23.314] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.25.0
                    [12.10.2023 20:59.23.314] [LOG]   Version is ok!
                    [12.10.2023 20:59.23.314] [LOG]   Module helper loaded: MMM-Fuel
                    [12.10.2023 20:59.23.325] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.325] [LOG]   Module helper loaded: newsfeed
                    [12.10.2023 20:59.23.325] [LOG]   No helper found for module: helloworld.
                    [12.10.2023 20:59.23.366] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.366] [LOG]   Module helper loaded: MMM-Tado
                    [12.10.2023 20:59.23.367] [LOG]   No helper found for module: MMM-YouTube.
                    [12.10.2023 20:59.23.367] [LOG]   No helper found for module: MMM-EasyBack.
                    [12.10.2023 20:59.23.394] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.394] [LOG]   Module helper loaded: MMM-ImagesPhotos
                    [12.10.2023 20:59.23.395] [LOG]   No helper found for module: MMM-EasyPix.
                    [12.10.2023 20:59.23.395] [LOG]   No helper found for module: MMM-EyeCandy.
                    [12.10.2023 20:59.23.395] [LOG]   No helper found for module: MMM-SimpleLogo.
                    [12.10.2023 20:59.23.395] [LOG]   No helper found for module: MMM-RandomPhoto.
                    [12.10.2023 20:59.23.423] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.423] [LOG]   Module helper loaded: MMM-Lunartic
                    [12.10.2023 20:59.23.451] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.451] [LOG]   Module helper loaded: MMM-Lunartic2
                    [12.10.2023 20:59.23.451] [LOG]   No helper found for module: MMM-Globe.
                    [12.10.2023 20:59.23.451] [LOG]   No helper found for module: MMM-Globe2.
                    [12.10.2023 20:59.23.477] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.477] [LOG]   Module helper loaded: MMM-EARTH
                    [12.10.2023 20:59.23.478] [LOG]   No helper found for module: MMM-EarthWinds.
                    [12.10.2023 20:59.23.480] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.480] [LOG]   Module helper loaded: MMM-MyWastePickup
                    [12.10.2023 20:59.23.508] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.508] [LOG]   Module helper loaded: MMM-COVID19-Inc
                    [12.10.2023 20:59.23.538] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.538] [LOG]   Module helper loaded: MMM-Todoist
                    [12.10.2023 20:59.23.538] [LOG]   No helper found for module: MMM-Gastzugang.
                    [12.10.2023 20:59.23.541] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.542] [LOG]   Module helper loaded: mmm-hue-lights
                    [12.10.2023 20:59.23.542] [LOG]   No helper found for module: MMM-HolidayLights.
                    [12.10.2023 20:59.23.569] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.569] [LOG]   Module helper loaded: MMM-MyStandings
                    [12.10.2023 20:59.23.570] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.570] [LOG]   Module helper loaded: MMM-MyScoreboard
                    [12.10.2023 20:59.23.570] [LOG]   No helper found for module: clock2.
                    [12.10.2023 20:59.23.570] [LOG]   No helper found for module: clock3.
                    [12.10.2023 20:59.23.570] [LOG]   No helper found for module: MMM-Xmas.
                    [12.10.2023 20:59.23.570] [WARN]  No /Users/patrickhahn/MM/js/../modules/MMM-Snake/MMM-Snake.js found for module: MMM-Snake.
                    [12.10.2023 20:59.23.570] [LOG]   No helper found for module: MMM-Snake.
                    [12.10.2023 20:59.23.570] [LOG]   Module helper loaded: MMM-Fitbit2
                    [12.10.2023 20:59.23.574] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.574] [LOG]   Module helper loaded: MMM-SoccerLiveScore
                    [12.10.2023 20:59.23.600] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.600] [LOG]   Module helper loaded: MMM-COVID19-SPARKLINE
                    [12.10.2023 20:59.23.641] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.641] [LOG]   Module helper loaded: MMM-rfacts
                    [12.10.2023 20:59.23.654] [LOG]   Initializing new module helper ...
                    [12.10.2023 20:59.23.655] [LOG]   Module helper loaded: MMM-Screencast
                    [12.10.2023 20:59.23.655] [LOG]   All module helpers loaded.
                    [12.10.2023 20:59.23.655] [LOG]   Starting server on port 8080 ...
                    [12.10.2023 20:59.23.655] [WARN]  You're using a full whitelist configuration to allow for all IPs
                    [12.10.2023 20:59.23.657] [LOG]   Server started ...
                    [12.10.2023 20:59.23.657] [LOG]   Connecting socket for: MMM-Remote-Control
                    [12.10.2023 20:59.23.657] [LOG]   Starting node helper for: MMM-Remote-Control
                    [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: updatenotification
                    [12.10.2023 20:59.23.661] [LOG]   Starting module helper: updatenotification
                    [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: calendar
                    [12.10.2023 20:59.23.661] [LOG]   Starting node helper for: calendar
                    [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-MyCalendar
                    [12.10.2023 20:59.23.661] [LOG]   Starting node helper for: MMM-MyCalendar
                    [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-OpenWeatherForecast
                    [12.10.2023 20:59.23.661] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
                    [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
                    [12.10.2023 20:59.23.661] [LOG]   MMM-DWD-WarnWeather helper started...
                    [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-Sonos
                    [12.10.2023 20:59.23.661] [LOG]   Starting module helper: MMM-Sonos
                    [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-TelegramBot
                    [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-AlexaControl
                    [12.10.2023 20:59.23.661] [LOG]   MMM-AlexaControl helper, started...
                    [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-DWD-Pollen
                    [12.10.2023 20:59.23.661] [LOG]   MMM-DWD-Pollen helper started ...
                    [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: MMM-Fuel
                    [12.10.2023 20:59.23.661] [LOG]   Starting module helper: MMM-Fuel
                    [12.10.2023 20:59.23.661] [LOG]   Connecting socket for: newsfeed
                    [12.10.2023 20:59.23.662] [LOG]   Starting node helper for: newsfeed
                    [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-Tado
                    [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-ImagesPhotos
                    [12.10.2023 20:59.23.662] [LOG]   Starting node helper for: MMM-ImagesPhotos
                    [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-Lunartic
                    [12.10.2023 20:59.23.662] [LOG]   Starting node_helper for: MMM-Lunartic
                    [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-Lunartic2
                    [12.10.2023 20:59.23.662] [LOG]   Starting node_helper for: MMM-Lunartic2
                    [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-EARTH
                    [12.10.2023 20:59.23.662] [LOG]   Starting module: MMM-EARTH
                    [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-MyWastePickup
                    [12.10.2023 20:59.23.662] [LOG]   Starting node_helper for module: MMM-MyWastePickup
                    [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-COVID19-Inc
                    [12.10.2023 20:59.23.662] [LOG]   Starting node helper for: MMM-COVID19-Inc
                    [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-Todoist
                    [12.10.2023 20:59.23.662] [LOG]   Starting node helper for: MMM-Todoist
                    [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: mmm-hue-lights
                    [12.10.2023 20:59.23.662] [LOG]   Starting node_helper for module [mmm-hue-lights]
                    [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-MyStandings
                    [12.10.2023 20:59.23.662] [LOG]   MMM-MyStandings helper started ...
                    [12.10.2023 20:59.23.662] [LOG]   Connecting socket for: MMM-MyScoreboard
                    [12.10.2023 20:59.23.662] [LOG]   Starting node_helper for module [MMM-MyScoreboard]
                    [12.10.2023 20:59.23.695] [LOG]   Connecting socket for: MMM-Fitbit2
                    [12.10.2023 20:59.23.695] [LOG]   Starting module helper: MMM-Fitbit2
                    [12.10.2023 20:59.23.695] [LOG]   Connecting socket for: MMM-SoccerLiveScore
                    [12.10.2023 20:59.23.695] [LOG]   Starting node helper for: MMM-SoccerLiveScore
                    [12.10.2023 20:59.23.695] [LOG]   Connecting socket for: MMM-COVID19-SPARKLINE
                    [12.10.2023 20:59.23.696] [LOG]   Starting node helper for: MMM-COVID19-SPARKLINE
                    [12.10.2023 20:59.23.696] [LOG]   Connecting socket for: MMM-rfacts
                    [12.10.2023 20:59.23.696] [LOG]   Starting module: MMM-rfacts
                    [12.10.2023 20:59.23.696] [LOG]   Connecting socket for: MMM-Screencast
                    [12.10.2023 20:59.23.696] [LOG]   Sockets connected & modules started ...
                    2023-10-12 20:59:23.714 Electron[13999:65212] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
                    [12.10.2023 20:59.23.716] [LOG]   Launching application.
                    [12.10.2023 20:59.23.889] [ERROR] ERROR! Could not find main module js file for MMM-Lunartic1
                    [12.10.2023 20:59.25.230] [LOG]   Create new calendarfetcher for url: http://p126-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmo7RzjFf-TUZWLk0TuOam3UYf6_Am2G7toTrvToJiYzhItBQd6YHovaHHc7VaXkBx4 - Interval: 3600000
                    [12.10.2023 20:59.25.244] [LOG]   Create new calendarfetcher for url: http://p126-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmpj-F2SettLCAt0Uv_YZaqGwSNCegMcedybfhqOCaZ6b0DxoMXJSOezr1VmZHWy9-U - Interval: 3600000
                    [12.10.2023 20:59.25.245] [LOG]   Create new calendarfetcher for url: http://p126-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmo1PgYX3cXsO3IVusWJ4iKzb4xm1PfKu7EKUkJ-O4aQPdZpBXeb7r60PaikWG0Kp4A - Interval: 3600000
                    [12.10.2023 20:59.25.245] [LOG]   Create new calendarfetcher for url: http://p126-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmo7RzjFf-TUZWLk0TuOam3UYf6_Am2G7toTrvToJiYzhItBQd6YHovaHHc7VaXkBx4 - Interval: 300000
                    [12.10.2023 20:59.25.245] [ERROR] Whoops! There was an uncaught exception...
                    [12.10.2023 20:59.25.245] [ERROR] TypeError: fetch is not a function
                        at fetchCalendar (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:62:14)
                        at CalendarFetcher.startFetch (/Users/patrickhahn/MM/modules/MMM-MyCalendar/calendarfetcher.js:110:3)
                        at Class.createFetcher (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:73:11)
                        at Class.socketNotificationReceived (/Users/patrickhahn/MM/modules/MMM-MyCalendar/node_helper.js:21:9)
                        at Socket.<anonymous> (/Users/patrickhahn/MM/js/node_helper.js:104:11)
                        at Socket.emit (node:events:513:28)
                        at Socket.emitUntyped (/Users/patrickhahn/MM/node_modules/socket.io/dist/typed-events.js:69:22)
                        at /Users/patrickhahn/MM/node_modules/socket.io/dist/socket.js:704:39
                        at processTicksAndRejections (node:internal/process/task_queues:77:11)
                    [12.10.2023 20:59.25.245] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [12.10.2023 20:59.25.245] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [12.10.2023 20:59.25.245] [LOG]   Create new calendarfetcher for url: http://p126-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmpj-F2SettLCAt0Uv_YZaqGwSNCegMcedybfhqOCaZ6b0DxoMXJSOezr1VmZHWy9-U - Interval: 300000
                    [12.10.2023 20:59.25.246] [ERROR] TypeError: fetch is not a function
                    [12.10.2023 20:59.25.246] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [12.10.2023 20:59.25.246] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [12.10.2023 20:59.25.246] [LOG]   Create new calendarfetcher for url: http://p126-caldav.icloud.com/published/2/MjAwMTgyNjQ0NTIwMDE4Mp2LsX_-xfYBCZZDkkcAhmo1PgYX3cXsO3IVusWJ4iKzb4xm1PfKu7EKUkJ-O4aQPdZpBXeb7r60PaikWG0Kp4A - Interval: 300000
                    [12.10.2023 20:59.25.246] [ERROR] Whoops! There was an uncaught exception...
                      @Stoffbeuteluwe show the output from where we have npm start so we can see what the messages are
                      • StoffbeuteluweS
                          @Stoffbeuteluwe said in Update is not working..I need help please:
                          don’t know why.
                          StoffbeuteluweS 2 Replies Last reply
                          • StoffbeuteluweS
                            Anyway, thank you very much for your help
                            greetings from Germany
                            • StoffbeuteluweS
                              the solution is to change the line 11 an 12 of calendarfetcher.js to this …
                              /*const fetch = require("fetch");*/
                              /*const digest = require("digest-fetch");*/
                              now it works :folded_hands: :smiling_face_with_sunglasses:
                              Reply Quote 2
                                @Stoffbeuteluwe awesome. thanks for the feedback
                                • 2 / 3
