    Which calendar modul is able to get Nextcloud (WebDAV) calendars synchronized?
    9 Posts 3 Posters 2.7k Views 3 Watching
      bdream
      Since the release in which the digest fetch was removed I cant get my personal calendars visible where I need the authentication.
      I did it within the URL in plain text. Hope there is a more secret way available now :winking_face:
      url: "https://USERNAME:SECRET@DOMAIN.TLD/NextCloud/remote.php/dav/calendars/USERNAME/pers%c3%b6nlich?export"
      cheers, bdream
        MMRIZE @bdream
        @bdream
        Not tested in Nextcloud so I cannot promise,
        But you can try https://github.com/MMRIZE/MMM-CalDAV
          bdream @MMRIZE
          @MMRIZE I tried it out but what I see is:
          my config her should should show some entries for recycling stuff.
          I didn’t use the credential stuff at this point.
                                  module: "MMM-CalDAV",
                                  position: "bottom_left",
                                      serverurl: "https://www.fes-frankfurt.de/abfallkalender/QWx0ZSBGYWhydHwxMXw2MDQzNw%3D%3D.ics",
                                  vcalendarHeader: false
          cheers, bdream
            MMRIZE @bdream
            @bdream
            First, this works in the background, so you don’t have to set the position of this module.
            Second. the proper propertyname is serverUrl not serverurl
            Third. Your url is not CalDAV server url, it was just plain iCal format .ics. You can use the default calendar module to present events in that iCal.
            The purpose of this module is to connect CALDAV server (Maybe your NextCloud), then get its calendar events and convert them to MM-understandable formal .ics file. (To use the file as a feed of the default calendar module or other .ics feeding module)
            So if this is not your goal, search another way.
              bdream @MMRIZE
              @MMRIZE
              position: how do the MM know where to display?
              serverUrl: seriously. Thansk!
              .ics: you are right. That was a try after I got the error using credentials.
              I wantet so see if this module is working.
              Error shown by: npm run config:check
              Your configuration file contains syntax errors :(
              but I use
                                            serverUrl: "https://DOMAIN.TDL/NEXTCLOUD/remote.php/dav/calendars/USER/pers%c3%b6nlich/"
                                            credentials: {
                                              username: "USER",
                                              password: "GEHEIM",
                                          vcalendarHeader: true
              cheers, bdream
              mumblebajM M 2 Replies Last reply Reply Quote 0
              • mumblebajM Offline
                mumblebaj Module Developer @bdream
                @bdream You are missing a comma after the serverUrl
                  bdream
                  @mumblebaj you are right. My bad!
                  Now it runs without failure but also without displaying the calendar.
                  I deleted already position: "bottom_left",
                  What module do I need to activate for display and how do I get the CalDAV module linked?
                  cheers, bdream
                    MMRIZE @bdream
                    @bdream
                    When you need oauth to use your Caldav server, I’ll upgrade the module sooner. Currently this module supports only basic auto.
                      MMRIZE @bdream
                      @bdream
                      “http://YOURMM/modules/MMM-CalDAV/public/Test.ics” would be accessible. (See under the public directory of module.)
                      Now you can use this as a ics feed and f default calendar module.
