    MMM-Flights does not work
    8 Posts 3 Posters 1.3k Views 3 Watching
      Mats
      This is the error I see in the log after installing and restarting MagicMirror:
      0|mm | [13.10.2023 19:35.37.312] [ERROR] MMM-Flights: unknown error getting data SyntaxError: Unexpected token ‘:’
      I use the proposed minimal config setup in config.js
            module: "MMM-Flights",
              laMin: 50.0,
              laMax: 50.21,
              loMin: 8.4,
              loMax: 8.8,
      karsten13K 2 Replies Last reply Reply Quote 0
      • karsten13K Offline
        karsten13 @Mats
        @Mats
        can confirm this error, will try to fix it later
          karsten13 @Mats
          @Mats
          the problem is caused by changes on the flightradar side, I already opened an issue: https://github.com/derhuerst/flightradar24-client/issues/36
          A quick and dirty fix would be to go into the module folder (from mm folder) with cd modules/MMM-Flights and then edit the followoing file e.g. with nano nano node_modules/flightradar24-client/lib/radar.js and replace the line at the beginning of the file
          const endpoint = 'https://data-live.flightradar24.com/zones/fcgi/feed.js'
          with
          const endpoint = 'https://data-cloud.flightradar24.com/zones/fcgi/feed.js'
          Other possibilities:
          • wait for a fix
          • you can use another provider in MMM-Flights
            Mats @karsten13
            @karsten13
            That has worked - thank you!
            • lavolp3L lavolp3 moved this topic from Transport on
              karsten13 @Mats
              @Mats
              issue was fixed upstream so I released a new (fixed) version
                james3xyx3 @karsten13
                @karsten13 sorry to jump on this thread with my query, hope you can advise. I added Flights module just now and love it. Only thing is I don’t understand fully the coordinates. If I enter the coordinates of my area and duplicate for min and max it produces a fairly small map of my area. When I try and add a min and max value of areas close to me it defaults to a world map! Can you advise as to what I may be doing wrong? I appreciate this may be difficult without knowing the exact coordinates I am entering.
                  karsten13 @james3xyx3
                  @james3xyx3
                  maybe better explained with
                  laMax: Northern edge latitude
                  laMin: Southern edge latitude
                  loMin: Western edge longitude
                  loMax: Eastern edge longitude
                    @karsten13 That makes much more sense to me now. Will try it tomorrow. Thanks for the quick reply and support, much appreciated.
