    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
      MMRIZE @roth_nj
      @roth_nj
      You don’t have to read entire posts on this thread. Just read the README md first.
      And there is the feature description of what you want probably.
        roth_nj @hrmax23
        @hrmax23 said in MMM-CalendarExt3:
        @MMRIZE Is there a way to show a rolling 4/5 week in the month mode? Basically something like -1 week to +3 weeks rather than showing basically the current month until that month is over.
        Also, is there a trick to get the calendar to re-render completely on some interval? On my MM right now, it’s currently showing the current day in the 5th week (i.e. still showing April as the current month). If I restart MM, it will update to show May as current month, but doesn’t seem to do it automatically. I only have 1 scene so not using MMM-Scenes.
        @MMRIZE said in MMM-CalendarExt3:
        @roth_nj
        i did. again, im new to all of this. i am not a programmer at all in any sense. im an ME but did have to take a c++ course like 20 years ago. my brain just doesn’t see this stuff easily. i can read through the readme’s for various modules and get the basic functions but then i have been reading through all the trouble shooting threads about them to get a better understanding on how to actually do it.
        at this point im guessing something on the css level with transforming or preprocessing the data?
        • BKeyportB
          BKeyport Module Developer @MMRIZE
          @MMRIZE the background highlighting issue is shown in my screenshot. If you look at October 11 in the shot, you’ll notice the highlight is smaller than the text.
          Same goes for the full day event shown on Nov 2, the highlight is blocking the “2” partially.
          That being said, I’m gonna work on expanding my module to do a big calendar instead. I’m not getting what I want even with monkeypatch, and it’s getting too confused.
          M 1 Reply Last reply
            bicolorbore586 @roth_nj
            @roth_nj in the config of the module set the ‘mode’ to week. The add the config option ‘weeksInView’ and set that to 4 or 5
            Here’s an extract from mine:
            			module: "MMM-CalendarExt3",
            			position: "lower_third",
            				mode: "week",
            				weekIndex: 0,
            				weeksInView: 5,
            As MMRIZE says, it’s in the readme file (under config details). The re-render, as you say is also listed in there, as one of the intervals.
            R 1 Reply Last reply
              roth_nj @bicolorbore586
              @bicolorbore586 said in MMM-CalendarExt3:
              				mode: "week",
              				weekIndex: 0,
              				weeksInView: 5,
              thanks… trust me, i read all that stuff a number of times. it just didn’t click that thats what i meant. im going to go bang my head against the wall now ha ha
              • A
                aircliff
                Have another issue I just recently noticed. I have two different modules running, one in day view showing one week worth of calendar. The other is in month view. The day view is set with dayIndex of 0 so the current day is the first day. Day 7 on the view shows no events although they are shown for that day on the month view calendar. I could not find any similar posts with issues in this thread so hoping someone has seen and can provide some help. Here are screenshots for reference. It is always the last day in the day view, so for right now Tuesday the 24th is where the issue lies. I’ve changed weeksInView to 2 and it was always just the last day of the series.
                Week View:
                Month View:
                M 2 Replies Last reply
                  MMRIZE @aircliff
                  @aircliff
                  Maybe the bug. I’ll inspect it. :)
                    MMRIZE @aircliff
                    @aircliff
                    I found where the bug lies on.
                    https://github.com/MMRIZE/MMM-CalendarExt3/blob/28c3aeabfbc5b0ebc28107831dcbacd125578d0a/MMM-CalendarExt3.js#L436
                    I’ll fix it tomorrow. :)
                    A 1 Reply Last reply
                    • A
                      aircliff @MMRIZE
                      @MMRIZE
                      Thank you. I actually played with it quite a bit last week and specifically that line and couldn’t get it to work for me. I would end up adding a second week or multiple extra days. Interested to see what you find as the fix.
                        MMRIZE @aircliff
                        @aircliff
                        fixed. (1.6.1)
                        https://github.com/MMRIZE/MMM-CalendarExt3#history
                          MMRIZE @BKeyport
                          @BKeyport said in MMM-CalendarExt3:
                          give enough height to cell header
                          Your height of cellHeader is smaller than the fontsize used.
                          By default it is defined as --cellheaderheight
                          As I showed you, it is possible, but it doesn’t mean easy.
                          Anyway, this module is not designed to show events like that, however, I introduced to you how to override by monkey-patching, but if you are not satisfied, the only way would be to build a new module for that purpose.
                          • A
                            aircliff @MMRIZE
                            @MMRIZE
                            Worked like a champ. Thanks for the help.
                              roth_nj
                              Formatting question… not sure if it’s best for to ask here or some place else….
                              I currently have the icons turned off, and 6 color coded calendars being displayed. Right now there is the small colored dot next to each and I have it color coded and the legend turned on and that’s all good….
                              How would I go about formatting each entry so it has the “apple” look? Like a light shaded transparent box around each entry that pulled the tint from the calendar color. Also I would then off the colored dots
                                MMRIZE @roth_nj
                                @roth_nj
                                I think it could be achieved by CSS modification. However, without details, I cannot guess what you exactly want. Do you have a sketch for it?
                                (By default, this module is designed to imitate the Apple calendar app or Fantastical app. I’m sorry if you think it doesn’t look alike. )
                                  roth_nj @MMRIZE
                                  @roth_nj
                                  sorry if theres any misunderstanding. i think the module is great and works awesome. i have my pi hooked up to a 40" tv that i am going to frame and hang. so with the detail and how close just trying to tweak the visuals now that i have everything functioning well. one of the things i’ve noticed with my set up is the contrast between all the white text and black background. from what i’ve researched it is a drawback to using a TV instead of a computer monitor or smaller device. adjusting the contrast/brightness on the tv itself made the pictures look like crap. i think this will help a by separating the white text from the black background.
                                  what i meant is to have the type of transparent tinted box around (or behind) the calendar entry texts in the style of apples current design looks. heres a quick think i made in powerpoint.
                                  thank you again for all you help
                                    MMRIZE @roth_nj
                                    @roth_nj
                                    By default, without any modification; This module has 2 style metaphor for event. One is for fullday/multidays event and one is for normal event.
                                    Fullday/multidays event looks a boxed, background-filled to be distinguished with a normal event.
                                    Anyway, if you want that a normal event has same looks with fullday events - boxed and filled.
                                    Add these lines to your custom.css
                                    .CX3 .event.singleday .headline:not(.useSymbol)::before,
                                    .CX3 .event.singleday .headline.useSymbol .symbol.noSymbol::before {
                                      display: none;
                                    .CX3 .event.singleday {
                                      background-color: var(--calendarColor);
                                      mix-blend-mode: difference;
                                      border-radius: 4px;
                                      color: var(--oppositeColor);
                                    .CX3 .event:not(.fullday) .headline .time {
                                      MMRIZE
                                      [UPDATE] 1.7.0
                                      • skip of event Object property (Example)
                                      • skipPassedEventToday of config
                                      • eventTime color in multiday event
                                      • more, morePopover feature.
                                      • Global object check. (For compatible with not browser environment)
                                      • Support iconify
                                      • auto-detect firstDayOfWeek and minimalDaysOfNewYear
                                      • weekends of config
                                      Usually I just describe outlines of update here, but in this update, I need to explain somethings with images, so I did it.
                                      I opened WIKI for some details.
                                      Using Iconify
                                      Even though fontawesome is the default icon framework of MM, there are many needs of iconify. And I prefer it to font-awesome. Now you can use iconify icons by config value useIconify: true
                                      // In your calendar module config
                                      defaultSymbolClassName: '', // <-- Important to identify iconify properly.
                                          color: "red",
                                          symbol: "flag:us-4x3",
                                          url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics?foo"
                                          color: "red",
                                          symbol: "fa fa-fw fa-flag", // <-- Important when you want to use font-awesome also together.
                                          url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics?bar"
                                      WARNING
                                      To use iconify, you should set defaultSymbolClassName: '', in your default calendar module. Usually, it is enough when you hide the original default calendar module to use with CX3. But if you want to use font-awesome icons together, you should add font-awesome classnames (e.g fa, fas, …) by yourself.
                                      displaying startTime and endTime in multi-day event.
                                      a Fullday event doesn’t need startTime and endTime. And there is not enough place to show endTime for a single-day event. But for multi-day events, There would be enough space to display the endTime of the last day of the period. And it would be convenient. The position where the endTime would be displayed will be near the event’s last day.
                                      If you don’t want to show it, add this to your css/custom.css
                                      .CX3 .event.multiday:not(.continueToNextWeek) .headline .endTime {
                                        display: none;
                                      more for overflowed events.
                                      By the limitation of maxEventLines (and due to the resolution of the MM screen), overflowed events on the day had to be ignored. It was inconvenient.
                                      Now, CX3 can show how many events are ignored in the day. You can pop over the whole events list of that day by clicking/touching the header of the cell or more marks(White rounded number). The popover contents could be scrollable by touch/drag (if possible)
                                      image image
                                      NOTICE Firefox, Opera Mobile, Samsung Browser cannot handle a new de facto starndard popover feature yet.
                                      Even though it would be helpful to use the new more feature, Still overflowed events would be inconvenient. Generally, upcoming events would be more important than past events especially for today. So you can skip the past events of today by this option. The skipped events will be shown again when today passes.
                                      skipPassedEventToday: false (default)
                                      skipPassedEventToday: true
                                      Auto-detect calendar info by locale
                                      Before 1.7.0, the user must manually set firstDayOfWeek and minimalDaysOfNewYear in the config to calculate the start day of the week, week number, weekend info, etc.
                                      Now, this module will calculate that info automatically with locale without your manual config for firstDayOfWeek and minimalDaysOfNewYear (Leave them as blank or null)
                                      For example;
                                      • When you set the locale as en-US (in the module config or global config), the week starts from Sunday.
                                      • When you set the locale as en-GB, the week starts from Monday.
                                      • When you set the locale as fa-IR, the week starts from Saturday, and the weekend day will be only Friday.
                                      Of course, you can set them up manually by force for the exceptions.
                                      • Not supported natively in legacy browsers.
                                      • To show custom weekend days for your job shift instead of public weekends. (e.g. weekends: [1, 3, 5] for Mon, Wed, Fri resting)
                                      • to adopt a locale but with a different language. (e.g. The Americans living in Germany, so the calendar system itself should be followed by German rule but displayed in English.)
                                      locale: 'en-US', // Displaying things as US English, e.g. MM. DD. YYYY instead of European DD. MM. YYYY
                                      firstDayOfWeek: 1, // German ISO rule. The week starts on Monday, not Sunday, as `en-US`
                                      minimalDaysOfNewYear: 4,
                                      weekends
                                      A new config value, weekends: [], is introduced. By default, you don’t have to set this by yourself because it is derived from the auto-detection of calendar info from the locale. This field will be fulfilled automatically unless you set it manually in config.
                                      Every day cell has weekend and weekend_1 or weekend_2 as its classname.
                                      For example, weekends: [6, 0] means Saturday and Sunday will be considered weekends. Saturday will have weekend weekend_1 and Sunday will have weekend weekend_2.
                                      Style cells with these class names instead of the fixed weekday_N. You don’t have to know which weekday is a weekend in a specific locale.
                                      And more…
                                      C 1 Reply Last reply
                                        ChickenBeard @MMRIZE
                                        Is there a step missing when updating? I follow the install or update instructions in GitHub but it never seems to actually update.
                                          MMRIZE @ChickenBeard
                                          @ChickenBeard
                                          Try this;
                                          cd ~/MagicMirror/modules/MMM-CalendarExt3
                                          git pull
                                          npm install
                                          git submodule update --init --recursive
                                          Sorry, it may be missing. I’ll add the info on next update. (soon)
                                            MMRIZE
                                            [UPDATE] 1.7.1
                                            • ADDED useMarquee config
                                            • ADDED noMarquee event Object attribute
                                              From now, too long title will be rolling as marquee or ticker style.
                                              marquee
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 34
                                            • 35
                                            • 20 / 35
