    MMM-Wallpaper gives black screen on one MM. Other one works.
    11 Posts 3 Posters 4.5k Views 3 Watching
    • Cliff365C
      Cliff365
      The script is identical on both. It works on one, but other gives me a black screen with just a cursor. I have tried bing and chromecast sources and still a black screen.
      			module: "MMM-Wallpaper",
      				// git clone https://github.com/kolbyjack/MMM-Wallpaper.git
      				position: "fullscreen_below",
      				// See "Configuration options" for more information.
      					source: "chromecast",
      					slideInterval: 30 * 500 // Change slides every 30 seconds
        sdetweil @Cliff365
        @Cliff365 show the output from npm start
        and also open the developers window, ctrl-shift-i on the mm window,
        select the console tab and enter wall in the filter field
        Cliff365C 1 Reply Last reply Reply Quote 0
          sdetweil @Cliff365
          @Cliff365 im guessing it this
          if (typeof(fetch) === “undefined”) {
          fetch = require(“fetch”);
          on the system that fails, (black screen) do
          node -v
          i bet its less than 18…
          • Cliff365C
            Cliff365 @sdetweil
            @sdetweil Thanks, I will take a look.
            • Cliff365C
              Cliff365 @sdetweil
              @sdetweil Where would that code go? Command line?
              Node -v returns 16.19.0.
              Do you know the command to update node?
                sdetweil @Cliff365
                @Cliff365 best thing to do is run my upgrade script
                see
                • Cliff365C
                  Cliff365 @sdetweil
                  @sdetweil Thanks! I ran the script, and it’s been sitting at this for about an hour. I assume I should just reinstall MM.
                  alt text
                    sdetweil @Cliff365
                    @Cliff365 no. maybe get out?
                    try this
                    sudo apt-get -y remove nodes npm
                    then node -v
                    the npm install was supposed to be done in the module folder
                    BKeyportB Cliff365C 2 Replies Last reply Reply Quote 0
                    • BKeyportB
                      On my system before Wallpaper was updated as well, I did a npm install fetch in the module directory to get it back.
                      might be worth a shot.
                      • Cliff365C
                        Cliff365 @sdetweil
                        @sdetweil said in MMM-Wallpaper gives black screen on one MM. Other one works.:
                        I think that did the trick. Thanks! node now reports v20,5,1
                          sdetweil @Cliff365
                          @Cliff365 sorry typo in command, my phone thought it knew better!!!
                          sudo apt-get remove nodejs -y
