    MMM-Wallpaper gives black screen on one MM. Other one works.
    11 Posts 3 Posters 4.4k Views 3 Watching
      sdetweil @Cliff365
      @Cliff365 show the output from npm start
      and also open the developers window, ctrl-shift-i on the mm window,
      select the console tab and enter wall in the filter field
      Cliff365C 1 Reply Last reply Reply Quote 0
        sdetweil @Cliff365
        @Cliff365 im guessing it this
        if (typeof(fetch) === “undefined”) {
        fetch = require(“fetch”);
        on the system that fails, (black screen) do
        node -v
        i bet its less than 18…
        • Cliff365C Offline
          Cliff365 @sdetweil
          @sdetweil Thanks, I will take a look.
          • Cliff365C Offline
            Cliff365 @sdetweil
            @sdetweil Where would that code go? Command line?
            Node -v returns 16.19.0.
            Do you know the command to update node?
              sdetweil @Cliff365
              @Cliff365 best thing to do is run my upgrade script
              see
              • Cliff365C Offline
                Cliff365 @sdetweil
                @sdetweil Thanks! I ran the script, and it’s been sitting at this for about an hour. I assume I should just reinstall MM.
                alt text
                  sdetweil @Cliff365
                  @Cliff365 no. maybe get out?
                  try this
                  sudo apt-get -y remove nodes npm
                  then node -v
                  the npm install was supposed to be done in the module folder
                  BKeyportB Cliff365C 2 Replies Last reply Reply Quote 0
                  • BKeyportB Offline
                    On my system before Wallpaper was updated as well, I did a npm install fetch in the module directory to get it back.
                    might be worth a shot.
                    • Cliff365C Offline
                      Cliff365 @sdetweil
                      @sdetweil said in MMM-Wallpaper gives black screen on one MM. Other one works.:
                      I think that did the trick. Thanks! node now reports v20,5,1
                        sdetweil @Cliff365
                        @Cliff365 sorry typo in command, my phone thought it knew better!!!
                        sudo apt-get remove nodejs -y
