    Upgrading from micro SD to M2 SSD
    4 Posts 2 Posters 868 Views 2 Watching
    • N Offline
      Nneuland
      I would like to do a fresh install on anM2 SSD to improve speed of my mirror. I’m currently running an older 32bit OS on a micro SD.
      Is there any way to know if upgrading to a 64bit OS on an M2SSD would cause conflicts? Apologizes for the noob question.
        sdetweil @Nneuland
        @Nneuland there were some gpio problems on the early 64 bit versions, I haven’t tested any myself… so if you have devices attached to the gpio I would suggest testing on an sd card first…
        also, if your pi is a 4, then the 64 bit uses a new graphics display manager, wayland, instead of x11… and currently vnc is broken
        make a backup of your mm setup…
        see https://github.com/sdetweil/MagicMirror-backup-restore
        use my install script for new install.
        see https://github.com/sdetweil/MagicMirror_scripts
        my pi4 I boot off sd card, but run off a USB SSD stick… this was built before the boot from USB support was available…
        (it works so I don’t fiddle with it)
        • N Offline
          Nneuland @sdetweil
          Thank you for the reply, Sam.
          I am indeed using a 4. AND vnc is my connection, unfortunately.
          This reddit thread mentions possible fixes for that. https://www.reddit.com/r/raspberry_pi/comments/175dw97/comment/k4fia8o/?share_id=TNg-oqa439pj6ZLxNBGMP&utm_content=2&utm_medium=android_app&utm_name=androidcss&utm_source=share&utm_term=1
          I imagine booting and running off of the M2 would be faster, and more space, but havent tried yet.
            sdetweil @Nneuland
            @Nneuland yeh, that link
            Made sure I was running updated client and host,
            and that wayland is NOT  running
            instead of X11, nothing
            line split and emphasis on NOT is mine
