    Magic(Dashboard)Mirror
    50 Posts 27 Posters 48.9k Views 38 Watching
      sdetweil @SARCux
      @SARCux please don’t multipost…
        SARCux @sdetweil
        OK
        Thought that the author also had the problem and here has a solution for everyone who wants to use the module
        1 Reply Last reply Reply Quote -1
        • A
          acdacd2
          I love your screen, very clear and desgin.
          Could you share your config and css. THanks, marc,
          • TazDevT
            TazDev @SARCux
            @SARCux
            https://github.com/mazim-co
            • TazDevT
              TazDev
              welches plugin ist das “display ausschalten …” links unten im Eck?
              und wo findet man nun deine CSS ;) ? https://github.com/mazim-co hier ist es nicht so offensichtlich
              • TazDevT
                TazDev @davidT89
                @davidT89
                thanks, this was so important.
                npm install valid-url
                npm install rrule-alt
                • luisestradaL
                  luisestrada @MZ-BER
                  @frentemorao al final te enviaron el css / config.js ? intenté contactarlo pero no responde
                  • MZ-BERM
                    MZ-BER
                    Hello there - I finally got it to upload. I added the files (config.js, custom.css and main.css) to my Github. You can find it here:
                    https://github.com/mazim-co/Dashboard-Backup
                    NOTES:
                    1.) I removed all sensible information like API Keys and Access Tokens in the config.js. So, you have to follow the steps from each module (if requried) to get your own credentials.
                    2.) To get the same UI as my dasboard you have to replace the original main.css with my main.css.
                    3.) If you change the main.css you’ll get a notification every quarter as soon as MagicMirror will be updated. Because it will have a conflict with the original file. To inititate the MagicMirror update you can do a git reset --hard and replace the main.css again afterwards.
                    4.) The custom.css is designed in portrait mode for a 27 inch screen (LG 27MP89HM-S)
                    5.) For some modules you have to install valid-url and rrule-alt (e.g. MMM-MyCalendar).
                    For example:
                    cd MagicMirror/modules/MMM-MyCalendar
                    Good Luck! :beaming_face_with_smiling_eyes:
                      shiring @MZ-BER
                      @MZ-BER
                      Thank you! Great Work!!
                      • G
                        greedyvegan
                        did you take components of the LG screen off in order for it to be so flat?
                        MZ-BERM 1 Reply Last reply Reply Quote 0
                        • MZ-BERM
                          MZ-BER @greedyvegan
                          @greedyvegan Nope, I haven’t removed any components from the screen. The screen itself is quite slim, and I have attached it to the slimmest screen mount I could find (please refer to my first post for the specific model).
                          • G
                            greedyvegan @MZ-BER
                            @MZ-BER thanks, I used a tv I got from a glitch sale and removed the back and speakers to avoid a bulge, built a frame and it still sticks out 3 inches.
                            • G
                              gerbenz @MZ-BER
                              @MZ-BER Van u share the config file?
                              I’m new and try to learn.
                              • 3 / 3
