    MMM-Remote-Control
    9 Posts 4 Posters 3.0k Views 4 Watching
      Dennis-010
      Hey all,
      After troubleshooting the calendar module with the help of Sam I stumpled upon a new “problem”.
      I installed the MMM-Remote-Control module to be able to use motion sensors and HASS to turn on/off the screen/monitor.
      The module works flawlessly exept for the monitor on and off command. I can start, restart and turn off the pi with the module.
      I’m using a Pi4 with 2 micro hdmi ports, monitor isd plugged in hdmi0 (left port) Already tried on a different monitor for testing purose.
      Also already changed the output commands to
      'xrandr -d :0 --output HDMI-1 --auto',
                      module: 'MMM-Remote-Control',
                      // position: 'bottom_left',
                          customCommand: {  // Optional, See "Using Custom Commands" below
                            monitorOnCommand: 'xrandr -d :0 --output HDMI-1 --auto',
                            monitorOffCommand: 'xrandr -d :0 --output HDMI-1 --off'
                          showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                          secureEndpoints: true, // Optional, See API/README.md
                          // uncomment any of the lines below if you're gonna use it
                          // customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                          // apiKey: "", // Optional, See API/README.md for details
                          // classes: {} // Optional, See "Custom Classes" below
        Jessendelft @Dennis-010
        @Dennis-010
        Thanks for figuring all of this out. I also reverted back to the X11 window driver.
        For completeness, just add --rotate right to the command:
          monitorOnCommand: 'xrandr -d :0 --output HDMI-1 --auto --rotate right',
          sdetweil @Dennis-010
          @Dennis-010 pi4 bookworm uses the new Wayland display system instead of x11…
          xrandr doesn’t work
          from discord last night
            Dennis-010 @sdetweil
            Ah have not found that on Google yet,
            Is there a custom line available to have this fixed?
              @Dennis-010 sorry, don’t know what you mean ‘custom line’
              i don’t know if any of us know what to do yet… wayland right now is only setup on pi4… apparently there is a setting in raspiconfig to got back to x11…
                @sdetweil said in MMM-Remote-Control:
                Well, I started with:
                monitorOnCommand: "echo 'on 0.0.0.0' | cec-client -s -d 1",
                Then changd it to:
                So I was wondering if there was a new “custom” line of code I can use. But u already said thast there might be no solution yet.
                  @Dennis-010 he had another post
                  yeah ! just found for wayland
                  [3:58 PM]
                  for turn on: pi@raspberrypi:~ $ WAYLAND_DISPLAY=wayland-1 wlr-randr --output HDMI-A-2 --on
                  [3:58 PM]
                  for turn off: pi@raspberrypi:~ $ WAYLAND_DISPLAY=wayland-1 wlr-randr --output HDMI-A-2 --off
                  ankonaskiff17A D 2 Replies Last reply Reply Quote 0
                  • ankonaskiff17A Offline
                    ankonaskiff17 @sdetweil
                    @sdetweil Saw this and I maybe putting out old news because most people do
                    sudo raspi-config and then hit enter. Saw some text that appear to type in
                    sudo raspi-config nonint do_wayland <W1/W2> with
                    W2 - Use the Wayland backend
                      That line infortunatly did not do the trick.
                      I used the revert option from @ankonaskiff17 to revert back to X11 and now the commands are working again.
                      Only thing now is: when monitor turns back on it’s set back to landscape instead of 90 degrees right portrait.
                      I remember seeing a fix for that somewhere, so I’ll be looking for that.
                        @Dennis-010
