MMM-Remote-Control
9 Posts 4 Posters 1.5k Views 4 Watching
    Dennis-010
    Hey all,
    After troubleshooting the calendar module with the help of Sam I stumpled upon a new “problem”.
    I installed the MMM-Remote-Control module to be able to use motion sensors and HASS to turn on/off the screen/monitor.
    The module works flawlessly exept for the monitor on and off command. I can start, restart and turn off the pi with the module.
    I’m using a Pi4 with 2 micro hdmi ports, monitor isd plugged in hdmi0 (left port) Already tried on a different monitor for testing purose.
    Also already changed the output commands to
    'xrandr -d :0 --output HDMI-1 --auto',
                    module: 'MMM-Remote-Control',
                    // position: 'bottom_left',
                        customCommand: {  // Optional, See "Using Custom Commands" below
                          monitorOnCommand: 'xrandr -d :0 --output HDMI-1 --auto',
                          monitorOffCommand: 'xrandr -d :0 --output HDMI-1 --off'
                        showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                        secureEndpoints: true, // Optional, See API/README.md
                        // uncomment any of the lines below if you're gonna use it
                        // customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                        // apiKey: "", // Optional, See API/README.md for details
                        // classes: {} // Optional, See "Custom Classes" below
    S 1 Reply Last reply Oct 26, 2023, 7:56 PM Reply Quote 0
      Jessendelft @Dennis-010
      @Dennis-010
      Thanks for figuring all of this out. I also reverted back to the X11 window driver.
      For completeness, just add --rotate right to the command:
        monitorOnCommand: 'xrandr -d :0 --output HDMI-1 --auto --rotate right',
        sdetweil @Dennis-010
        @Dennis-010 pi4 bookworm uses the new Wayland display system instead of x11…
        xrandr doesn’t work
        from discord last night
        D 1 Reply Last reply Oct 26, 2023, 7:59 PM Reply Quote 0
          Dennis-010 @sdetweil
          Ah have not found that on Google yet,
          Is there a custom line available to have this fixed?
          S 1 Reply Last reply Oct 26, 2023, 8:16 PM Reply Quote 0
            @Dennis-010 sorry, don’t know what you mean ‘custom line’
            i don’t know if any of us know what to do yet… wayland right now is only setup on pi4… apparently there is a setting in raspiconfig to got back to x11…
            D 1 Reply Last reply Oct 26, 2023, 8:21 PM Reply Quote 0
              @sdetweil said in MMM-Remote-Control:
              Well, I started with:
              monitorOnCommand: "echo 'on 0.0.0.0' | cec-client -s -d 1",
              Then changd it to:
              So I was wondering if there was a new “custom” line of code I can use. But u already said thast there might be no solution yet.
              S 1 Reply Last reply Oct 26, 2023, 8:28 PM Reply Quote 0
                @Dennis-010 he had another post
                yeah ! just found for wayland
                [3:58 PM]
                for turn on: pi@raspberrypi:~ $ WAYLAND_DISPLAY=wayland-1 wlr-randr --output HDMI-A-2 --on
                [3:58 PM]
                for turn off: pi@raspberrypi:~ $ WAYLAND_DISPLAY=wayland-1 wlr-randr --output HDMI-A-2 --off
                A D 2 Replies Last reply Oct 27, 2023, 9:28 PM Reply Quote 0
                  ankonaskiff17 @sdetweil
                  @sdetweil Saw this and I maybe putting out old news because most people do
                  sudo raspi-config and then hit enter. Saw some text that appear to type in
                  sudo raspi-config nonint do_wayland <W1/W2> with
                  W2 - Use the Wayland backend
                    That line infortunatly did not do the trick.
                    I used the revert option from @ankonaskiff17 to revert back to X11 and now the commands are working again.
                    Only thing now is: when monitor turns back on it’s set back to landscape instead of 90 degrees right portrait.
                    I remember seeing a fix for that somewhere, so I’ll be looking for that.
                    J 1 Reply Last reply Dec 9, 2023, 9:09 PM Reply Quote 0
                      @Dennis-010
