    Modifying the Config File
    101 Posts 7 Posters 186.2k Views 7 Watching
      sdetweil @jimb
      @jimb said in Modifying the Config File:
      Sam, that’s where I put it. I can’t cut and paste here because I’m on a different computer than the Pi.
      turn on ssh, and install the bitvise or winscp ssh clients
      then you can do everything from your PC. it’s SOOOOO much better
        jimb
        Sam , After adding the commas to the end of the version Iine I ran it with the check on the config file- All OK. I ran MM in Dev mode and now am getting a 401 error when it attempts to load the openweather resource files. So I seem to not be passing the version or ID string>
          sdetweil @jimb
          @jimb can you show the config for the weather module…
            jimb
            Sam, as a last resort (operating from 2 computers) I attemped to take a picture with my phone and copy that here. No luck. I hear you about working from my PC on the pi, but beyond my experience level. I could try and copy to another place or system?
              sdetweil @jimb
              @jimb posting your pic is the third icon from the right above the message editor
                jimb
                Co
                Sam, I get an error when trying to copy the file. Does it need to have a particular extension?
                  sdetweil @jimb
                  @jimb copy what file?
                    jimb
                    Phone picture of the Config.js file. The picture has a jpg extension.
                      sdetweil @jimb
                      @jimb never any trouble, 3rd icon from the right
                        jimb
                        Sam, I don’t know why the picture is not copied, I suspect it is over-sized. Dev yield
                        The first 12 s the following error message:
                        Failed to load resource: the api.openweatherapp.0…c6acaacfb123ce212:1 server responded with a status of 401 (unauthorized)
                        (twice)
                        Could not locate data …TypeError: Cannot read openweathermap.is 43 properties of undefined (reading ‘humidity’)
                        …then as time increases and it tries to update the screen more specific error messages occur
                        Thye first 12 characters of my api id are truncated in the first error message text above
                          sdetweil @jimb
                          @jimb yes I have had to upload to my PC, then edit the.pic smaller sometimes. technology is so cool sometimes
                          • F Offline
                            fulviolcabrera @jimb
                            @jimb once you download it search for your location. For example, city. It with show your locationID or long or lat. Etc
                              jimb
                              Guys,
                              It’s obvious that I am not specifying the correct item or leaving something out. It’s difficult because noe of the examples I’ve see "lay out’ the complete line of the config only some parts. I’ve played with different items changing them aroud and I get different reports from running in dev of either “401 no authorized” to “404 not found” on the string sent to weathermap. I am using the following-
                              apiVersion: “3.0”
                              locationID: “4699066”
                              apiKey: “xxx” a 32 digit hexadecimal received after registering.
                              I am not using the Lat or Lon at this time
                                sdetweil @jimb
                                @jimb weather is a pain in the rear. the providers are mess, openweather is the worst
                                I believe if you have the new API version you must set the endpoint:“/onecall”
                                AND then you MUST USE lat/lon
                                  jimb
                                  A lillte ray of sunshine… It 'apears" to be talking with operweather now since the MM display shows-
                                  UNDEFINED
                                  (wind symbol) 0 north INVALID DATE
                                  NaN (degrees)
                                  Feels like 32.0 degrees
                                  WEATHER FORECAST UNDEFINED
                                  I’m still getting 401 Unauthorized failed to load resource file. And getting other Cannot Read errors from openweather when using DEV option while running MM
                                    sdetweil @jimb
                                    @jimb can you post the complete module definition
                                    xxx out the apikey field
                                      jimb
                                      Sam, here tis. I just noticed the string symbol ($) and the brackets ({}) in the apiKey. I found that in the instructions in MM. I didn’t try the config without them…
                                      module: “weather”,
                                      units: “imperial”,
                                      windUnits: “imperial”,
                                      tenpUnits: “imperial”,
                                      position: 'top right",
                                      apiVersion: “3.0”,
                                      weatherProvider: “openweather”,
                                      weatherEndpoint: “/onecall”,
                                      lat: “33.50872”,
                                      lon: “-96.612213”,
                                      type: “current”,
                                      locationID: 4699066",
                                      apiKey: “${xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx}”,
                                      module: “weather”,
                                      units: “imperial”,
                                      apiVersion: “3.0”,
                                      lat: “33.50872”,
                                      lon:" -96.612213",
                                      type: “current”,
                                        sdetweil @jimb
                                        @jimb I don’t understand that comment about $[] as the sample looks like this
                                        please take those characters off, it should just be the text provided by openweather, in quotes
                                          jimb
                                          Sam, this was from one source (above that you pasted). Mo config with the weather data is above that and includes the items I mentioned. BTW, I keyed it separately as I am unable to paste from the Rasberry Pi to my windows PC.
                                            sdetweil @jimb
                                            @jimb on the pi desktop, menu top left
                                            preferences, pi preferences.
                                            interfaces, check ssh on. ok,
                                            change host name, just look at it, should be raspberrypi
                                            then save/exit, reboot
                                            on your PC do
                                            ssh pi@raspberrypi
                                            if the userid you created on the pi is pi.
                                            use the password you set when you booted the first time
                                            now you have a terminal on the pi from your PC, and you can copy/paste in both directions…
                                            • 2 / 6
