    Modifying the Config File
    101 Posts 7 Posters 192.5k Views 7 Watching
      sdetweil @jimb
      @jimb yes I have had to upload to my PC, then edit the.pic smaller sometimes. technology is so cool sometimes
      • F
        fulviolcabrera @jimb
        @jimb once you download it search for your location. For example, city. It with show your locationID or long or lat. Etc
          jimb
          Guys,
          It’s obvious that I am not specifying the correct item or leaving something out. It’s difficult because noe of the examples I’ve see "lay out’ the complete line of the config only some parts. I’ve played with different items changing them aroud and I get different reports from running in dev of either “401 no authorized” to “404 not found” on the string sent to weathermap. I am using the following-
          apiVersion: “3.0”
          locationID: “4699066”
          apiKey: “xxx” a 32 digit hexadecimal received after registering.
          I am not using the Lat or Lon at this time
            sdetweil @jimb
            @jimb weather is a pain in the rear. the providers are mess, openweather is the worst
            I believe if you have the new API version you must set the endpoint:“/onecall”
            AND then you MUST USE lat/lon
              jimb
              A lillte ray of sunshine… It 'apears" to be talking with operweather now since the MM display shows-
              UNDEFINED
              (wind symbol) 0 north INVALID DATE
              NaN (degrees)
              Feels like 32.0 degrees
              WEATHER FORECAST UNDEFINED
              I’m still getting 401 Unauthorized failed to load resource file. And getting other Cannot Read errors from openweather when using DEV option while running MM
                sdetweil @jimb
                @jimb can you post the complete module definition
                xxx out the apikey field
                  jimb
                  Sam, here tis. I just noticed the string symbol ($) and the brackets ({}) in the apiKey. I found that in the instructions in MM. I didn’t try the config without them…
                  module: “weather”,
                  units: “imperial”,
                  windUnits: “imperial”,
                  tenpUnits: “imperial”,
                  position: 'top right",
                  apiVersion: “3.0”,
                  weatherProvider: “openweather”,
                  weatherEndpoint: “/onecall”,
                  lat: “33.50872”,
                  lon: “-96.612213”,
                  type: “current”,
                  locationID: 4699066",
                  apiKey: “${xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx}”,
                  module: “weather”,
                  units: “imperial”,
                  apiVersion: “3.0”,
                  lat: “33.50872”,
                  lon:" -96.612213",
                  type: “current”,
                    sdetweil @jimb
                    @jimb I don’t understand that comment about $[] as the sample looks like this
                    please take those characters off, it should just be the text provided by openweather, in quotes
                      jimb
                      Sam, this was from one source (above that you pasted). Mo config with the weather data is above that and includes the items I mentioned. BTW, I keyed it separately as I am unable to paste from the Rasberry Pi to my windows PC.
                        sdetweil @jimb
                        @jimb on the pi desktop, menu top left
                        preferences, pi preferences.
                        interfaces, check ssh on. ok,
                        change host name, just look at it, should be raspberrypi
                        then save/exit, reboot
                        on your PC do
                        ssh pi@raspberrypi
                        if the userid you created on the pi is pi.
                        use the password you set when you booted the first time
                        now you have a terminal on the pi from your PC, and you can copy/paste in both directions…
                          jimb
                          Sam, I remember the name I gave to the Pi, but unfortunately not the password. Is there a way to find it?
                            sdetweil @jimb
                            @jimb np, but you should be able to change it from the preferences without knowing it
                              jimb
                              Sam, I know the name assigned to the rasberry. I now know the password as I have changed it. SSH is not resolving the hostname. So, what is the proper way to populate the following-
                              ssh {what goes here}@{what goes here}
                              Example: ssh {{hostname} @ {password} ???
                                sdetweil @jimb
                                @jimb ssh user @ hostname
                                every command supports help
                                command_name -h or --h
                                  jimb
                                  Sam, the username seems to be OK, but the hostame doesn’t resolve. Even though it shows in preference. Am I missing something
                                    sdetweil @jimb
                                    @jimb try adding .local after the hostname
                                    or use the IP address of the pi.
                                      jimb
                                      Sam, beating head against rock… local host didn’t work. I was able to resolve an IP address, but it appeared to be a v6 that would.t work with ssh. I don’t know the next step.
                                        jimb
                                        Sam, since I’m not making any progress on the weather module I’m going to remark all the lines out for now and move on to other modules.
                                          sdetweil @jimb
                                          @jimb ok the address was probably raspberrypi.local
                                          you need to disable ipv6 on the pi, in the network settings of the pi config under the desktop menu
                                          no reason to have ipv6 in a home environment
                                            jimb
                                            Sam, no joy on either suggestion. Would it be worth it to start the MM install over again. I couldn’t ‘remark’ out the lines, just caused an error with the config file.
                                            I bought the Rasberry Pi with a pre-populated SIM. Not how to get it in virgin state.
                                            • 2 / 6
