    MagicMirror using the wrong time
    54 Posts 6 Posters 33.8k Views 6 Watching
      sdetweil @blissb
      @blissb calendar uses the system timezone
      set in the preferences, from the desktop
      B 1 Reply Last reply
        blissb @sdetweil
        @sdetweil Thanks for the quick reply - but what you are saying isn’t what I’m seeing… Please let me know what I’m missing. I’d be really grateful!
        Time and timezone are set correctly on the two RPi systems. Time / date are showing correctly on the Raspbian desktop, and in the MM Clock module (after setting the timezone option). So, clearly, I’m missing something. Raspi-config has the correct timezone (America/New_York)
        Clock module is correct after adding timeZone to config.js, but not the calendar or weather:
          MMRIZE @blissb
          @blissb
          Maybe your RPI is not synchronized with time server. RPI (not 5) has not RTC feature, so it should be synced it’s time sometimes.
            sdetweil @blissb
            @blissb can you add ,“DEBUG”
            to the log level in config.js
            then do
            from on the terminal window do
            npm start > somefile.txt
            wait til the calendar is up, then Ctrl+q to stop mm
            then examine the somefile.txt
            search for ‘initial’
              blissb @sdetweil
              I replied to this, but then received a notice that my submission was rejected. I don’t know why.
              The debug file has over 200 entries referencing “initial tz =” with both “America/New_York” and “America/Lima.” I do not know why Lima would be anywhere in my configs, but I believe it’s the same time as New York, so I’m not sure that’s instructive.
              I will also add there seems to be an “initial tz=” entry each followed immediately by “corrected tz=” with the same value.
              S B 2 Replies Last reply
                sdetweil @blissb
                @blissb not the same all the time
                could you pull a complete section…
                thru “saving event”
                or send the file to me same userid as here at Gmail.
                  blissb @blissb
                  @blissb
                  Again, I’m not seeing the same thing you are… weird.
                    blissb @sdetweil
                    I think this is what you were asking for?
                    [19.11.2023 17:30.43.315] [DEBUG] Event:
                    {“type”:“VEVENT”,“params”:[],“created”:“2023-11-18T21:17:38.000Z”,“lastmodified”:“2023-11-19T03:21:20.000Z”,“dtstamp”:“2023-11-19T03:21:20.000Z”,“uid”:“cade6f8b-b662-4ad6-bb41-6cdf47266ba9”,“summary”:“Gryphon meds”,“status”:“CONFIRMED”,“rrule”:{“_cache”:{“all”:false,“before”:[],“after”:[],“between”:[]},“origOptions”:{“tzid”:“America/New_York”,“dtstart”:“2023-11-18T22:00:00.000Z”,“freq”:3,“until”:“2023-12-03T05:00:00.000Z”},“options”:{“freq”:3,“dtstart”:“2023-11-18T22:00:00.000Z”,“interval”:1,“wkst”:0,“count”:null,“until”:“2023-12-03T05:00:00.000Z”,“tzid”:“America/New_York”,“bysetpos”:null,“bymonth”:null,“bymonthday”:[],“bynmonthday”:[],“byyearday”:null,“byweekno”:null,“byweekday”:null,“bynweekday”:null,“byhour”:[22],“byminute”:[0],“bysecond”:[0],“byeaster”:null}},“MOZ-LASTACK”:“20231119T032120Z”,“start”:“2023-11-18T22:00:00.000Z”,“datetype”:“date-time”,“end”:“2023-11-18T23:00:00.000Z”,“sequence”:“2”,“MOZ-GENERATION”:“1”,“ec75586d-206f-4821-9a50-81af9612d507”:{“type”:“VALARM”,“params”:[],“action”:“DISPLAY”,“trigger”:“PT0S”,“description”:“Default Mozilla Description”,“end”:“2023-11-20T22:30:36.369Z”}}
                    [19.11.2023 17:30.43.317] [DEBUG] start: Sat Nov 18 2023 17:00:00 GMT-0500 (GMT-05:00)
                    [19.11.2023 17:30.43.319] [DEBUG] end:: Sat Nov 18 2023 18:00:00 GMT-0500 (GMT-05:00)
                    [19.11.2023 17:30.43.320] [DEBUG] duration: 3600000
                    [19.11.2023 17:30.43.322] [DEBUG] title: Gryphon meds
                    [19.11.2023 17:30.43.346] [DEBUG] Search for recurring events between: Sun Nov 19 2023 17:30:43 GMT-0500 (GMT-05:00) and Sun Nov 17 2024 23:59:59 GMT-0500 (GMT-05:00)
                    [19.11.2023 17:30.43.398] [DEBUG] Title: Gryphon meds, with dates: [“2023-11-20T22:00:00.000Z”,“2023-11-21T22:00:00.000Z”,“2023-11-22T22:00:00.000Z”,“2023-11-23T22:00:00.000Z”,“2023-11-24T22:00:00.000Z”,“2023-11-25T22:00:00.000Z”,“2023-11-26T22:00:00.000Z”,“2023-11-27T22:00:00.000Z”,“2023-11-28T22:00:00.000Z”,“2023-11-29T22:00:00.000Z”,“2023-11-30T22:00:00.000Z”,“2023-12-01T22:00:00.000Z”,“2023-12-02T22:00:00.000Z”]
                    [19.11.2023 17:30.43.400] [DEBUG] event.recurrences: undefined
                    [19.11.2023 17:30.43.402] [DEBUG] recurring date is Mon Nov 20 2023 17:00:00 GMT-0500 (GMT-05:00) offset is 300
                    [19.11.2023 17:30.43.405] [DEBUG] recurring date is Mon Nov 20 2023 17:00:00 GMT-0500 (GMT-05:00) offset is 5 Hour is 17
                    [19.11.2023 17:30.43.407] [DEBUG] Corrected startDate: Mon Nov 20 2023 17:00:00 GMT-0500 (GMT-05:00)
                    [19.11.2023 17:30.43.408] [DEBUG] initial tz=America/New_York
                    [19.11.2023 17:30.43.409] [DEBUG] corrected tz=America/New_York
                    [19.11.2023 17:30.43.411] [DEBUG] start date/time=Sat Nov 18 2023 17:00:00 GMT-0500 (GMT-05:00)
                    [19.11.2023 17:30.43.413] [DEBUG] start offset=-300
                    [19.11.2023 17:30.43.415] [DEBUG] start date/time w tz =Sat Nov 18 2023 17:00:00 GMT-0500 (GMT-05:00)
                    [19.11.2023 17:30.43.418] [DEBUG] event date=Mon Nov 20 2023 17:00:00 GMT-0500 (GMT-05:00)
                    [19.11.2023 17:30.43.419] [DEBUG] event offset=-300 hour=17 event date=Mon Nov 20 2023 17:00:00 GMT-0500 (GMT-05:00)
                    [19.11.2023 17:30.43.421] [DEBUG] adjustHours=0
                    [19.11.2023 17:30.43.422] [DEBUG] duration: 3600000
                    [19.11.2023 17:30.43.428] [DEBUG] saving event: false
                      sdetweil @blissb
                      @blissb cool, now find one with Lima
                        blissb @sdetweil
                        Not an exhaustive search – but so far every single “Lima” entry has been an all-day event, and I’m not seeing a “saving event” line for any of the ones I’ve checked so far. Here’s an example:
                        [19.11.2023 18:25.21.190] [DEBUG] Event:
                        {“type”:“VEVENT”,“params”:[],“created”:“2023-11-14T21:23:37.000Z”,“dtstamp”:“2023-11-14T21:23:54.000Z”,“lastmodified”:“2023-11-14T21:23:54.000Z”,“sequence”:“2”,“uid”:“dd7170db-8f64-43ec-9dca-ed806d4c35a2”,“start”:“2023-11-24T05:00:00.000Z”,“datetype”:“date”,“end”:“2023-11-25T05:00:00.000Z”,“status”:“CONFIRMED”,“summary”:“Judiciary Holiday”}
                        [19.11.2023 18:25.21.191] [DEBUG] start: Fri Nov 24 2023 00:00:00 GMT-0500 (GMT-05:00)
                        [19.11.2023 18:25.21.192] [DEBUG] end:: Sat Nov 25 2023 00:00:00 GMT-0500 (GMT-05:00)
                        [19.11.2023 18:25.21.193] [DEBUG] duration: 86400000
                        [19.11.2023 18:25.21.194] [DEBUG] title: Judiciary Holiday
                        [19.11.2023 18:25.21.195] [DEBUG] if no tz, guess based on now
                        [19.11.2023 18:25.21.195] [DEBUG] initial tz=America/Lima
                        [19.11.2023 18:25.21.196] [DEBUG] corrected tz=America/Lima
                        [19.11.2023 18:25.21.197] [DEBUG] start date/time=Fri Nov 24 2023 00:00:00 GMT-0500 (GMT-05:00)
                        [19.11.2023 18:25.21.198] [DEBUG] start offset=-300
                        [19.11.2023 18:25.21.200] [DEBUG] start date/time w tz =Fri Nov 24 2023 00:00:00 GMT-0500 (GMT-05:00)
                        [19.11.2023 18:25.21.201] [DEBUG] event date=Fri Nov 24 2023 00:00:00 GMT-0500 (GMT-05:00)
                        [19.11.2023 18:25.21.202] [DEBUG] event offset=-300 hour=0 event date=Fri Nov 24 2023 00:00:00 GMT-0500 (GMT-05:00)
                        [19.11.2023 18:25.21.203] [DEBUG] adjustHours=0
                        [19.11.2023 18:25.21.203] [DEBUG] Processing entry…
                          sdetweil @blissb
                          @blissb
                          that means the system timezone is set to Lima.
                            blissb @sdetweil
                            And yet it is not according to everything I can see.
                              sdetweil @blissb
                              @blissb how about thru the preferences, in the menu, top left on the desktop
                              this is a pi, yes?
                                blissb @sdetweil
                                I know I haven’t said it, but I really appreciate you looking at this… it’s been driving me nuts since the last update messed things up.
                                I just tested hard-coding the timezone in calendarfetcherutils.js – replaced “moment.tz.guess()” with “America/New_York” on line 29. That has removed the “Lima” entries in the debug log, but it has not corrected the time issue.
                                Yes, I’m running on a Pi. Here’s what’s in preferences:
                                  sdetweil @blissb
                                  @blissb what is the locale above the tz?
                                    blissb @sdetweil
                                    On my second MagicMirror I restored the backup of the last version of MM, and made no other changes. The debug info shows no instances of the “lima” timezone, and all times are correct.
                                    I went back to the most recent version, reran with debug, and the “Lima” instance is back, as are the wrong times.
                                    I’ll be reverting to the previous version of MM for the moment, but please let me know if there’s anything else I can do to help with troubleshooting this really annoying issue!
                                      blissb @sdetweil
                                      Locale is:
                                        sdetweil @blissb
                                        @blissb great info!!! thanks.
                                        this sounds like a bad moment lib.
                                          @blissb can you show me the list of active modules, in the order in config.js
                                          thx
                                            blissb @sdetweil
                                            Is there an easier way to get them other than just scrolling through the config.js?
                                            Modules in order:
                                            alert
                                            clock (correct after adding the timezone: option)
                                            calendar
                                            weather (Sunrise time is also 5 hours off - sorry if I failed to mention that earlier)
