    MagicMirror using the wrong time
    54 Posts 6 Posters 27.7k Views 6 Watching
      blissb @rcberg3
      @rcberg3 I’m having exactly the same issue. Also on Raspbian 10 and MM 2.25.0. I was able to set the timeZone in the clock module, but the calendar is still off. Has there been any further info on this? Is there another posting I should be looking at?
        sdetweil @blissb
        @blissb calendar uses the system timezone
        set in the preferences, from the desktop
          blissb @sdetweil
          @sdetweil Thanks for the quick reply - but what you are saying isn’t what I’m seeing… Please let me know what I’m missing. I’d be really grateful!
          Time and timezone are set correctly on the two RPi systems. Time / date are showing correctly on the Raspbian desktop, and in the MM Clock module (after setting the timezone option). So, clearly, I’m missing something. Raspi-config has the correct timezone (America/New_York)
          Clock module is correct after adding timeZone to config.js, but not the calendar or weather:
            MMRIZE @blissb
            @blissb
            Maybe your RPI is not synchronized with time server. RPI (not 5) has not RTC feature, so it should be synced it’s time sometimes.
              sdetweil @blissb
              @blissb can you add ,“DEBUG”
              to the log level in config.js
              then do
              from on the terminal window do
              npm start > somefile.txt
              wait til the calendar is up, then Ctrl+q to stop mm
              then examine the somefile.txt
              search for ‘initial’
                blissb @sdetweil
                I replied to this, but then received a notice that my submission was rejected. I don’t know why.
                The debug file has over 200 entries referencing “initial tz =” with both “America/New_York” and “America/Lima.” I do not know why Lima would be anywhere in my configs, but I believe it’s the same time as New York, so I’m not sure that’s instructive.
                I will also add there seems to be an “initial tz=” entry each followed immediately by “corrected tz=” with the same value.
                S B 2 Replies Last reply Reply Quote 0
                  sdetweil @blissb
                  @blissb not the same all the time
                  could you pull a complete section…
                  thru “saving event”
                  or send the file to me same userid as here at Gmail.
                    blissb @blissb
                    @blissb
                    Again, I’m not seeing the same thing you are… weird.
                      blissb @sdetweil
                      I think this is what you were asking for?
                      [19.11.2023 17:30.43.315] [DEBUG] Event:
                      {“type”:“VEVENT”,“params”:[],“created”:“2023-11-18T21:17:38.000Z”,“lastmodified”:“2023-11-19T03:21:20.000Z”,“dtstamp”:“2023-11-19T03:21:20.000Z”,“uid”:“cade6f8b-b662-4ad6-bb41-6cdf47266ba9”,“summary”:“Gryphon meds”,“status”:“CONFIRMED”,“rrule”:{“_cache”:{“all”:false,“before”:[],“after”:[],“between”:[]},“origOptions”:{“tzid”:“America/New_York”,“dtstart”:“2023-11-18T22:00:00.000Z”,“freq”:3,“until”:“2023-12-03T05:00:00.000Z”},“options”:{“freq”:3,“dtstart”:“2023-11-18T22:00:00.000Z”,“interval”:1,“wkst”:0,“count”:null,“until”:“2023-12-03T05:00:00.000Z”,“tzid”:“America/New_York”,“bysetpos”:null,“bymonth”:null,“bymonthday”:[],“bynmonthday”:[],“byyearday”:null,“byweekno”:null,“byweekday”:null,“bynweekday”:null,“byhour”:[22],“byminute”:[0],“bysecond”:[0],“byeaster”:null}},“MOZ-LASTACK”:“20231119T032120Z”,“start”:“2023-11-18T22:00:00.000Z”,“datetype”:“date-time”,“end”:“2023-11-18T23:00:00.000Z”,“sequence”:“2”,“MOZ-GENERATION”:“1”,“ec75586d-206f-4821-9a50-81af9612d507”:{“type”:“VALARM”,“params”:[],“action”:“DISPLAY”,“trigger”:“PT0S”,“description”:“Default Mozilla Description”,“end”:“2023-11-20T22:30:36.369Z”}}
                      [19.11.2023 17:30.43.317] [DEBUG] start: Sat Nov 18 2023 17:00:00 GMT-0500 (GMT-05:00)
                      [19.11.2023 17:30.43.319] [DEBUG] end:: Sat Nov 18 2023 18:00:00 GMT-0500 (GMT-05:00)
                      [19.11.2023 17:30.43.320] [DEBUG] duration: 3600000
                      [19.11.2023 17:30.43.322] [DEBUG] title: Gryphon meds
                      [19.11.2023 17:30.43.346] [DEBUG] Search for recurring events between: Sun Nov 19 2023 17:30:43 GMT-0500 (GMT-05:00) and Sun Nov 17 2024 23:59:59 GMT-0500 (GMT-05:00)
                      [19.11.2023 17:30.43.398] [DEBUG] Title: Gryphon meds, with dates: [“2023-11-20T22:00:00.000Z”,“2023-11-21T22:00:00.000Z”,“2023-11-22T22:00:00.000Z”,“2023-11-23T22:00:00.000Z”,“2023-11-24T22:00:00.000Z”,“2023-11-25T22:00:00.000Z”,“2023-11-26T22:00:00.000Z”,“2023-11-27T22:00:00.000Z”,“2023-11-28T22:00:00.000Z”,“2023-11-29T22:00:00.000Z”,“2023-11-30T22:00:00.000Z”,“2023-12-01T22:00:00.000Z”,“2023-12-02T22:00:00.000Z”]
                      [19.11.2023 17:30.43.400] [DEBUG] event.recurrences: undefined
                      [19.11.2023 17:30.43.402] [DEBUG] recurring date is Mon Nov 20 2023 17:00:00 GMT-0500 (GMT-05:00) offset is 300
                      [19.11.2023 17:30.43.405] [DEBUG] recurring date is Mon Nov 20 2023 17:00:00 GMT-0500 (GMT-05:00) offset is 5 Hour is 17
                      [19.11.2023 17:30.43.407] [DEBUG] Corrected startDate: Mon Nov 20 2023 17:00:00 GMT-0500 (GMT-05:00)
                      [19.11.2023 17:30.43.408] [DEBUG] initial tz=America/New_York
                      [19.11.2023 17:30.43.409] [DEBUG] corrected tz=America/New_York
                      [19.11.2023 17:30.43.411] [DEBUG] start date/time=Sat Nov 18 2023 17:00:00 GMT-0500 (GMT-05:00)
                      [19.11.2023 17:30.43.413] [DEBUG] start offset=-300
                      [19.11.2023 17:30.43.415] [DEBUG] start date/time w tz =Sat Nov 18 2023 17:00:00 GMT-0500 (GMT-05:00)
                      [19.11.2023 17:30.43.418] [DEBUG] event date=Mon Nov 20 2023 17:00:00 GMT-0500 (GMT-05:00)
                      [19.11.2023 17:30.43.419] [DEBUG] event offset=-300 hour=17 event date=Mon Nov 20 2023 17:00:00 GMT-0500 (GMT-05:00)
                      [19.11.2023 17:30.43.421] [DEBUG] adjustHours=0
                      [19.11.2023 17:30.43.422] [DEBUG] duration: 3600000
                      [19.11.2023 17:30.43.428] [DEBUG] saving event: false
                        sdetweil @blissb
                        @blissb cool, now find one with Lima
                        • 1 / 6
