    Brand New Install works until I enable PM2 Autostart
    9 Posts 3 Posters 2.1k Views 3 Watching
      cowlam
      Hi All,
      Newbie here having an issue with new installs where everything works perfectly following the official installation instructions (https://docs.magicmirror.builders/getting-started/installation.html) until I implement PM2.
      I am using Bookworm 64bit desktop on a 3A+ with a 32gb SD. Running “npm run start” launches Magic Mirror on the desktop and all is good.
      But as soon as I try to autostart (https://docs.magicmirror.builders/configuration/autostart.html#using-pm2) when it launches, it is actually launching an empty black Electron app on the desktop. If I close that app then the Magic Mirror 2 app launches and runs fine. It’s completely weird. I have run through this from scratch 3 times and the same issue each time.
      Any help is much appreciated.
      Anthony
        sdetweil @cowlam
        @cowlam did you do these steps?
        if YOU execute mm.sh does it open MM?
        so, if you do
        pm2 status
        then
        pm2 remove 0
        pm2 save
        then resume the steps
        pm2 start mm.sh
        if it starts then
        pm2 save
        or , you can use my scripts. (remove the entry in pm2 first so you don’t get two)
        see
        the last script on that page will setup pm2 to launch mm
          cowlam @sdetweil
          @sdetweil Thank You for the suggestions.
          It launches correctly with “pm2 start mm.sh”.
          But when I then run “pm2 save” and stop mm and start it again it launches the black Electron screen.
          So I then remove it (had to run “pm2 del 0”), and save (pm2 save --force).
          Then I ran “pm2 start mm.sh” again.
          I then ran “pm2 stop mm”.
          Then I ran “pm2 save”.
          I can successfully run “pm2 start mm.sh” after that providing I saved it in the stopped state.
          But that means when the pi reboots it isn’t started automatically.
            sdetweil @cowlam
            @cowlam don’t do the pm2 stop
            pm2 start mm.sh
            pm2 save
            then pm2 restart 0 (or mm), pm2 status will show you the managed apps…
            can address by number or name or all (if u want to affect all apps)
              cowlam @sdetweil
              pm2 start mm.sh
              Magic Mirror launches successfully
              pm2 save
              pm2 restart 0 (can confirm that is the correct id from pm2 status - only one entry which is mm)
              Magic Mirror is closed down… and an black Electron window opens and does not change ever after several minutes.
              If I right-click the Electron window and close it, after a few seconds the Magic Mirror launches successfully again on its own.
                sdetweil @cowlam
                @cowlam weird…
                can you reboot and tell what happens
                can u show the mm.sh
                  cowlam @sdetweil
                  After my last post I ran pm2 restart 0 and it restarted MM correctly.
                  But after I rebooted it was back to launching the black Electron screen.
                  mm.sh looks like this:
                  cd ./MagicMirror
                  DISPLAY=:0 npm start
                    sdetweil @cowlam
                    @cowlam can u change the cd line to
                    the one u have is MagicMirror from here (.)
                    not MagicMirror from user home (~)
                    also the pm2 status line has a column with a circled arrow header, that is restarts
                    and after 5 rapid it stops
                    I suspect the cd doesn’t work, mm doesn’t start,
                    but the saved info says u need electron started.
                    • BKeyportB
                      @sdetweil Sam: Just to let you know, if PM2 is not running any tasks, it won’t save with a plain pm2 save - you have to use pm2 save --force to clear the list after deleting everything.
