    Brand New Install works until I enable PM2 Autostart
    9 Posts 3 Posters 1.6k Views 3 Watching
      cowlam @sdetweil
      pm2 start mm.sh
      Magic Mirror launches successfully
      pm2 save
      pm2 restart 0 (can confirm that is the correct id from pm2 status - only one entry which is mm)
      Magic Mirror is closed down… and an black Electron window opens and does not change ever after several minutes.
      If I right-click the Electron window and close it, after a few seconds the Magic Mirror launches successfully again on its own.
        sdetweil @cowlam
        @cowlam weird…
        can you reboot and tell what happens
        can u show the mm.sh
          cowlam @sdetweil
          After my last post I ran pm2 restart 0 and it restarted MM correctly.
          But after I rebooted it was back to launching the black Electron screen.
          mm.sh looks like this:
          cd ./MagicMirror
          DISPLAY=:0 npm start
            sdetweil @cowlam
            @cowlam can u change the cd line to
            the one u have is MagicMirror from here (.)
            not MagicMirror from user home (~)
            also the pm2 status line has a column with a circled arrow header, that is restarts
            and after 5 rapid it stops
            I suspect the cd doesn’t work, mm doesn’t start,
            but the saved info says u need electron started.
            • BKeyportB Offline
              @sdetweil Sam: Just to let you know, if PM2 is not running any tasks, it won’t save with a plain pm2 save - you have to use pm2 save --force to clear the list after deleting everything.
