    Magic mirror dual screen
    25 Posts 4 Posters 22.6k Views 4 Watching
    • 1 Offline
      1a2a3a @MMRIZE
      @MMRIZE hmmm ideally… 1 pi connect to 2 monitor and both monitor running … this is the part I don’t quite get it.
      I want 1 monitor to just display Google photo and the other monitor showing all the informative stuff like calendar news stock etc. would this be more viable running 2 instances of mm? Or 1 instance of mm portraying Google photo on 1 screen and info on another side?
      It feels like the first option is easier?
      I’m happy to go either direction.
      Of course the easiest solution is to buy 2 pi and call it a day. But where’s the fun in that 😅
        sdetweil @1a2a3a
        @1a2a3a MM only displays on one screen… you can run two instances, and have them display on different monitors… from the same mm folder. just two different config files.
        see the MM_CONFIG_FILE env variable
        to get an instance on the other monitor you need to add
        electronOptions:{x:????,width:yyyy},
        to the config.js before the modules:{} list
        ??? is the width of the 1st display in pixels
        yyyy is the width of the second monitor
        note that you can also do the MMM-Pages approach, and only display some on a logical page 1 and some on logical page 2 in rotation…
        see my fork for a better way to define that
        https://github.com/sdetweil/MMM-pages
        1 1 Reply Last reply Reply Quote 0
        • 1 Offline
          1a2a3a @sdetweil
          @sdetweil oh my just that simple 1 config file and I’m done? And when I run pm2 it will flash to 2 as well?
            sdetweil @1a2a3a
            @1a2a3a have to run two scripts, one w the second config file
              @sdetweil see the pm2_MagicMirror.json in ~/MagicMirror/installers
              copy, change the name and script name, make a new script mm2.sh
              and the env variable
              pm2 start pm2_MagicMirror.json(new name)
              pm2 save
              that give the app pm2 manages a pretty name
              you can test w another terminal window
              set the env variable, using export variable=
              then create the new config.js, w only the modules u want enabled.
              then npm start
              • BKeyportB Offline
                @sdetweil heck, I’m a little lost there. Can you explain it out a bit better for us? I’m currently running two Magicmirrors back to back with two MM Directories and custom mm.sh files, if I could simplify that, I want to.
                • BKeyportB Offline
                  @BKeyport What I did was two directories, with seperate configs, then mm.sh does:
                  cd /home/bkey1970/MagicMirror
                  DISPLAY=:0 npm start
                  and mm2.sh does:
                  cd /home/bkey1970/MagicMirror2
                  To get the 2nd on the 2nd monitor, I added:
                          electronOptions: {
                      x: 1920
                  to the 2nd config.js, right below the address line, and changed the port to 8081.
                    sdetweil @BKeyport
                    @BKeyport @1a2a3a
                    copy the second config.js to the first mm config directory as config2.js
                    edit the mm2.sh
                    cd to the first mm directory(instead of the second)
                    and add a line
                    export MM_CONFIG_FILE=${cwd}/config/config2.js
                    npm start
                    now. make sure all the modules needed by both instances are installed in the modules folder of the 1st instance.
                    if they aren’t used by a particular instance, no big deal, same as setting disabled:true on a module config
                    • BKeyportB Offline
                      Interesting - although, now, it’s ignoring the electronOptions: item.
                      • BKeyportB Offline
                        Here’s the answer for @1a2a3a (Edited to show below changes)
                        Here’s how to do it cleanly: (replace <username> with your pi login name., with width of first monitor)
                        1. create two starting scripts:
                        First, mm.sh is as follows:
                        cd /home/<username>/MagicMirror
                        Second, mm2.sh is as follows:
                        export MM_CONFIG_FILE=${pwd}/config/config2.js
                        1. Two config files in magicmirror/config next:
                        First, config.js (this is your second monitor):
                               var config = {
                               electronOptions: { x: <width> },
                                address: "0.0.0.0",
                                port: 8080,
                                ipWhitelist: [],
                                language: "en",
                                timeFormat: 12,
                                units: "imperial",
                                //logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
                        Second config2.js (this is your first monitor):
                               var config = {
                                address: "0.0.0.0",
                                port: 8081,
                                ipWhitelist: [],
                                language: "en",
                                timeFormat: 12,
                                units: "imperial",
                        electronOptions will only work in the file that isn’t redirected to a new config - so use that in the config.js only.
