    CalDAV
    26 Posts 8 Posters 26.3k Views 8 Watching
      Beh
      Hey, @poekel
      after some trying on my Baikal server, I found out, that just the use of the start parameter alone is not working indeed.
      However, I was able to get a request, if you add the componentType option to the request URL. You have to filter the type to VEVENT. But thats no problem, because the documentation says, that this is the only working type for export anyway.
      So I got valid answers with the following URL scheme (including recognized timestamp):
      https://dav.example.com/dav.php/calendars/USERNAME/calendarname?export&start=1490745600&componentType=VEVENT
        poekel
        Your the Greatest!
        Man , it works ! Unbelievable ! Many thanks!!!
        • O
          OsCourt
          Hi gentlemen,
          I’m sorry to reopen this old topic.
          What you are succeeded to do here it’s exactly what I search to do but it doesn’t work on my MagicMirror.
          • I have a Syno with Baikal (http://ipaddress/baikal/admin)
          • I have a user (homemagic) with his calendar (default)
          • My calendarfetcher.js is up-to-date (v2.2.0)
          URL I use for :
          http://ipaddress/baikal/cal.php/calendars/homemagic/default?export&start= 1514761200&componentType=VEVENT
          • Work on my android mobile with Caldav Sync Free Beta (PlayStore)
          • Work on ThunderBird
          • Doesn’t work on my MagicMirror :'(
          • My web browser (IE) return an error when I try to export
          Someone could help me please :)
          B 1 Reply Last reply
            Beh @OsCourt
            @OsCourt I think you need to use dav.php instead of cal.php on newer baikal versions. Also you need to use digest authentication with the calendar module of the mirror. It’s described in the readme of the module.
            • O
              OsCourt
              Thanks @Beh.
              I don’t have dav.php file in my baikal folder on my Syno :/
              I had already read the readme and I have the digest authentication in the mirror:
                                                              symbol: "calendar-check-o ",
                                                              url: 'http://ipaddress/baikal/cal.php/calendars/homemagic/default?export&start=1514761200&componentType=VEVENT',
                                                              auth: {
        user: "homemagic",
        password: "pass",
        method: "digest"
              P 1 Reply Last reply
              • O
                OsCourt
                Hi @poekel,
                How have you installed baikal on your Syno ?
                  poekel @OsCourt
                  @Beh
                  Since sometime my calendar will not start. It keeps saying “loading”
                  Does anyone have an idea to solve this ?
                  • Z
                    zeisolf
                    Dear all,
                    it definitely sounds interesting to have Baikal-calenders on a MM as well.
                    I am using Baikal (0.2.7, for my understanding the most recent version) on Synology for some time already now.
                    By defnition i have the old-style path like http://MYSYNO/baikal/cal.php/calendars/USER/default/.
                    To export any .ics-files for my understanding i will need to add the export plugin.
                    How can i add this to Baikal on Synology or should this already be integrated in version 0.2.7?
                    If not how can i update to any other version for Synology to enable this function?
                    After some testing this is how i got it working:
                    Add the Export-Plugin to Baikal:
                    Edit cal.php
                    near the end of the file add to the plugins:
                    $server->addPlugin(new \Sabre\CalDAV\ICSExportPlugin());
                    Edit card.php
                    $server->addPlugin(new \Sabre\CardDAV\VCFExportPlugin());
                    URL in the web browser (i.e. Magic Mirror):
                    http(s)://SERVER/baikal/cal.php/calendars/USER/default?export
                    http(s)://SERVER/baikal/card.php/addressbooks/USER/default?export
                    No additional parameters needed, if you want you can as described earlier in this thread…
                      matt216
                      Hoping to get some up-to-date help with getting a self-hosted baikal (container) server on to my MagicMirror.
                      I am currently seeing “Error in the calendar module. Authorization failed” which points to user/password.
                      Config looks like:
                      header: "family calendar",
                                                        url: "https://mydomain.tld/dav.php/calendars/family/default/',
                                                        auth:   {
        user: 'user',
        pass: 'pass',
        method: 'basic'
                                    maximumEntries: 5
                      I’ve had a play with ?export and &start flags but still getting the auth error.
                      Anyone have any recent success with a local baikal container?
                      Thank you for the help,
                      Matt
                      M M 2 Replies Last reply
                        MMRIZE @matt216
                        @matt216
                        Try MMM-CalDAV.
                          matt216 @matt216
                          @matt216
                          Resolved.
                          Adding ?export to the end of your calendar URL generates the ics file required. Also recommend confirming the auth settings in the baikal web UI.
                          • M matt216 referenced this topic on
