    CalDAV
    26 Posts 8 Posters 25.9k Views 8 Watching
      poekel
      Your the Greatest!
      Man , it works ! Unbelievable ! Many thanks!!!
      • O Offline
        OsCourt
        Hi gentlemen,
        I’m sorry to reopen this old topic.
        What you are succeeded to do here it’s exactly what I search to do but it doesn’t work on my MagicMirror.
        • I have a Syno with Baikal (http://ipaddress/baikal/admin)
        • I have a user (homemagic) with his calendar (default)
        • My calendarfetcher.js is up-to-date (v2.2.0)
        URL I use for :
        http://ipaddress/baikal/cal.php/calendars/homemagic/default?export&start= 1514761200&componentType=VEVENT
        • Work on my android mobile with Caldav Sync Free Beta (PlayStore)
        • Work on ThunderBird
        • Doesn’t work on my MagicMirror :'(
        • My web browser (IE) return an error when I try to export
        Someone could help me please :)
          Beh @OsCourt
          @OsCourt I think you need to use dav.php instead of cal.php on newer baikal versions. Also you need to use digest authentication with the calendar module of the mirror. It’s described in the readme of the module.
          • O Offline
            OsCourt
            Thanks @Beh.
            I don’t have dav.php file in my baikal folder on my Syno :/
            I had already read the readme and I have the digest authentication in the mirror:
                                                            symbol: "calendar-check-o ",
                                                            url: 'http://ipaddress/baikal/cal.php/calendars/homemagic/default?export&start=1514761200&componentType=VEVENT',
                                                            auth: {
        user: "homemagic",
        password: "pass",
        method: "digest"
            • O Offline
              OsCourt
              Hi @poekel,
              How have you installed baikal on your Syno ?
                poekel @OsCourt
                @Beh
                Since sometime my calendar will not start. It keeps saying “loading”
                Does anyone have an idea to solve this ?
                • Z Offline
                  zeisolf
                  Dear all,
                  it definitely sounds interesting to have Baikal-calenders on a MM as well.
                  I am using Baikal (0.2.7, for my understanding the most recent version) on Synology for some time already now.
                  By defnition i have the old-style path like http://MYSYNO/baikal/cal.php/calendars/USER/default/.
                  To export any .ics-files for my understanding i will need to add the export plugin.
                  How can i add this to Baikal on Synology or should this already be integrated in version 0.2.7?
                  If not how can i update to any other version for Synology to enable this function?
                  After some testing this is how i got it working:
                  Add the Export-Plugin to Baikal:
                  Edit cal.php
                  near the end of the file add to the plugins:
                  $server->addPlugin(new \Sabre\CalDAV\ICSExportPlugin());
                  Edit card.php
                  $server->addPlugin(new \Sabre\CardDAV\VCFExportPlugin());
                  URL in the web browser (i.e. Magic Mirror):
                  http(s)://SERVER/baikal/cal.php/calendars/USER/default?export
                  http(s)://SERVER/baikal/card.php/addressbooks/USER/default?export
                  No additional parameters needed, if you want you can as described earlier in this thread…
                    matt216
                    Hoping to get some up-to-date help with getting a self-hosted baikal (container) server on to my MagicMirror.
                    I am currently seeing “Error in the calendar module. Authorization failed” which points to user/password.
                    Config looks like:
                    header: "family calendar",
                                                      url: "https://mydomain.tld/dav.php/calendars/family/default/',
                                                      auth:   {
        user: 'user',
        pass: 'pass',
        method: 'basic'
                                  maximumEntries: 5
                    I’ve had a play with ?export and &start flags but still getting the auth error.
                    Anyone have any recent success with a local baikal container?
                    Thank you for the help,
                    Matt
                    M M 2 Replies Last reply Reply Quote 0
                      MMRIZE @matt216
                      @matt216
                      Try MMM-CalDAV.
                        matt216 @matt216
                        @matt216
                        Resolved.
                        Adding ?export to the end of your calendar URL generates the ics file required. Also recommend confirming the auth settings in the baikal web UI.
                        • M matt216 referenced this topic on
