    Magic mirror dual screen
    25 Posts 4 Posters 25.4k Views 4 Watching
    • BKeyportB Offline
      Here’s the answer for @1a2a3a (Edited to show below changes)
      Here’s how to do it cleanly: (replace <username> with your pi login name., with width of first monitor)
      1. create two starting scripts:
      First, mm.sh is as follows:
      cd /home/<username>/MagicMirror
      DISPLAY=:0 npm start
      Second, mm2.sh is as follows:
      export MM_CONFIG_FILE=${pwd}/config/config2.js
      1. Two config files in magicmirror/config next:
      First, config.js (this is your second monitor):
             var config = {
             electronOptions: { x: <width> },
              address: "0.0.0.0",
              port: 8080,
              ipWhitelist: [],
              language: "en",
              timeFormat: 12,
              units: "imperial",
              //logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
      Second config2.js (this is your first monitor):
             var config = {
              address: "0.0.0.0",
              port: 8081,
              ipWhitelist: [],
              language: "en",
              timeFormat: 12,
              units: "imperial",
      electronOptions will only work in the file that isn’t redirected to a new config - so use that in the config.js only.
        sdetweil @BKeyport
        @BKeyport nice description
        • BKeyportB Offline
          @sdetweil I figured I might as well make it as clear as possible…
          • 1 Offline
            1a2a3a
            Thanks all! I’ll give this a go once the monitor arrives!
              sdetweil @1a2a3a
              @1a2a3a @BKeyport
              the MM_CONFIG_FILE problem is mine
              the correct stmt would be
              export MM_CONFIG_FILE=$(pwd)/config/config2.js
              notice I changed the brackets to parens and changed the command name
              BKeyportB 2 Replies Last reply Reply Quote 0
              • BKeyportB Offline
                  sdetweil @BKeyport
                  @BKeyport I just fixed it
                  • BKeyportB Offline
                    It has to be brackets on my system, FYI.
                      sdetweil @BKeyport
                      @BKeyport ok…
                      • 1 Offline
                        1a2a3a
                        btw, how do i configure the css for the 2 screen?
                          sdetweil @1a2a3a
                          @1a2a3a you would set the css filename in its config.js
                          so you would have css/custom.css and css/custom2.css, one for each instance
                          from the doc
                          https://docs.magicmirror.builders/configuration/introduction.html
                          customCss	The path of the custom.css stylesheet. The default is css/custom.css.
                          • BKeyportB Offline
                            @sdetweil alternatively, use the single custom.css file if there’s no conflict.
                              sdetweil @BKeyport
                              @BKeyport yeh but I assumed there was a conflict, else he wouldn’t have known there was an issue.
                              • 1 Offline
                                1a2a3a
                                Decided to drop this for now guys. The new monitor is a 27 qhd compared to the previous 24 fhd. With the extra real estate, everything doesn’t seems to be so cluttered now.
