    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
      sdetweil @1a2a3a
      @1a2a3a install the (free) bitvise or winscp clients on windows, enable ssh on pi
      and then you can edit on windows with double click on the file interface window they provide . bitvise also has a drag/drop window to copy files in either direction…
      on windows I use Notepad++ or Visual Studio Code as the editor…
      I NEVER edit ON the pi… EVER… I use ssh or one of the graphical tools…
      on Linux I use the Caja file manager as it can link to ‘servers’ (ssh systems) and provide the same file manager interface
      1 1 Reply Last reply
        1a2a3a
        THANK YOU both! the gap body code is exactly what i needed and bitvise helps a plenty!
        Sam, do you mean i copy the code over from pi to pc > then simulate pc to run the mirror in dev mode and edit the css on the pc > then copy the css code from pc back to pi?
          sdetweil @1a2a3a
          @1a2a3a no ,
          open any browser connected to mm, in developer mode, (so chrome on your PC viewing mm page, and editor on PC editing custom.css via bitvise directly)
          and you can set styles on any element to see it’s effect
          then can add those to custom.css and refresh
          see
          https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1700742616489
            1a2a3a @sdetweil
            @sdetweil hmmm, i have been editing in the module css instead of the custom css. any undesirable consequences? also, whats the button to press for refresh? i keep doing ctrl c and npm start for refresh.
            M S 2 Replies Last reply
              MMRIZE @1a2a3a
              @1a2a3a
              Don’t do edit module’s CSS ever at all. It will be problem on module update.
              Instead, override them in your css/custom.css
                sdetweil @1a2a3a
                @1a2a3a refresh
                if the cursor is over the mm part of the page, ctrl-r
                if the cursor is over the developers window part, f5
                never edit any module provided file, or any mm provided file
                custom.css is designed to enable override of any css.
                  1a2a3a @sdetweil
                  @sdetweil lol so dead. no idea what i changed in main.css and module css :(
                    sdetweil @1a2a3a
                    @1a2a3a in each place (mm folder/ module folder) do
                    git diff
                    it will show you the changed content
                    then copy that to custom.css
                    when complete, in each place do
                    git checkout xxx
                    xxx is the filename to restore
                    main.css or module_name.css
                      1a2a3a @sdetweil
                      @sdetweil thank you! that fix it. i needed quite a long time to remediate them haha
                        1a2a3a @sdetweil
                        @sdetweil hey Sam can I know your vnc tool? Or rather the problem I’m facing now is that I’m using tiger vnc. My pi monitor is vertical. Pc Monitor is horizontal. When I vnc from the pc it shows vertical but my mouse is in horizontal mode so I can’t control it properly to do my css.
                          sdetweil @1a2a3a
                          @1a2a3a I don’t use VNC. I use my PC browser.
                          on windows I use the bitvise ssh client that gives me ssh window for commands and a file system browser for editing files.
                          mixing vertical and horizontal is hard
                            1a2a3a @sdetweil
                            @sdetweil I’m also using bitvise as per your suggestion. Editing config file and the drag and drop is brill.
                            I install MM on pc and do the css on the pc and edit the css before transferring the css over to pi. Only problem is pc MM is horizontal and more often than not I have to guess and trial and error to get my position right.
                            My pc MM is started via npm start dev hence I can adjust the horizontal scale. So the horizontal position is always like for like. It’s the vertical part that I couldn’t do it because well, the horizontal monitor is not long enough….
                              sdetweil @1a2a3a
                              @1a2a3a you don’t have to transfer the css file, just double click to edit and save.
                              I use notepad++ or visual studio code as the config editor
                              yeh, doing the math on the dimension changes is a pain in the rear.
                              get it like you like it horizontal and adjust
                              x times narrow_size/wide_size ( like width of 300px * 1080/1920)
                                1a2a3a
                                @MMRIZE hi, can i know how to change eventheight in cx3? whenever i try to custom change the value, it is overwritten by the default element style which i have no access to it…
                                M 1 Reply Last reply
                                  MMRIZE @1a2a3a
                                  @1a2a3a
                                  https://github.com/MMRIZE/MMM-CalendarExt3/blob/main/README.md
                                    1a2a3a @MMRIZE
                                    @MMRIZE read and don’t understand which was what I did.
                                    I input —eventheight into my custom css but nothing seems to change
                                    Edit:
                                    Oh set in config. Let me try
                                      1a2a3a
                                      @MMRIZE did something change? i did a git pull update and now my calendar ext 3 is missing.
                                        sdetweil @1a2a3a
                                        @1a2a3a did you npm install in the module folder again?
                                          1a2a3a @sdetweil
                                          @sdetweil yes i deleted it and reinstall. seems to be working fine now
                                            sdetweil @1a2a3a
                                            @1a2a3a he has a part called a submodule, that needs npm install to connect it
                                            so you didn’t need to clone again, just run npm install
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 34
                                            • 35
                                            • 21 / 35
